When the monitor goes on stand-by it has difficulties turning on. It flickers and makes a clicking noise. I have to turn it off then turn it on for it to display. Is the backlight going bad? I have a Hanns-G HG281 that has been repaired once under warranty for the same problem, but then it would not turn on at all.
CRT on a flatscreen LCD monitor does not go bad. To my knowledge LCD flatscreens do NOT have a CRT, so it cant go bad.
Posted on Jul 23, 2012
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
The same old problem is coming again, last time it was not fully repaired. Get it repaired this time or try to exchange this one, if in warranty. A small flickering can result in the same old problem. Enjoy !!! Thanks for using fixya !!!
Posted on Nov 11, 2010
  • 43 Answers
Sir i am sorry to inform you that this could be dangerous to use as the monitor's CRT might be going bad and as you have said that you have already repaired it once it better if u get the monitor replaced .
This is a common problem with the monitor .
u can also refer the search engine for details
My Monitor LG Flatron W2243S keeps flickering and turns off, this started yesterday
Try another good monitor, if it solves the problem replace the monitor if not replace the computer.
Oct 25, 2012 | LG Flatron W2243SPF Widescreen LCD Monitor
Hi, i have viewsonic 1940w. When i turn it on it makes buzzing sound and after 5-30 seconds it goes in stand by mode(orange light). Sometimes screen flickers to. If you turn off monitor and on again you...
I fixed this same Viewsonic problem by replacing the electrolytic caps on the power board and re-soldering the power transformer joints. The noise is coming from the transformer, if you torque it the noise stops. Cold solder joints must have been the cause (large posts did not heat up enough during construction). The bad joints might have caused a cap to overheat too, not sure but one was swollen and leaking and after replacing them the squealing was stronger and allowed a longer running time to locate the cold joint.
Oct 23, 2010 | Computers & Internet
My VX1962wm monitor began making a almost hissing noise and has not displayed what it should be properly since it first made that noise. The monitor will turn on when I turn on my PC, but it makes the...
Your monitor has high voltage leak from one of the bulbs end to the ground. This leak is in form of an arc starting from the solder on the bulb where the wire ends and ending on the metal frame of the LCD.
The current rises and electronic protection in the inverter turns it off.
You have to take apart the monitor, then the LCD to find the broken insulation and to resolder and insolate the joint between the high voltage wire and the light bulb.
Aug 01, 2010 | ViewSonic VX1962wm LCD Monitor
HPW 2007 goes to sleep
Try going to the control panel after clicking on the start button and it will have an icon that says "power options", there will be options there for the sleep functions for the monitor etc.
Nov 30, 2009 | HP Computers & Internet
Car make noise, look like is left wheel bearing or transmission. When turn right noise dissapear. When car is risen on stands , noise only when left wheel is turning. It is wheel bearing or transmission...
Check the CV joint that the axle connects to. They make a clicking sound when turning a corner if badly worn. Both CV joints are commonly replaced when one of them goes out.
Sep 08, 2009 | 2002 Mazda Protege
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Display Screen goes black
Right Click on Desktop
select Properties
select the Scree Saver tab
Click on the Power Button which is on the right side
select the power schemes
In that select the power schemes options and choose "Never" for turn off monitor, turn off hard disk and system stand by
click on
Apply
Repeat the above step for each option in "Power Schemes"
then click on ok
Feb 15, 2008 | Compaq Presario 1200,1600, Series CD...
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Now the monitor flickers..
Your monitor is slowly dying. Get ready for the eventuality and start saving some bucks for replacement.
Sep 18, 2017 | Mitsubishi Diamond Pro 91TXM 21" CRT...
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
