Question about Microwave Ovens
My coffee pot B30 will not turn on. No lights come on. If you can't solve it, where do I take it for repair I live in Upland CA 91784 Thomas Moga
  • thomasmoga Nov 12, 2010
    Kuerig is the name of the coffee pot
    Kuerig is the Mfg of this single cup coffee maker model B30
  • 8,197 Answers
May I ask who manufactured the coffee pot to help you more.
Posted on Nov 11, 2010
My coffee maker wont turn on
Many coffee makers use neon bulbs to indicate that power is on. These do burn out after a while, but replacement is usually somewhat difficult. In this case, the coffee maker still works; you just don't have the immediate visual indication.
Many of the urn-type coffee pots have problems with the power cord breaking where it goes into the pot. To fix this, you need to remove the bottom, cut the cord where it is broken (on the outside of the pot), strip it back to match the part of the cord remaining inside the pot and crimp on new terminals of the same kind used on the original ends. The hardest part is squeezing the strain relief clamp where the cord enters the pot to remove it, and putting it back on. Study it carefully as it you remove it from the cord so you know how it works. To avoid a repeat of the same problem (and buying a new cord), be careful not twist the cord or bend it too tightly at the strain relief. NOTE: one of the wires in the power cord has a rib on the outer jacket. This is the neutral wire. Make sure it connects to the same place inside the pot as the original neutral.
Other failure points are at the power switch, or (rarely) the heater element. I've seen a programmable coffee maker with a burned-out relay (magnetic switch in a black plastic box on the circuit board). The clock and timer worked, but the heater wasn't getting any power. That part is about $5.
The easiest way to identify the problem is with an ohmmeter. Start by removing the bottom of the coffee maker (unplug it first!). Identify the heater terminals (the heater looks like a small version of the one in your oven and has either screw or slip-on terminals). Connect one of the ohmmeter test leads to each heater terminal to measure the heater resistance (typically 5 - 20 Ohms). If you have a basic (non-programmable) coffee maker, turn on the power switch and measure the resistance from each terminal to each prong on the plug. You should read either nearly zero ohms, or the heater resistance plus not more than a few tenths of an ohm. If you read open to one prong of the plug, you are on the track. Trace where the wire from that heater terminal goes. If it goes to the power switch, check the resistance of the power switch in the on position. If the reading is more than a couple of tenths of an ohm, the switch has dirty contacts, or it's broken or burned out. If you have a good connection from the heater to the power line side of the switch, but you get open from there to the hot side of the plug, the power cord is bad. Likewise, if you get an open reading from the other heater terminal to the neutral side of the plug, the cord is bad.
Programmable coffee makers have a similar troubleshooting procedure, except that you have to check for live AC voltage with the pot plugged in - this is not something to try if you aren't trained in the safe way to do this.
Sep 09, 2011 | Microwave Ovens
My B30 is stopping up in 4 days after it is cleaned with white Vinegar. Is there any other cleaner?
There are many coffee pot cleaners on the market, but white vinegar will normally do the job, if you do it thoroughly. If might take 3-4 passes through for all the minerals to be removed and then a once a month cleaning would be enough to keep it free flowing.
Jun 30, 2011 | Microwave Ovens
I would like to purchase a 9 cup corningware purcolator coffee pot
Click the link below:
Corningware coffee pot
Be CAREFULL they were recalled. See the information at the site below.
Corningware coffee pot recall
Good Luck.
Zeppelinx12
Mar 16, 2011 | Microwave Ovens
I have a Black 4 cup Mr Coffee with luminate lighting and time display programer so that I can have coffee brewed in the morning when I get up for work at 4:30am my problem is the coffee pot has started...
I had a black and decker coffee pot do same thing and it was brand new. here is how I fixed it.
make sure the filter seated down good. If you look at the top of the coffee pot it should open up the little valve of the coffee filter holder. also mine had a little water spout above the coffee filter that swings over the filter. make sure it is over the filter. I know my coffee pot is different, but I think the problem is the opening from filter to coffee pot is not open some how so the water is flooding over the filter and going out the sides onto counter
hope this helps
Jan 28, 2011 | Microwave Ovens
My coffee pot quit working. it turns on but doesnt warm up or start brewing. how do i fix it
Either the heating element is open, the thermostat is open, or the overheat fuse has popped. You can probably replace the pot for what it will cost to repair it. Good luck!
Oct 09, 2010 | DeLonghi Microwave Ovens
I have B30 Mini Keurig. The green power light comes on but the blue flashing light never comes on after I put the kcup and water in there. It does not brew. What could be wrong?
I also just had the same problem- the answer for me was the coffee mug. The sensor lights where you place your mug don't like certain coffee cups- in my case it was any clear mugs. First I had a clear acrylic coffee mug, then a clear glass mug, then tried regular opaque coffee mugs and it worked fine. So maybe if it's clear or somewhat transparent it might mess up the sensors. Hope that's all the problem is for you.
Aug 29, 2010 | Microwave Ovens
New GE coffee maker #169209 (1300 watt) 12 cup digital. House lights flicker when in hot plate warming mode. Tried on 15 amp GFI circuit and then on dedicated 30 amp #10 wired circuit -- but same...
Hi, then it might be a factory fault problem, i will advise you to call in a electrician to come and witness it whenever you put it on so that he will be able to identify weather it is the microwave's fault or an electrical fault...
Mar 11, 2010 | Microwave Ovens
Flickering lights
good day,
hope this link below will solve your problem.
kitchen appliances
Sep 24, 2009 | Samsung MW5351G Microwave Oven
DO COFFEE POT AND MICROWAVES USE ELECT WHEN OFF (
Unless there is a clock, they use no current when turned off.
Apr 30, 2009 | General Electric Microwave Oven
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
