Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
Won't despense dishwashing detergent - LG LDF6810ST Stainless Steel Built-in Dishwasher
  • LG Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Nov 12, 2010
Maytag dishwasher detergent cup won't open on it's own...
The detergent dispenser is sold as a complete assembly, it's reasonably easy to replace, it just unscrews once you have removed the front panel of the dishwasher,
Mar 07, 2012 | Dishwashers
The soap despenser is broken. looks like the spring is inside the holder and it will not close....stays open at all times. model number for our dish washer is 665.13842k601.Kenmore ultra wash. is this an...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
heatman101 '';
Aug 01, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
The detergent isn't despensing correctly. The door seems to be functioning correctly; however after the cycle is complete I open the door and just runs down the door. It never actually gets used. ...
Check the way you're loading your dishwasher. Sometimes large plates or baking pans can block the door of the dispenser. The latch unlocks but because the door is blocked, the detergent can't get out. Once you open the main door, the dispenser door pops open and looks as if it has been in the fully opened position when it was actually held in place by that large utensil!Cutting boards are major blockers as well.
I hope this helps. If it does, please come back to fixya and rate my answer!
Jun 30, 2011 | Dishwashers
Finish dishwashing product does not dissolve
Many dishwashing detergents need a water temperature of 140 degrees to dissolve. If your water is at the correct temperature, the only other suggestion I have is to make sure the detergent dispense is not blocked by large objects such as baking sheets, frying pans etc. If the dispenser cannot open fully, the detergent won't dissolve.
I hope one of these suggestions helps you. If it does, please rate my effectiveness. Thanks.
Jun 02, 2011 | Dishwashers
Help! My dishwasher runs thru it's cycles but when I open it I find my second detergent cup still full of soap and my dishes still dirty. I have an older maytag dishwasher but have never had this...
heatman101
Aug 27, 2010 | Dishwashers
Asko 1805 dishwasher detergent door does not despense the detergent during the wash cycle. At the conclusion of the dishwasher cycle the door is still closed. How do you repair?
First make sure that nothing is blocking it.. when you load the dishwasher...next make sure your dishwasher cycle is NOT on rince and hold ( water spraying on a plate symbol) as this cycle will not open the despence door..
last you can remove the screws in the door check the vax motor and or check if you are getting power to the despencer ( no power replace control)
power to vax motor replace despencer motor
Hope it helps if Not let me know more about you problem..I can help
Sep 05, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Whirlpool quietpartner I Dishwasher wont clean anymore.
you need to take the blades that spin out and clean them off they have grime on them, is there water still in the bottom of the dishwasher when done> if so there is a plastic grate in the bottom rear of the dishwasher you need a 1/4 inch nut driver take the cover off and clean the debris out, there is a small stainless steele cutting blade in there be careful, it is to cut up foods that might not be washed off before putting dishes in the washer, also it is pressure that makes the detergent door open make sure you are getting full pressure comming into the waher, if non of this works the pump should be replace or it;s new dishwasher time
May 30, 2009 | Dishwashers
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
160 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
