Question about Refrigerators
GE frig cooling problems
I have a GE TFX22P. Both freezer and fresh are not cooling. Frid side is in the 50 degrees. The repairman said it was not the heater defroster. No ice build-up. He said it was low on freon and might have a tiny leak. He put freon in it and it did get much colder but the refrigerator compressor and fan run constantly. Is that normal? Then he said after he put the freon in that the compressor tested poorly and I needed a new compressor. 500 dollars for the part. If freon worked doesn't that mean I have a leak? Why would I want a new compressor if I had a leak, or does adding extra freon cover up symptoms of a bad compressor. I am a woman ...lol. ....please help. I can't afford not doing the right thing. Should I buy a new frig? I am worried that I will blow money on a condensor and still have a freon leak. How long will it take for freon to leak back out? What should I do? Thanks so very much for any help. I need it badly
  • turtlebug Jun 17, 2008
    Thank You very much fixum
    Director Badge:
    Uploaded 100 video answers.
  • Refrigerators Master
  • 488 Answers
This Refrigerator was charged with leak dye about 4 month before it leaked out again. Got service call, there was sticker dated 4 month ago, thats what honest company do, even if other company will come out they able to see when it was charged with freon and if they add leak dye. Got my blue flash light - found right away dye, spayed with soap - bubbles right on the spot, replaced piece of copper tube - leak fixed! call right service man at first!
Posted on Jul 13, 2015
    Genius:
  • 1,073 Answers
The repaorman sould have repaired the sealed system leak the unit is not gona leak a little of freon and be ok there is a leak and needs to be repaired
call 800-905-9505 this is for a&e factory service. the techs are factory trianed and they will be able to repair the machine for a lot less than the price that you posted
Posted on Jun 17, 2008
GE TFX22P Refrigerator Evaporator Fan
Fun run as long as the compressor runs and you do not need to worry about it. the only thing you need to verify are the temperatures in the refrigerator and and freezer compartment: below 40-F, and below 0-F
if temp ok, do not wory about it.
Aug 18, 2014 | GE Profile 21.6 cu. ft. Side-by-Side...
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
FRESH FOOD SIDE OF FRIG NOT COOLING
i would take the back freezer panel off and see what kind of frost pattern your coils have.they may be frosted over and the begining of a defrost problem.
Mar 11, 2009 | GE GSH22KGM Side by Side Refrigerator
Whirlpool refrig not cooling
is the fan in the freezer working when compressor is on? if not you need to replace it. do you have a large frost build up on the back wall of the freezer? if so you have a defrost problem, or back to the evaporator fan. If the fan is working you have a defrost problem which could mean a bad heater, timer, or bad defrost thermostat....
Jan 03, 2009 | Whirlpool GS6NBEXR Side by Side...
Hi Guys, I have a GE Profile Frig: PSF26NGTDBB Serial # SL416129 This AM the softdrinks seemed a little warmer than usual. We checked the digital temperature inside the frig compartment and the freezer...
HI thanks for your question. the problem is either that the fan in the freezer is not working, or the fridge is frosting up, or the coils at the back of the fridge are dirty. first clean the coils .it could be you problem. thanks the appliance doc please rate my answer . thanks.
Oct 09, 2008 | GE Refrigerators
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Doesn't cool fresh food
It´s probably overloaded. Any refrigerator has a specific cooling capacity eg x Kg/24hours. you must check that capacity and charge acording to that.
Jun 30, 2008 | GE Refrigerators
Frig side by side problem
yes it could. you again have a defrosting problem. do you noticed frost at the back side of the freezer section? the repairman could have replaced your heating element and your defost timer.
Dec 28, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
455 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
