Question about Olympus FE-330 Digital Camera
My olympus FE-330 displays a black screen. it shows every menu and function on the camera but the outside image to be snapped does not show at all. its always as if someone is trying to take a shot in TOTAL darkness.
  • 11967 Answers
SOURCE: hi i have a olympus
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 18, 2010
SOURCE: Camera malfunction
when the lens are protracting i held them  and they didnt go back in. then i turned it on and it worked! but the lens dont go back in when the camera turns off and the zooming is messed up because of it, but it works!
Posted on Feb 08, 2009
zohail
  • 1223 Answers
SOURCE: Olympus FE-330 Blank Viewfinder
BAD CCD problem if u take pics and those are blank and u have bought camera recently kindly run for warranty it is a bad ccd imager problem it will be replaced dont worry
pls rate me FIXYA for help
Posted on Apr 03, 2009
  • 34 Answers
SOURCE: can i use a sd memory card with my olympus fe 330
No this is not possible. Olympus is using the xD-Picture Card.
If you get an microSD to xD adapter (Olympus MASD-1 adapter) it is possible to use Micro SD Cards.
Posted on Jun 09, 2009
SOURCE: Olympus Fe-4000 screen is completely black no image available
My FE 4000 takes a photo's on the screen but you cannot view them clearly they are very dark. Also some day time photos turn out dark. Does anyone know what is wrong with my camera.
Cheers
Michelle
Posted on Apr 27, 2010
Display does not show any view
You know you can change the monitor brightness? Check the manual (eventually online) to see how to change the settings. Please check if you can playback pictures you already shot, to make sure the display still works.
You also could remove the battery, charge it and then replace it. This acts like a cold boot from a computer.
May 24, 2014 | Olympus FE-210 Digital Camera
My olympus camera fe-340 showing black screen when i snap a picture its also showing black all my picture before we erase need help
If your menus work and you have no picture in recording mode, either movie or single, then your possible problem is that the CCD sensor has a problem.
See if it is still coverd by the manufacture, if not sell it for parts on Ebay or some such website.
Oct 31, 2011 | Olympus FE-340 Digital Camera
Black screen no image showing
black screen blur image showing cannot see subject to be photographed when camera power on,if press to take photo nothing shows, just black screen. it was fine one minute then nothing the next. battery is fully charged, memory card ok.
May 24, 2010 | Olympus FE-230 Digital Camera
My olympus fe-330 has a cracked screen. What is my best and cheapest route for getting it fixed?
http://shop.ebay.com/i.html?_nkw=Olympus+FE-330+screen+&_sacat=0&_dmpt=Batteries_Chargers&_odkw=Olympus+FE-330&_osacat=0&bkBtn=&_trksid=p3286.m270.l1313
Ok this is probably the cheapest way to buy one suitable display ...and if you do it yourself ..it will be the cheapest way to fix it ...It is actually not that hard to change cause it is just a ribbon with a plug in the end ..The issue is to open it right ..and have patience and not to panic ...Just study it ..to see all snap clicks amd screws that may be hidden ...open it ..and replace ..
have a great day and do not forget to rate me ...!
May 02, 2010 | Olympus FE-330 Digital Camera
My olympus FE 340 is showing a black screen when it comes on. Photos are showing black also. However, I can review photos that are already on the camera, and the graphics/icons on the screen when I go to...
There are two possibilities for said problem, one is ccd imager chip failure that will be replaced and other is jammed aperture that is inbuilt in lens mechanism and lens assembly will be replaced.
In either problem, camera needs visual check of qualified tech, local camera repair shop will help you.
Thanks.
Apr 03, 2010 | Olympus FE-340 Digital Camera
Olympus c-25 screen black but will take and display new photos. just not showing image in real time
you may have turned 'monitor' off feature to save power. consult your manual. or just press the 'menu' or setup if you have that
Jul 15, 2009 | Olympus FE-210 Digital Camera
Olympus FE 330
Unfortunately the camera does not have a menu option to take images in black or white or sepia. You can take them in color and then using photo editing software modify the image to be monotone or sepia in color.
May 06, 2009 | Olympus Cameras
Apr 03, 2009 | Olympus FE-330 Digital Camera
Olympus camera FE-330 day month year installed shows up on review but not on printing
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Nov 19, 2008 | Olympus Cameras
Olympus FE-330 Digital Camera Logo
41 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
