Question about Sony Cybershot S650 Digital Camera
Im getting a blue screen file error and cant import to my computer
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on May 01, 2011
How do I fix dell error code 0x8000FFFF: Catastrophic Error.
use photobucket, it's much easier and it syncs automatically.Or you can try to take the memory card out of your phone and stick it in the laptop to do the transfer. Use a micro sd card carrier that plugs into your laptop like a regular sd card. Or you can tell your phone to always connect as a usb mass storage device.
Feb 23, 2015 | Dell Computers & Internet
Tip
How to View Windows Minidump Files
First of all, you need to configure Windows to save these important log files. Most of the time, this is already done automatically, however follow these steps to make sure these log files are being saved.
1) Click on Start
2) Right-click on My Computer
3) Click on Properties
4) In Windows XP , click on the Advanced tab. In Windows Vista , click on the Advanced System Systems option on the left side of the screen.
5) Under Startup and Recovery, Click on the Setting button
6) Under the System Failure section, you'll see the options for the memory dump file. Write an event to the system log should be checked along with Send an Administrative Alert. The debugging information should be set to the Small Memory dump (64K) and generally the Small Dump Directory is set to %SystemRoot%\Minidump. In most cases this is the C:\Windows\Minidump directory.
As far as the third check box is concerned, if this is checked the computer will automatically restart when a blue screen error message is encountered. So, if your computer is booting into Windows, then rebooting automatically most likely you are getting some sort of blue screen error message and its forcing the computer to restart. If you uncheck this box, then the message itself will appear so you can retrieve important details about the error.
Download and Installing the Debugging Tools to Read Minidump Files
In order to view the Minidump files, you have to download the following tools.
Debugging Tools for Windows including WinDbg
Although most of the time its not necessary, you can download the Symbol packages as well as the Debugging Tools so you can read the Minidump logs easier. Once you've downloaded the Debugging Tools for the correct version of Windows and installed them, open the WinDbg program by following these steps.
1) Click on Start
2) Click on All Programs
3) Click on Debugging Tools for Windows group
4) Click on WinDbg to open
The screen should look similar to the one below.
Deciphering the Minidump Files
In the WinDbg program, click on File, then click on Open Crash Dump
Browse to the following directory on your hard drive and open a minidump log. The drive letter will be whichever drive you installed Windows on. In most cases, this is drive C.
C:\Windows\Minidump
After you open a minidump file in WinDbg, scroll to the bottom of the file. You should see a line that says Probably caused by:, followed by a filename. This is the problem file. In my case the file was related to the ELock Program in the Acer Empowering Technology set of tools. I simply uninstalled this program from the computer and the blue screen and problem went away.
Probably caused by : eLock2FSCTLDriver.sys ( eLock2FSCTLDriver+11332 )
Although you may not recognize the file that is causing the problem, it definitely helps in tracking down a solution for the blue screen error message and resolving the issues.
on Jun 25, 2010 | Computers & Internet
Tip
Blue Screen Of Death (BSOD) Important Info When you get a Blue Screen Of Death...
When you get a Blue Screen Of Death (BSOD) on your computer this can be very frustrating. Below is the info you need to get from a BSOD because the way that Microsoft words the message a lot of people miss the real important parts. With the right information this will helps tech support help you address your problem quickly.
The first thing to look at is the error message. A lot of times you will get a message like the one below that states "PAGE_FAULT_IN_NONPAGED_AREA". In the case of this BSOD the error screen the error code is a generic one of 0x00000050 so we have to rely on message that tells us that the problem was with the memory or the page file.
The next thing to look at is the error code. Note you really do not need the info between the parentheses for standard trouble shooting.
So with both pieces info this will help tech support figure out where the issue is at and where to troubleshoot.
Note the file name that the BSOD list normally is not important in troubleshooting the in most cases it just point to the point where Windows had the problem.
on Mar 29, 2010 | Computers & Internet
I have a Sata portable video hdd, its a multimedia external hard disk, yesterday when I tried to put dome files from a friends computer it got jammed, and now I cant connect it to my computer either,the...
Only thing you can do at this juncture is remove the drive from the external case and hook it up as a slave to your main computer. Boot your machine up (cross your fingers) and using windows explorer locate and transfer over any files you want to the main drive that you booted up from. Do it as quickly as you can since your drive id dying. Do not perform any diagnostics on it since that procedure alone often kills the drive completely and you are really then out of luck.
And if your computer will not tolerate its presence try doing the same procedure on another machine since all computers are different and react differently to different situations - u might get lucky and fine one that will allow you to transfer your important files.
Apr 23, 2017 | Computers & Internet
I have an hp mini and I recently tried to clear some things to make space and now i cant get into my computer. It keeps giving me a message about it detected a problem
Hi there! When you cleared things to make space, you may have accidentally deleted important system files, and your system may have become corrupted. Did you get some sort of recovery USB with your HP Mini? Does the message have a blue background? Does it look something like this: http://www.grahamnewbert.co.uk/Some_Pictures/BSOD.jpg ? If it does, you have a so-called "Blue Screen of Death", which means that there is a serious error with your system, and Windows won't work.
Mar 25, 2011 | HP MINI 2133 Notebook
I have sony-dsc -s930<cybershoot>.at present
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 05, 2011 | Sony DSC-S930 Digital Camera
I have an acer that will go to a blue screen after I type in the password then it restarts itself over again the same thing!
Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors
The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors
In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors
However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
Update Windows - missing updates, including service packs can be a source of stop errors.
Check your system - run a virus scan and spyware scan after updating your definition files.
Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
hope it helps, if so rate the solution
Nov 29, 2010 | Acer Aspire 3690-2196 Notebook
Hello my acer aspire 3680 has a blue screen error
You can refer to my earlier answer,here is the link
http://www.fixya.com/support/t3766071-dell_precision_m4400_blue_screening
Jan 03, 2010 | Acer Aspire 3680 Laptop
BSOD
I found this on the web. pls read below
If you find this information, helpful, pls rate
me. Good Luck.
In most cases, the build up of junk files in your registry is the main culprit of this trouble; this is due to the fact that area in your computer is very crucial because it is the central database of important files where most vital information and programs are stored. The accumulation of redundant items can significantly affect vital data because the build up can dislodge some of them from its proper location and cause others to be corrupted. The moment this scenario takes place, problems start to emerge and the dreaded blue screen of death appear which you need to immediately repair to prevent worsening the case.Consequently, one of the best solutions in managing the situation is to use registry cleaning tools http://make-computer-run-smoothly.com with great power and capacity to completely flush out all junk files and fix all errors found. By effectively keeping this area clean from all trashes, you can also effectively solve the problem and even optimize your computer's performance.
Nov 05, 2009 | Toshiba M200 Tablet PC
Blue screen on my dell latitude d600 tells me its dumping memory and that its complete says contact tech support
Hello my friend,
The blue screen is very popular and it's usually happen when there is a file system deleted or a virus on your computer.
You may try to boot up your system in safe mode and then uninstall any software that you installed recently and restore also your computer to a date when it was working fine.
If this doesn't fix the issue, you can try the recovery system if enabled when you installed your system for the first time.
If it's not the case, the only way to get this computer working again is by formating your computer and installing windows again.
Best Regards,
Oct 31, 2009 | Dell Latitude D600 Notebook
Sony Cybershot S650 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
