WASHER FILLS BUT THEN WON'T START. WILL LIFT THE LIFT AND CLOSE SEVERAL TIMES AND THEN WILL START. NOW DOESN'T START AT ALL. IS THIS THE SWITCH ON THE DOOR, SHOWING IT ISN'T CLOSED SO IT WON'T START?
    Genius:
  • 1,028 Answers
Must be a whirpool or kenmore shut lid try pressing down on left rear corner be sure lid hinge screws are tight then raise lid on left corner under top out of sight you will feel small lever push toward back of washer slightly and then try again also if lid center has popped down push up slightly in center till lid pops back up sen it happen once where washer would not spin
Posted on Jun 18, 2008
  • 6 Answers
SOURCE: LG Washer dryer error dE
Unplug the machine.
Plug back in (maybe 10 seconds later).
Mine had several dE messages. Unpluged, waited 10 seconds, when pluged back in, it remembered which cycle and parameters I had it on, then locked the door and continued with no problem.
Posted on Apr 12, 2009
  • 245 Answers
SOURCE: Fills with water then stops
it sounds like the lid switch is going out if you lift the top of the washer you will see it in there this is a safety feature for homes with small children if your kids are all grown and gone you can connect the two wires going to that switch to bypass it otherwise any appliance parts store will have these switches in stock they are usually around $15
Posted on May 15, 2009
kel1guy2002
  • 3740 Answers
SOURCE: WASHER STOPPED
Hi and welcome to FixYa. I am Kelly
Just as you raise or close the lid you should hear an audible click from the lid switch. It will be faint but audible. If you do not hear a click then there is a problem with the lid switch. See item 18 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47786&diagram_id=675654#d675654
1. Unplug the washer.
You gain access to the lid switch by removing the 2 screws in the lower front panel then pull the bottom of the front panel toward you / outward then off. After that you will remove the 2 bolts (Item 20 of link above) and tip the top straight up from the front. The lid switch will be in the center of the back of the lid area inside the top panel.
If there is water in the unit select SPIN on the timer.
You can remove the 2 wires from the lid switch and jumper them together to see if the machine works. If it works the lid switch is bad.
Reassemble in reverse order....
If you still have problems after trying this just respond here and I will get back to you asap.
Kelly
Posted on Apr 18, 2010
  • 6277 Answers
SOURCE: I have a Frigidaire washer model ftf2140fs1, the
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jul 09, 2011
Jahn27
  • 1554 Answers
SOURCE: Whirlpool imperial series washer will
The problem is obviously the lid switch which now have got broken totally The only viable solution then is replacing the lid switch. Unplug the machine or disconnect power then release the console from the top of the cabinet by removing the screws securing the rear of the console. Pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine. Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Please accept the solution should you find it helpful and/or informative. Accepting the solution will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Aug 04, 2011
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Washer over fills with water
They work on a pressure switch. It has a rubber hose that connects to the bottom of the drum and runs up to the top control panel. When water fills up into the hose the air pressure trips a switch. So either the switch is bad and not making contact when it clicks. Or the hose is leaking air so it won't let it build up enough pressure. I had one that a mouse got up into and chewed a hole in the hose. You can take the back panel off of the top control panel and let the water in and listen to see if the switch clicks when it gets fulll. If it does and doesn't stop filling then it is a switch.
Or it could be the water shutoff switch where the water hoses hook up. If it is that then it will run all the time, more than likely. Is that what it is doing? Does the washer start running and water keeps coming in? Because it wont start running until the pressure switch is enganged. If it starts running and keeps coming in it is that. Good luck hope this helps.
Dec 04, 2011 | Kenmore 24032\24036 Top Load Washer
Whirlpool High Capacity washer, start cycle , it fills with water then no agitation, and no spinning.
next time send the model number,open the lid,look on the right side and there should be a hole in the top,that's the lid switch,it's used so the washer won't run if the lid is open for safety reasons,set it to spin and with a screw driver push down on the plastic piece in the hole,if nothing happens push in and release,do this a few times,if you don't hear a clicking sound when you push up and down the switch is bad or close the lid and open it an inch,close it and open it a few times,no clicking sound the switch is bad.
Jun 12, 2011 | Whirlpool 3.2 cu. ft. Washer
Fills with water then won't go to the wash cycle until you slam the lid several times
It sounds like the lid switch is faulty. The washer has a lid switch that checks to see if the lid is open, if lid is open the washer will not start the wash cycle. Check/replace the lid switch and you should be back in business.
Oct 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Thanks in advance, my washer fills with water but doesn`t spin. not any noise.
The safety interlock switch might be bad. That's a safety switch to prevent the machine from agitating or spinning while the door is open. Close the door slowly and listen for a click just before it is completely closed. If you don't hear it, then check the alignment of the door and its actuator. If you do hear a click but the machine doesn't start, then the switch may need replacement.
Sep 18, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Ultra II 90 series washing machine (#11092561400) it fills & agitates but wont drain & spin/rinse? Any solutions.
lift the lid up a few inches and close it down a few times,if you don't hear it clicking you have a broken lid switch,also try to stick a pen or something in the hole on the top and see if it spins,let me know what you find
Aug 27, 2010 | Kenmore 22422 Top Load Washer
I have a Kenmore 900 series washer. It fills with water but them doesn't run. I see no switch on the lid but if I lift and shut the lid sometimes it will start. This is getting worse.
There is a lid switch which is proabably going bad it is located at the rear of the lid lift the lid up all the way look where the lid touchs the tol at the back in the middle you will see a little tab sticking out which when you close the lib the lid presses down on this tab which makes the switch function. You have to take off the top of washing machine to replace switch. Unplug washer before doing this
Aug 07, 2009 | Kenmore 24052 Top Load Washer
Kenmore washer Model# 11024642300
Dear Customer
Please perform the following checks
Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model # Please rate this,Thank u
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
