Question about E-Machines eMachines Monitor E15T4
I have a new Acer computer which worked fine at first, but is now flashing on and off the screen when I try to connect to answer my mail. It happened a few days ago, and I just quit and today when I tried to read my mail it is doing the same thing. I can see the menu but only for a second or two between flashed. I need some help. if you can. Thanks, lbleeper@att.net
  • 6,993 Answers
check the back of the monitor, you will see a wire connecting from the monitor to the CPU. Make sure the wire is is firmly connected to the CPU. That wire is called VGA cord and that's what makes the CPU display on the monitor.
It is possible that the wire is shaking and that might be what's making it loose contact and can cause the screen to flash.
Let me know what happens when firmly connect the VGA cord/wire.
Good luck.
Posted on Nov 11, 2010
Dark Screen on Acer Aspire 5735z
That sounds like the bulb in the screen is blown. I have changed them at times but it is very tricky and I'm pretty sure you won't find a reputable place to do it for you.
Effectively in answer to your question the only rational solution is to change the LCD panel, it's not very difficult to do on the aspires, just a few screws and peel off the tape holding the screen connector in place, disconnect the inverter cables, (pink and white) and swop for the new panel. check ebay etc for a new LCD panel they're not that expensive. Try to get a new one instead of a second hand one. to find out what panel you need, you'll have to open the screen and look at the back, it'll have a paper sticker showing the model number.
Jun 12, 2013 | Computers & Internet
Grandson dropped his Acer Aspire One. Now has double screen with blank white screen in center. (Left half of a normal screen shows on left side of screen and on right side of screen, with white screen in...
My suggestion is to replace the LCD with new one. Let the certified technician to work on that. You cannot perform the DIY on that. Its too complicated.
Aug 18, 2010 | Acer Aspire One PC Notebook
Replaced the broken screen in my Acer Aspire One D150 (10 inch). It seems to work fine, except when the computer is powered off. The screen remains ON and completely white when the computer is turned off....
Sounds like your "Backlight" is not powering off.
Are you sure it is an exact replacement?
Check ALL your connections again, perhaps ya have a bad one...?
Have you got the latest drivers?
Jan 18, 2010 | Acer Aspire One D150-1587 Netbook
ACER EXTENSA 4620-4605 model screen problem
If you wiggle the screen and it comes back, then it is not your Video card. Probably just a loose connection with your LCD cable to the LCD screen. Although you may also need a new screen/cable.
The weird thing is that it "fades" out... which would indicate a bad screen to me.. but securing the cable is alot cheaper to try first.
Completely rule out your graphics card by connecting your laptop to an external monitor... if it works fine for a long period of time then your card is fine.
Good Luck.
Sep 06, 2009 | Acer Extensa 4620 Notebook
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Wireless network access: 1 laptop fine, other not so much
Check the wireless card on the PC first. Go to "My Computer" then "Device Manager" and check to se if all the hardware is ok.
Use Control panel/netconnections to check to see if you still have a wireless connection and if it works. Also check "My Network Places." Try re-installing the drivers.
As a last resort....try System Restore if it's an XP or Vista system. Remember - using system restore will return the PC to an earlier time but you could lose some stuff so decide first.
Mar 21, 2009 | Acer Computers & Internet
Acer aspire one will not work.
If you get a post screen with Acer written on it at startup, and the screen turns off when loading the system (Windows or Linux), then you need to reinstall the system using an external USB cd unit and the recovery disk that was provided with your Acer.
If instead the display has no screen at all , try connecting an external monitor to test the laptop.
If you get picture on external monitor, then the Aspire One has a faulty LCD ribbon cable or a faulty LCD display or inverter.
If you get no picture on external screen , then you have a faulty motherboard, possibly faulty video chipset on motherboard.
In any case check your Acer One warranty, all the faults listed are covered by Acer warranty for one year.
Contact Acer at the number listed on documentation to have the computer repaired.
Mar 13, 2009 | Acer Aspire One PC Notebook
Possible monitor or graphics card malfunction
The monitor is bad. The flashing is telling you that something inside the monitor has gone out. If it is still under warranty they should either fix your monitor or give you a replacement. Hope this helps & please remember to rate my answer.
Dec 28, 2008 | Computers & Internet
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Black screen
Hey there everett 403, my first suggestion would be that your video card is malfunctioning. You have not mentioned if you installed one. If you have one installed, begin by removing it and switching your monitor connection to the onboard port. If this works to get the screen working, then next step is to replace the video card. If it is still not working, try removing your ram. Check it for damage of any sort. If good, reinstall and ensure to seat properly. I would also check the light on your motherboard. If it flashes, there may be a problem with your board, such as burnt capacitors. If these solutions do not solve, please include info on configuration and peripherals, and anything different you have been doing with your machine as of late. Good Luck!
Jan 29, 2008 | Acer Aspire™ T180 PC Desktop
E-Machines eMachines Monitor E15T4 Logo
29 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
