002: Fatal Error, 01F6E018, 01F6DFB4 and 01F64998 errors on okidata C5150n. Have to turn off and on each time. It only works for a little while and you have to turn on and off again.
  • monakhd Jul 11, 2008
    I'm having the same problem with my C5200N.
  • Anonymous Sep 08, 2008
    same problem here any idea on how to fix ?
SOURCE: fatal error 002
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
Take the printer off the network. (Remove the network cable) Then enter the menu and select network menu. You want to change the settings as described below:
Change the Hublink Setting to "100 base tx full"
Change the FTP Setting to "Disable"
Once done and machine says online, shut it off, reattach the network cable and restart the printer.
You may also want to change the printer's IP address.
If this does not help, or you cannot get past the 002 fatal error then the machine will require service.
Posted on Dec 06, 2008
SOURCE: Oki C5200n 002: Fatal Error
We have to change firewall settings in our Fios router. I just don't know which ports or udp to open.
Posted on Jan 08, 2008
SOURCE: OKIDATA C3530 MFP with 980
buy a new fuser
Posted on Oct 07, 2008
  • 44 Answers
SOURCE: okidata c5200n printer 173:FATAL ERROR. What is
In the fuser unit the Heat roller thermister indicates a low temperature error. Replacing the fuser unit will usually resolve this. Fuser units are consumable items bur for an early life failure such as this it may be worth contacting the manufacturer.
Posted on Apr 19, 2009
  • 526 Answers
SOURCE: fatal error : 144 on a Okidata
this is indicated when the toner feed switch error
or the toner locklever-open error occurs repeatedly when new toner is used.
it has to do with the yellow.
3 possible solutions.
Confirm that the lever is in position.
Replace the toner feed unit.
Replace the ID units.
Posted on Aug 28, 2009
Testimonial: "Thanks for the advice SALES320 in that it ended up being a issue with the yellow drum unit."
OKI c6150 with error msg 002-fatal error. please, I need a quick answer. do not have time to scroll through pages of older posts
If you printer has an additional memory card fitted then remove it (powered off of course) and turn on and see what happens. If the fatal error is still there then with the age of the machine (getting on in years) it is better to replace it as the error refers to the cpu in the control board and that's expensive on older machines to replace.
Jun 20, 2016 | OKI C Office Equipment & Supplies
925 fatal error
www.okidata.com/canada_en/downloads/C9600_Bertl_4Stars.pdf
all in manual above. http://www.okic3200n.co.uk/index.asp?printername=C3200n&menumode=0&content=errorcodes
error codes above.
Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
May 08, 2010 | OKI C9600hdn Laser Printer
Fatal error : 144 on a Okidata
Aug 28, 2009 | OKI C9600hdn Laser Printer
I have a oki 9600 Fatal error 917
Replace the transfer belt unit. A 917 is a belt **** sensor error.
Jun 19, 2009 | OKI C5150n Led Printer
Getting Fatal error 020 on my Okidata 7300 printer. How do I fix.
You could take the controller board and reseat the dimms. But the Rom Dimm is usually bad and needs to be replaced.
Apr 15, 2009 | Office Equipment & Supplies
Fatal error 002
Aug 08, 2008 | OKI C5200n Laser Printer
Fatal Error 162
I am pretty sure this is the result for your 162 code:
Toner Sensor Error, Color:Cyan
When cyan toner sensor error has occurred
Try reseating your toner carts.
May 14, 2008 | OKI C5150n Led Printer
Fatal Error
unplug and plug back in.
Jan 15, 2008 | OKI C5150n Led Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
170 people viewed this question
jasbo
jasbo
