I have Model DX-L15-10A bought a year ago. I have moved and I no longer can find my manual to reset the channels - do I need a code ? or do I need my book? How can I get both? Time Warner is pleased to assist me but they need a code or something like that. I'm not too swift when it comes to resetting something. Thank you. Gisele
  • 1 more comment
  • giselediane Nov 11, 2010
    The only # the remote has on it is RC-401-OA Thank, Gisele
    Thanks so much. I'll just have to go out and get me a new remote. I appreciate the quick answer. Thanks, Gisele
    It wasn't the answer I wanted but they gave me a way to go. That I find very helpful. Yes, I will get me a different remote and I printed my book so in a few days I should have my TV in the Kitchen going for the first time since I moved here. Thanks, G
  • 8,197 Answers
Welcome to FixYa! you can get the manual on the link below. As for the codes I need to get the remote model # to help you more.
http://www.dynexproducts.com/cms/documents/DX-L15-L19-L22-10A_08-1840_MAN_V2_ENG%20Final%20lr.pdf
Good Luck
Posted on Nov 11, 2010
  • Jyackle5
    Jyackle5 Nov 11, 2010
    Sorry there is no code for the remote to program to time warner. If you would like one remote to control the TV and cable box then you will need to get a universal remote.
    Good Luck
  • Jyackle5
    Sorry that is not the answer you wanted but that is the only way to fix the problem.
Finally bought anRCA antenna for my new Dynex TV.Nothing no signal,no way to scan for channels I can see.AGGH.Is it a lemon?
Which Dynex TV do you have? The manuals for most Dynex TVs are available from the product page. Start at http://www.dynexproducts.com/products/televisions.html . If you have an older Dynex that isn't on the main list, check under Discontinued Products. Alternatively search for your model. Then click on the Support tab to find the manual for that model.
For at least one Dynex TV (DX-32L152A11), the procedure to scan for channels is below.
To scan for channels, first make sure that the current input is set to TV. (Press the input button on the TV or the remote). Then press Menu and use the left/right arrows to select TV. Then press Enter or down arrow (the manual says the right arrow). Use the up/down arrows to select the entry to change. First, make sure that the Tuner Mode (first item) is set to Air (use the left/right arrows to change this). Press Menu to go back to the TV menu. Then go down to Channel Scan and press Enter. You may need to confirm the channel scan and press Enter again. Wait for the scan to be completed.
On a discontinued model (DX-32L151A11), the procedure is slightly different. With the input set to TV, press Menu. Select the Channel submenu and press Enter or down arrow. Set the TV mode to Antenna (use the left/right arrows to change the value). Then press the up/down arrows to reach AutoScan. Press Enter. Move cursor to highlight Yes and press Enter again. Wait for the scan to be completed.
I hope this helps.
(There were some Dynex monitors built. They usually do not have a coaxial antenna in port since they didn't have tuners.)
Jul 29, 2011 | Olevia LT32HVE 32 in. LCD Television
Can't get arc unless use sratch method also code says hlv 10? took the points out and cleaned them up reset to specks. was working about a year ago but now is not bought from kinfolk
www.coastaltechnicalservices.com
go to this website above look for and contact "The welderrepairman", he will assist you in what to do, he is the resident expert on these devices.
in my experience, this has to do with the auto-start and sense circuits, and is often a "Op-amp" or similar, however one would need a service manual,and schematic to be able to diagnose this exact fault, as related get in touch with the person above, he is the guru...
Jun 24, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
DOES THIS TV NEED A CONVERTER BOX?
If you scan your channels you will find out if it is digital. Say for instance you get channels 2-1, 16-3, 12-2, 12-3, then your TV is digital. Now if all your channels have no dashes and your channels come up 2, 12, 9, 16, and so on then you have an analog TV. Since this is a walmart brand there is not any online support that I can see. If you bought this a few years ago then again your tv is more than likely analog.
Apr 24, 2009 | Televison & Video
My Mitsubishi tv will not turn on.
If you have the owner's manual, you will find that the blinking light is an indicator that the lamp or fan is the problem. I'm not sure of your model number. Can you confirm that model please? If you no longer have the manual, once you confirm the model number, I can look up the code for you. Given its age, I would suspect that the lamp needs to be replaced.
Please post the model number and I will confirm.
Thanks,
Dan
Feb 20, 2009 | Mitsubishi WD-52725 52". Rear Projection...
How do you reset a locked out channel when the code is forgotten?
Try pressing simultaneously the QV and 9 on the remote to bypass the parental lock. Then press the MENU button and go into the menu to turn the lock off. At least this is how it works on several other old Mitsubishi televisions. I don't have anything on ***********'s model, but this is worth a try. I hope it works for you.
Nov 12, 2008 | Mitsubishi Televison & Video
User Manual for (Dynex) DX-LCDTV19
Go to the Dynex web site. Type your model number in the search box and follow the link to the user manual.
May 23, 2008 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
