Question about Sony Walkman NWZ-W202 MP3 Player
Conditiom dead - Sony Walkman NWZ-W202 MP3 Player
Dead condition.. how to solve this problem
Posted on Nov 11, 2010
98.3hombre battery went dead after a jump it wont start
double posted, why?
JUMPS OK
AFTER JUMP WORKS AND DRIVING, AND STOP AND KEY OFF
IT WILL NOT CRANK.
did i guess right?
that means ,
check all fuses first. even the alt fuse (large)
1-battery bad? #1 top failure all cars.
2-Charge system bad. (is the charge/ batt warn lamp glowing when running car, bingo.????
3-or phantom drains. (if no crank just after stall then it not this) if drains while sleeping yes.
the tests are easy, a dirt cheap voltmeter
13.3v to 15v running is good charge system.
if 12v and falling not.
if the battery is bad, the charge system can shut down, so, the best practice is to try a know
good battery out of 2nd car, do you have battery to barrow, this is TOP CHOICE< not thinner wallet.
if the good battery fails then the charge system is failing (note I said system and not a part)
or the belt missing or slipping to the alternator.
btw the 4.3L PCM runs the alternator
PCM is engine brain.
btww, same true 2.2l engine.
the regulator is in the PCM.
so is the charge/bat lamp in cluster
on key on, lamp test
the jump start it , it runs
does the charge./batt.lamp go out.
id be all over that lamp, costs nothing to look.
Oct 09, 2016 | 1998 Isuzu Hombre
The maps ligth does not working
if it's a separate light from your dome lights the bulbs have probably burnt out check them to see if the filament is broke or the bulb looks black that's a good sign the bulbs are no good and need replaced
Nov 05, 2015 | 2003 Buick LeSabre
What it worth
You ask "what it worth" and show a watch so I guess you want to know the value of a watch.
The resolution of your photo is rather bad but it looks like aBulova Accutron. You are not specifying the materiasl, presume it's not gold. Depends how old is it - yours looks like a vintage model and if in good conditin, might have some value. I can't really appreciate it's real conditiom, photo is not favoring. I guess it should worth about 100 dollars but you should take it to a jeweller or to a pawn shop and get it evaluated.
TIP: Go to ebay and browse all those Bulova Accutrons on sale, if you see some simoilar to yours.
Aug 06, 2015 | Watches
INJECTORS ARE NOT WORKING
wow no year, are you kidding? and worse no car body. wow. x2.
what does not working mean, they dont squirt
or they lack 12vdc on one side and the NOID signals on other are dead.
all dead means. (no squirts)
1: blown fuse.
2: main relay dead.
3: the ECU wants them dead.
4: fuel pump dead or ECU wants it dead.
what does want mean.
want means. the ECU logic, halts injection for these reasons.
A: lost spark.
b: lost CMP or CKP sensors, which kills spark
c: cranking wide open throttle ,cancel injections for magic secret unflood mode.
so , why did you start (if you did) at injectors, they are last to work.
all the above most work for or the ECU cuts fuel.
the ecu cuts fuel to prevent CRASH and BURN, as seen on TV.
so you check spark and you got what?
good, ? one dead , all dead?
if spark is all dead, scan the PCM.
does it show, P0340/355 DTC errors, for dead cmp, or ckp>
that be first , top of list after fuse checks.
tell car , year, and all symptoms, ?car will not start and spark is ////???????????
Feb 12, 2014 | Toyota Cars & Trucks
Engine goes of when air conditiom is switch on
Depending on the make model and year, it could be a bad ac compressor.
Jan 21, 2014 | Cars & Trucks
I have laptop this is totly dead when i open this laptop how can posible
Dead AC adapter?
Dead battery?
Dead motherboard?
Dead CPU?
Take it to a qualified technician, for professional trouble-shooting.
May 14, 2010 | Dell XPS M1330 Laptop
Air conditiom blows hot air on passanger side
yur air handler could be bad on that side or if you have dual climate control the control for that side could be bad.
Mar 26, 2010 | 2000 Lincoln LS
Can't post
Probably a dead power-supply.
Maybe a dead motherboard.
Maybe a dead CPU.
Not likely to be dead video.
Less likely to be dead RAM.
Take it to a qualified technician for trouble-shooting.
Nov 14, 2009 | Compaq Presario 5000 PC Desktop
Sony Walkman NWZ-W202 MP3 Player Logo
266 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
