Question about Toshiba 6560 Copier
C7 Eror Code
I had a paper jam and know I am getting a C7 error code
  • 148 Answers
C7 Fusing unit not warming up properly. It can be the fuser is not in correctly, fuser connector not making good contact, defective thermistor, fusing lamp or thermofuse.
Hope that helps...
Posted on Jun 21, 2008
SEVER EROR 0X9010001
Was the error preceded by 81:01 or 81:11? That is the format for the actual error on a 500 series plotter.
If so then you have a Paper-Axis shutdown.
Corrective Action: If this error code appeared but was NOT caused by a paper jam, then try the following:
Carriage Belt if it is frayed or worn out, if it is good then
Replace the Encoder Disk Assembly.
Sep 22, 2013 | HP DesignJet 500ps InkJet Printer
Canon error jam
for this case you must call technician for chek it.
because the technician have to detail to chek it.
- position of paper.
- condition of paper.
Feb 27, 2013 | Canon CLC 1180 Copier
ERROR CODE E225
eror 225 relates to a paper jam. It might be a tiny tearoff, rather than a larger pice of paper.
Please rate my help++++Thanks for using FIXYA
Nov 29, 2009 | Canon LaserBase MF3220 All-In-One Printer
Digital Copier AR 5316E error code H4 indicating
An H4 code denotes a low temperature or temperature sensor failure problem with the fuser (the device that provides heat and pressure to bond the toner to paper). There may be a peice of paper or part of a peice jammed up inside the fuser that's blocking the sensor, or the fuser is defective and needs to be replaced.
Sep 18, 2009 | Office Equipment & Supplies
E 065 error code
change the composite power suply board
Apr 27, 2009 | Canon NP 6035 Copier
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
Wrench light on and c7 code appear
C7 is a Fuser Error......The hot part where the paper passes through before exiting the machine is known as the Fuser or Fixing unit etc.
There are 3 parts involved and any of which when they fail will give a C7 error code. The Heating Lamp,Thermisor or Thermal Fuse.
This is a live area of the machine so you wouldnt be advised to attempt a repair without at least a restricted electrical license.
More than likely one of the parts mentioned will need to be replaced and then the C7 error count reset through "08"
May 12, 2008 | Toshiba 1370 Black and White Copier
CANNON NP6025
E212 is scanner home position error.remove the platen glass. Check the scanner and lense assembly.
Sep 01, 2007 | Gestetner DSc224 Copier
167 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
