Question about Kenmore 24032\24036 Top Load Washer
My Kenmore 90 series washing machine model 110.4786291 does fill and empty but will not agitate. Is this a belt issue ? If not, wha t do you think is the problem and how do I fix it ? Thanks Susan
  • 113 Answers
SOURCE: Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Posted on Dec 17, 2008
RescueTech
  • 145 Answers
SOURCE: Kenmore Washer 110.26912690 series 90
Hi Norm. Welcome to FixYa.
The first thing to check with the kind of symptoms your machine exhibits is the operation of the lid switch. Make sure that the pin/plunger on the lid itself has not broken off, and check the actuator lever on the switch itself. It is REALLY common on your model for the actuator arm to break off or crack, and this will cause no spin/no pump problems. Your machine is built by Whirlpool and the part number for the switch assembly is a 3849238. You can get it at any local whirlpool parts center in your area.
I hope you find this info helpful and thank you for allowing us to serve you.
Happy New Year from the FixYa crew!
Posted on Dec 27, 2008
  • 262 Answers
SOURCE: Remove agitator on Kenmore 90 series
ok take the top off the agitator there is a cap carefully remove this cap and then some have a inner cap with a handle remove that also in side the agitator it has a 1/2" or 7/16" head bolt remove the bolt and then pull up really ******* the agitator. to replace dogs you have to break the taps holding them in not the agitator be careful
Posted on Jan 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 70 series washer fills w/H20, but doesn't agitate or spin
Fix it. Very easy fix and the part is not expensive. What you have is a direct drive motor. For ease of maintenance the machine is made in a way which makes it possible to service it in place without having to move it. You flip the controls up and pop the retaining clips in back, unplug the lid switch harness and tip the case towards you an out of the way. You can now access the pump, motor, and that pesky drive coupling. These do simply wear out but they usually will go if a comforter is washed in it or low water big load scenario.ea74271.jpg
I have videos repair manual,parts locaters and repair photos: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 14, 2010
Testimonial: "Thank you for the EXCELLENT & QUICK solution! Your repair suggestion along with instructions worked perfectly & saved us hundreds of $$! "
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 90 series Coupler replacement
It appears your coupling has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
My washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Jan 19, 2009 | Kenmore 24932 Top Load Washer
My Kenmore Washer Model 100, 90 series fills and agitates but
most common solution is to replace the lid switch. (the machine thinks the lid is still open)
Dec 26, 2008 | Kenmore 23822 Top Load Washer
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE
ck the drive coupling and the motor start windings
Mar 03, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
228 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
