Question about Xerox Phaser 4500 Printer
I have a Xerox Phaser 4400 (not 4500), and received the Code: U4 Fuser Failure message. Is the fuser something that needs relacement, and can I do this at home - or is tech required?
4 Suggested Answers
  • 2072 Answers
SOURCE: Fuser error code u4
You would have to replace the fuser to resolve that code.
Posted on Jan 06, 2010
elix0411
  • 3530 Answers
SOURCE: u4 fuser error for Xerox
Major causes of a U4 error include the following:
? Warm-up failure - Fuser warm-up not complete within 110 seconds after
starting.
? Cool-down error - Cool-down process not complete within 200 seconds.
? Low trouble temperature - The fuser temperature drops to the low trouble
temperature (approximately current control temperature, minus
approximately 25° C).
? High trouble temperature - The fuser temperature rises to the high trouble
temperature (approximately current control temperature, plus
approximately 35° C).
? STS circuit open
? STS failure - The heat rod remains on for at least 10 seconds after warmup
has completed.
You have to replace the thermistor in the fuser unit.
Posted on Oct 13, 2010
  • 54 Answers
SOURCE: Xerox Phaser 4500 printer has
From the Xerox Phaser 4500 Service Manual (here), the main problems could be one of:
  • Warm-up failure - Fuser warm-up not complete within 110 seconds after
  • starting.
  • Cool-down error - Cool-down process not complete within 200 seconds.
  • Low trouble temperature - The fuser temperature drops to the low trouble
  • temperature (approximately current control temperature, minus
  • approximately 25°C).
  • High trouble temperature - The fuser temperature rises to the high trouble
  • temperature (approximately current control temperature, plus
  • approximately 35°C).
  • STS circuit open
  • STS failure - The heat rod remains on for at least 10 seconds after warm-
  • up has completed
It could be that your fuser needs to be replaced, but as you can see that code relates to a couple of problems, so even replacing the Fuser might not fix the problem.
If it doesn't even do the warm up checks it is likely to be the fuser because the other components such as STS failure and cooldown won't have had a chance to run..
Posted on May 04, 2011
How do I reset error code u4 using the control panel?
error code u4 in xerox has something to do with fuser failure.you might have to replace fuser or take it to the nearest printer technician.
May 29, 2015 | Xerox Office Equipment & Supplies
Received fuser error u4-1. Replaced fuser, and still get same error
Try to hard reset your printer. To do this, unplug the cord at the rear of the printer while still powered on. Then remove it the plug from the socket. Let it sit for a few minutes. Then, plug the power cord and then reattach the cord at the back. The printer should power on itself, if not just power it on manually by pressing the power button.
Doing the hard reset should clear off any error messages from your printer's memory.
Feb 06, 2013 | Xerox Phaser 5500/DN Laser Printer
Code U4 Fuser failure - how much are fusers and can I replace myself or do I need a tech?
For the 4500, the fuser part number is 604K28532, iteminc.com has them in stock for $205, or refurbished using brand new rollers for for $185. here is a video that shows you how to replace it. Very easy with no tools required.
Aug 09, 2011 | Xerox Phaser 4500 Printer
Xerox Phaser 4500 printer has a U4 fuser code.
  • starting.
  • STS circuit open
  • up has completed
May 03, 2011 | Office Equipment & Supplies
Error U4-1000 (Xerox CopyCentre C116 copier)
U4-1000 Indicates Fuser on time failure
Follow these steps:
1. Check for paper on the fuser.
Y remove paper N proceed to step 2
2. Check the installation of the fuser assembly, make sure it is securely installed.
Y reinstall fuser N proceed to step 3
3. Remove the fuser. Check the conductivity of the contact points of the thermostat, are the contact points connected
N replace the fuser
Apr 12, 2011 | Xerox CopyCentre C118 Copier
Fuser error code u4
Jan 06, 2010 | Xerox Phaser 4500 Printer
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Oct 03, 2008 | Office Equipment & Supplies
My machine shows a U4 code
U4 code refers to a fuser heat failure, you'll probable find the fuser roll is stone cold .Possible cause is open circuit heater or overheat thermostat popped.Either way you will need to pull out the fuser unit and check continuity of the components
May 29, 2008 | Xerox WorkCentre Pro 423 Copier
487 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
