Question about NRS Hoveround MPV 5 - Used Power Wheelchair
Does my Hoveround need to be on or off when I plug it into the battery? Does it need to be on so that the lights show up on the joy stick or do you turn the chair completely off and then plug in the battery?
  • 692 Answers
Either way will work when charging the batteries and it wion't hurt the chair either way. If you can stand to have the lights scrolling all night when you charge the chair then leave it on If not turn the power off Your charger will tell you when its finished by turning the yellow light green. Hope this helps
Posted on Nov 12, 2010
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
Hoveround MPV4
Check your battery connections, make absolutely sure it is connected correctly.
Place a multimeter in the XLR plug (joystick). You should have around 26V reading if batteries are connected correctly.
Check the free wheel levers. place the chair in free wheel and move back and forth a couple of times. Place the chair back into drive, turn on controller and try to drive. ( This is not typically associated with a clicking sound but will ensure your brakes are not on)
If you are still hearing a clicking sound, it could be a problem with the brake or a motor. A qualified technician should really look at it for you.
Apr 19, 2014 | NRS Hoveround MPV 4 - Hovaround Used...
All joy stick lights stay on constantly. wheelchair does not move lights go out only if battery is disconnected
Hello.Hopefully this will help you.Any problem,please ask again.Visit-www.alldatasheet.com & download a troubleshooter for your product.Save it to your Adobe Reader as a PDF File + if you like print for future ref.I am disabled myself & know what its like to be stranded.Merry Xmas Colin.
Dec 16, 2010 | NRS Hoveround MPV 5 - Used Power...
Chair will power up, however lights just blink constantly. The joy stick will not work. Hoveround Teknique.
jfinch sorry it took so long to answer. If all the lights are blinking check to make sure that the freewheel levers are in drive mode. then check (if you have the power seat option ) that the seat is all the way down, and finally the problem could be in the controller check to make sure that the cable connection to the controller is well seated. If all these are correct and you still get the error then you will have to contact Hoveround tech support to find out what else you can do. They might have to send out a tech to look at the chair. Sorry I couldn't give you a quick fix Hope this helps you
Sep 26, 2010 | NRS Hoveround Technique Used Electric...
Used hoveround power chair
mcdevito75 here, The control switch could be bad, Contact Hoverround online at Hoveround .com You can also check with any Medixal Supply store in your area.
Jun 20, 2010 | NRS Hoveround MPV 5 - Used Power...
I have plugged the Soneil battery charger into the MPV4 Hoveround for over 24 hours. Although the indicator shows charging in process, the "battery charge indicator" shows it still requires a substantial...
If your Power Wheel Chair has been sitting idle for a while, the batts may need to be completely replaced. There is a gel inside the batts that need to have a current run through them via the charger on a regualr basis otherwise it will solidify. If the charger lights are onm you have connected the charger correctly for over 24 hours and the batteries are still not showing they have been charge, there may be damaged cells which means both batteries need to be totally replaced.
Nov 01, 2009 | NRS Hoveround MPV 5 - Used Power...
I own a mpv-4 hoveround,when iam moving forward it wants to pull to left.i have to hold joy stick a little to the right to go straight.is there a adjustment that i can do myself?i have very low income!
Make sure that your tires are both inflated to 45-40 psi, have good tread and are not leaning on or out of the frame. Were both of your batteries replaced at the same time? Is there any noise or vibration coming from the motors that may indicate one has less power than the other? You may want to check the bearings in the casters to ensure they can move freely. I hope this helps!
Sep 23, 2009 | NRS Hoveround MPV 5 - Used Power...
Hoveround MPV4 Just quit
make sure the connectors at the batteries are not loose and battery fuse is plugged in all the way
Jun 19, 2009 | NRS Hoveround MPV 4 - Hovaround Used...
Wheel chair will not respone to any of the joy stick controller
I don't know if you got my answer. I just had this problem with my Guardian Aspire chair. They had to replace the electronic box on the armrest with the joystick. This is a BIG BUCK problem!
Mar 12, 2009 | NRS Hoveround MPV 4 - Hovaround Used...
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
188 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
