Question about Kitchen Ranges
Have a model KB3300JS Sharp Insight electric stove with the built in drawer microwave. I am wanting to change the handle on the drawer microwave and cannot find any assembly information on how to remove the handle. can you assist? part number is JHNDPB052MRMO
  • 1 more comment
  • mo1912 Nov 11, 2010
    thanks for the info. have been to this site and it does not give me a good disassembly drawing for me to remove and replace the drawer handle.
    Thanks again.
    does the back of the drawer just snap in as i do not find any method of attachment other than the 4 screws below the drawer for the SS face?
    Mike O
  • Anonymous Mar 12, 2014
    This is an above stove built in microwave model # nn-s253WF
    Genius:
  • 1,456 Answers
Hello
Most people think that replacing a microwave door handle simply involves unscrewing the old one and mounting a new handle. The process is a bit more complicated than that.
Unplug the microwave oven from its power outlet or turn off its circuit breaker.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Posted on Nov 18, 2010
  • 421 Answers
Can your microwave work without mica cover?
It can be, but it's not recommended. Food can splatter and get into the waveguide and cause problems. Also if you reach in there with your finger right after the microwave stops, you can get a severe shock (until the capacitor discharges, usually in about a minute). Also the edge is sharp.
Nov 07, 2014 | Sharp KB-4425LW Insight Pro Electric...
Sharp KB-6524PS no power
There probably is a fuse inside but replacement depends upon your degree of comfort with disassembly while maintaining awareness of the dangerous voltages lurking inside.
Jan 14, 2014 | Sharp Insight Pro Series KB-6524PS 24""...
Fixya com
Please post a new help request here on FixYa and include the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc. and detailed symptoms and when they occur.
Apr 30, 2013 | Sharp Insight 30" Stainless Steel...
Drawer tries to close and then opens
I would suspect that a foreign object may have gotten in the pathway of the drawer, the drawer actuator is out of adjustment, or one of the door sensor switch is damaged, defective, or off its mount.
The service manual is at our site here.
You can order Sharp parts from Encompass here.
Nov 02, 2012 | Sharp KB6024MW Insight Pro 24" Built-In...
Where can I buy a Sharp drawer microwave in the UK?
Hi
You can check out these links to buy Sharp Microwave in UK:
Link 1
Link 2
Hope this helps...please post back for further assistance.
Daniel
Mar 18, 2011 | Sharp Insight® KB-6002 1000 Watts...
Sharp insight glass ceramic cooktop, with a cracked glass. I need to replace the glass ceramic cooktop. Model kb 3300 js .... serial 112895. Will be shipped to Puerto Rico.
You can buy the substitution replacement part at searspartsdirect.com for $711.99 (price on 1/29/2011). This is a manufacturer authorized substitution part. I pasted the note about those. We need to purchase one too, but are searching for something less expensive. If we are unable to locate a less expensive option we will probably just buy a new stove, because the replacement cooktop costs almost as much as we paid for our unit when it was new. We are looking at a possible part from sharp for another unit which maybe compatible...if it is it would be $296 before s/h, etc. That is a better price, but still more than I would like to pay for a piece of ceramic glass.
Manufacturer authorized substitution: FANG-B022MRY0 may differ in appearance, but is a functional equivalent to prior parts including FANG-B001MRY0.
Glass assemblyNumber:FANG-B001MRY0Substitution:FANG-B022MRY0
Jan 15, 2011 | Sharp KB3300JS Stainless Steel Electric...
Sharp Insight Range with Microwave Drawer in Stainless steel
FIRST DISCINNECT POWER........ If you can access the sides of the unit, look for a small cover on one of the sides. open it, a look for fuses. Replace with the exact fuse you took out. DO NOT ATTEMPT TO OPEN UP MICROWAVE IN ANY OTHER WAY!!!!!! Components inside that can shock/kill you.
Apr 05, 2010 | Sharp KB3401LS Stainless Steel Electric...
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
How much is a KB3300JS Cooktop replacement, and do you guys sell them?
Go to searspartsdirect.com and type in KB3300JS and you will get schematics and part numbers for product. They no longer make the original part, but Sears sells the substitution part for 711.99 and has it in stock as of today 1/29/2011. We need a cooktop too since ours is cracked, but we are still looking for a lower priced replacement or we will probably just buy a new stove because by the time we fix the two parts we need to replace we will have spent the same amount of money to buy a new stove. I hope this helps, because it was hard tracking down this information. Glass assemblyNumber:FANG-B001MRY0Substitution:FANG-B022MRY0
Dec 23, 2009 | Sharp KB3300JS Stainless Steel Electric...
Kitchen Ranges Logo
91 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
