Question about Black & Decker Leaf Hog Blower Bv4000
Change from vacuum to blower - Black & Decker Leaf Hog Blower Bv4000
After fixing blower motor it only blows out defrost
some a/c / heater actuators are controled by vacuum vacuum line may be pinched or broken when you did your repair,diesels have vacuum pump that suply vacuum for differant things,because diesel engine can not produce vacuum it self.if vehicle happens to have electric acuators then something may have been left unpluged or you may have blown a fuse
Aug 01, 2012 | Dodge Cars & Trucks
Older leafhog don't know how to change over to blower instead of vacuum model Bv2500
Remove the vacuum tube completely from the bottom of the machine and make sure the impeller cover closes completely. Remove the collection bag off of the blower outlet. Now attatch the blower tube to that outlet on the blower. Done.
Dec 07, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
I can not get the Leaf Hog to swtich from vacumn to blower. Any suggestions?
it does not "switch"
The air intake becomes the vacuum with an attachment. The "blower tube" is then the vacuum exhaust.
the motor does not change directions.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 27, 2010 | Black & Decker Leaf Hog Blower Bv4000
How do you attach the vacuum attachment to the blower. please send picture !
Look at the very bottom of the unit. See the vented spring loaded cover where the air is drawn in? The key is the "air is being drawn in". This doesn't change whether the machine is blowing or vacuuming. It HAS to draw air in as quite frankly every machine uses air to cool itself and operate..including computers. Open the vented bottom to the machine and insert the large vacuum tube there. You may have to twist it into place. Now where the blower tube is...take that off and attatch your collection back to the tube outlet on the machine. Done.
Aug 20, 2010 | Craftsman Blower Attachment
How do i change black and decker leaf blower to vacuum
you have to remove the plate that covers the fan bla des intake than witch hoses some covers are spring loaded and just flip up
Apr 22, 2010 | Black & Decker Blower Vacuum Mulcher 1 Ea
Blower not working
If the blower motor resistor is bad, the fan will run only on the high speed setting. In your case, you state you have no air coming from the dash vents, indicating that the blower is working. The control of air flow is done with vacuum-operated baffles that steer the air to the different possibilities. If it isn't changing with your different settings, you may have a broken or loose vacuum line or the very frail fitting on the vacuum reserve tank is snapped off - have seen this on GM stuff before.
The tank normally a cylindrical device 6-8" across and high. it should have two small fittings on which there should be vacuum lines. It is often located close to the firewall.
May 20, 2009 | 1994 Chevrolet Lumina APV
Blower motor in 1993 dodge dakota
u must have knocked the vacuum hose off when u changed the motor, that (vacuum) is what moves the air to the different outlets, the vacuum comes from the engine and enters the cab on the passenger side..
May 12, 2009 | 1995 Dodge Dakota
2003 F 550 blower fan quite how do I change it
If it's the blower motor,the vacuum pump has to be moved out of the way(10 mm bolts) . There are three or four 8mm bolts holding the motor in place. make sure you have power and ground to blower motor before replacing.
Feb 02, 2009 | 2001 Ford F350 Super Duty SuperCab
B & D leaf hog (blower/vac)
Check an see if a branch or something got caught in the blower an won't let it turn, if it hums that could be the problem
Nov 11, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Black & Decker Leaf Hog Blower Bv4000 Logo
182 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
