Question about ASUS Eee PC 1000HE Netbook
I have a grey startup screen with "Press F2 to run
  • ASUS Master
  • 5,317 Answers
Hello hyjacker this post and OPS other identical post on why F2 repeats, this is COMMON !
first take out that relic and bad large battery.
run on AC pack only, still dead?
http://pcdied.com/dead-PC.html
the PC is now 9 years old
the RTC COIN CELL BATTERIES, mostly do not go past 7 years, seen 10 happen, but is not PAR,
life span is 5 to 7 years.! facts.
so replace that first,
then reset bios next.
and test on AC Pack only, until the PC runs right again do not use the useless 9 year old HUGE BATTERY, oK?
then make sure boot order in BIOS
shows HDD , in the list.
or the HDD is dead.
the coin cells dead will cause many PC
to stick at BIOS screens, after all it cant find the boot order configurations with that battery dead.
once that is cured, you can boot windows
if the HDD still works.
on some pCs you can hit F2 and it loads BIOS defaults and boots.
but after powering down, all that is lost and all this above repeats.
the service manual on your PC covers this.
but I can not find that manual anywhere...
how to replace your RTC Coin cell.?
here it is, remove any hatches to reach it.
RTC is on the bottom
see yellow blob this is your exact mobo.
this is the bottom side of mobo
open hatches on bottom of PC to gain access.
I see 1 huge hatch in our manual, at asus.
no 2 laptops are the same unless they are exact model. so learn to find it using below photo.
Posted on Nov 05, 2018
  • 1 more comment
  • Anonymous Nov 05, 2018
    are not photos so grand,
    and manuals on this PC.
  • Anonymous Nov 21, 2018
    the PC fails so boot windows,
    and stick on the BIOS main pages, or shows hit F2, to enter setup(means bios)
    that means the HDD can not boot.,
    for 3 reasons.
    1: Coin cell is dead.
    2: hDD is dead,
    3: OS on HDD is corrupted.
    the photo shows the top side, I think
    and shows rear on bottom of photo
    that large black connector on the rear is huge battery connections.
    the hole on right is fan.
    the yellow is mr, RTC COIN CELL.
    my wild guess is remove keyboard to get to it.
    I now show top with keyboard out
    my guess is one of 2 lower right cut out
    squares are RTC access one can hope.
    keyboards come out by 2 ways.
    1: just bottom screws
    2: or that and what I call tickle locks on top edge of keyboard, unlock those and out it comes. (or like my HP has BOTH)
    there is no rules here, all LAPTOPS are different, no standards exist, on servicing.
    that is way a service manual is a joy.
SOURCE:
nonontech
  • 4737 Answers
SOURCE: I was told press F2 simultaneously on startup, nothing happened
You need not to press F2 or tab or escape unless you need to do so. If your system is ok, it'll automatically boot up, but if there's boot up problem with your system, then that's different. Thanks for using FixYa.
Posted on Jun 06, 2010
nonontech
  • 4737 Answers
SOURCE: Computer does not start up
Please reset the system... Disconnect the power adaptor. Remove your battery, press several times on the Power button of the Laptop without the battery and power.. and let me know.
  • 340 Answers
SOURCE: ASUS Eee PC 1005 HAB
It seems something wrong with the Hard disk, remove the Hard disk and memory card and reset them, then start your computer,,,If doesn't work, try more times, remove graphics together is better
Posted on Jan 10, 2011
  • 107 Answers
SOURCE: when i turn on my eee pc i get the message "Press
Please pull out your hard disk and put it back after 10 seconds. Your laptop will be start as normally.
Thanks
Posted on Jun 27, 2011
  • 382 Answers
SOURCE: I have an Asus Eee
My suggestion is better to send it on the technical around on your area, to prevent any further damage. And also backup your files by removing your hard disk and slave it to other computer. Just use any converter of mobile hard disk to become a USB type drive. Hope it helps thanks.
Posted on Sep 21, 2011
Press DEL to enter Setup, Press TAB to display BIOS POST message
to install window7 just put dvd in tray startup computer do what it says to do asn question
Jan 25, 2013 | ASUS M2V Motherboard
Asus Eee PC 1005HA wontl load OS
what key do you see during the boot up process
you should see a certain key it will be very quick you might have to restart a few times to get a good look
try pressing the delete key
hope it helps
Apr 09, 2012 | ASUS Eee PC 1000HE Netbook
I have an Asus Eee PC 1001ha series, with Windows XP. Whenever I turn it on it displays the grey asus screen with the phrase "press F2 to run Setup, Press TAB to display BIOS POST Message",...
Sep 21, 2011 | ASUS Eee PC 1000HE Netbook
When i turn on my eee pc i get the message "Press
Thanks
Jun 27, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Ok so my netbook goes to a blue screen where it says " press f2 to run setup, press TAB to display BIOS POST message" and stays there. if i push f2 then it goes to a black screen where at the...
Probably the hard drive is dead. Did you drop it recently? Anyway, it could be just the connector, if your good with hardware you could open it and check. I would suggest you to use the warranty though.
Mar 03, 2011 | ASUS Eee PC 1000HE Netbook
ASUS Eee PC 1005 HAB it won go after the "press f2 to run setup, press tab to display BIOS POST message" screen. When i turn it on it makes a sound inside the computer for like two seconds after...
Jan 10, 2011 | Computers & Internet
Hi, I have a netbook running Windows XP. When I start it up it has a white screen with the manufacturer name, at the bottom it says "Press F2 to run setup, Press TAB to display BIOS POST...
I'm afraid that you'll have to get some installation disks for an operating system and boot from it using an external DVD drive (for Windows 7 for instance). If System Recovery doesn't proceed, that's the only way I know to load an operating system.
Dec 18, 2010 | Computers & Internet
Jun 06, 2010 | ASUS Eee PC 1000HE Netbook
BIOS POST message cannot be displayed and Setup does not run
As soon as your computer turns on, start pressing F2 simultaneously until it enter the CMOS setup.
ASUS Eee PC 1000HE Netbook Logo
330 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
