Question about Xerox Office Equipment & Supplies
Our Xerox 3030 is making a loud thumping noise when it is making copies.............We know it is coming from the belts on the gears on the right hand side. Any Ideas?
    New Friend:
  • 51 Answers
It may be full of waste toner
Posted on Dec 12, 2010
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
Xerox grinding noise
the bearing on the motor or the rotating path must have damaged..
replace them
Jun 02, 2008 | Xerox WorkCentre Pro 215 Printer & Copier...
Growing noise in front end of Volvo s60
sounds like a wheel brg, if the noise lessens when you turn to the left while driving more than likely it is coming from the right side, but a brg makes more of a roaring noise.
Jan 09, 2012 | 2002 Volvo S60
My xerox Phaser 6130 is noisy and makes light copies. How do I lubricate it? Will this solve the problem?
The 6130 is not designed to be lubricated, but if you feel the need to lubricate gears, then use white lithium grease. I am not sure the nature of your noise. Loud rattling or repeating ticks could indicate damaged gears, and lubrication won't help that.
Often the Image Unit causes noise and bad print quality. Try replacing that first, PN 675K69244.
Whit
Nov 15, 2010 | Xerox 5665 Copier
OUR XEROX COPY MACHINE MAKES A SQUEALING NOISE WHEN MAKING COPIES
On this model most squeeling noises come from the fuser assembly.
If it is that loud replace the fuser assembly.
Other known prolbems is with the fuser fan in the back.
To see if it is the fuser fan, take off the back cover.
When the machine makes a copy unplug the fan very momentary. See if the noise goes away.
If the noise is still there, then it is possible the fuser is causing the problem.
Make sure the correct fuser is installled on this machine model.
Oct 21, 2009 | Xerox CopyCentre C20 Black and White...
2005 expedition rear a/c makes thumping noise when transferring
Sounds like the roof/floor actuator internal gear is stripped. The only way to fix it is to replace it. Remove the cup holder in the right rear trim panel. remove the 8mm bolts holding actuator and replace.
Feb 01, 2009 | 2005 Ford Expedition
Front differential making a winding noise and ends in a loud thump.
sounds like you need your transfer case looked at and repaired.....that the only thing i can think of...hope it helps :)
Sep 30, 2008 | 1994 Chevrolet S-10 Blazer
XEROX WORKCENTER XD100 NOISE
Most likely the fuser gear is worn. The noise is prominant in the right side toward the back I am assuming.
You can replace the heat roll drive gear itself, but honestly I would recommend replacing the entire fuser assembly. It is probably very very tight and would wear another gear out quickly.
You want to get that replaced before the drive gear on the main motor assembly wears out. It would not rewuire replacing that entire main drive assembly, But it is a real difficult part to replace.
Go onto google and do a search for The Parts Drop. It will be the first item to come up. CLick it on and call and talk to Britt.
He will have what you need for a reasonable price.
if you go that route and need instructions to replace that part. let me know. Its not very difficult.
Jul 16, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox Phaser 7700DN color printer
I would be willing to be it's one of two things.
Most common is a jammed gear on the imaging units. Remove all imaging units CMKY. The turn on machine. If the noise is gone, start replacing imaging unit one at a time tile noise reappears. Replace defective imaging unit.
If that doesn't work remove the accumulator belt from the right side of the machine and then turn machine on, see if noise is gone. If so replace accumulator belt.
May 16, 2008 | Xerox Phaser 7700DN Laser Printer
118 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
