Question about Philips SACD1000 CD Player
P ower button pushed ,no display or red light, relay tries to click.i took cover off removed screws from first board and cover from disc transport .plugged in and it played disc.i put it back togeather and again it will not play.i have always had trouble with machine.rebooting used to fix problem. sacd 1000
  • Philips Master
  • 6,993 Answers
your player is having a power problem. One or more component(s) on the power board of your player is defective, that's why its turning off.
This problem may have occurred as a result of power surge or excess power entering into the unit or irregular power supply.
If you know about electronic repairs, get a meter, use a screwdriver to open the player so that you can gain access to the power board. Use the meter to read the power board and replace any bad component detected.
Once this is done, your player will stay on and function normally again.
All this while, the machine has been giving you sign.
Good luck.
Posted on Nov 11, 2010
How do I unlock the panasonic 5 disc player. drawer will not open
In the first decade of CDs, there used to be transport screws on the bottom cover to keep the mechanism from banging around during transporting. They used to be painted in RED to make them stand out to the customer. Someone mentioned on another question, that there was a hole in the bottom, that had to be to pushed in to release the mechanism. That may be a more precise answer than mine, in these current days. When I worked for the manufactures, a project engineer told my that the difference between profitable or non profitable on a product may just be the difference in pennies(the cost of those RED screws)! If you need more assistance, please visit my website at audioserviceclinic.com.In addition to that, the information you seek, is probably in your owner's manual.
Nov 24, 2014 | Panasonic SC-HT720 System
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
I have a wii balance board, the batteries ran out so i changed them -now the board will not work. Ive tried pressing the red buttons together but still no joy. my neighbour is having the same issuses. Why...
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete
click here to download repair guide if u need
Dec 17, 2010 | Nintendo Wii Fit - Balance Board + Game...
Wii balance board power light does not stay on,screen says push power button w/ your foot i do and a blue blinks a few times and the screen stays the same
You need to Sync it first.Open the SD Card slot cover on the front of the Wii console, just below the disc drive, then push the red button there, then open the batteries cover on your Wii Fit and push the red button there.
Nov 09, 2009 | Nintendo Wii Fit for Wii
Wii fit board - blue power light flashes then goes off and wont work. This is also happening to my parents one and we are both on our 2nd wii fit board each. Have reset red button but no joy - help please
Unplug the AC adapter from power cord then wait 10 min and plug it again.Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.Then push the red button again, then open the batteries cover on your
Wii Remote and push the red button there.After that push the red button on console one more time, then open the batteries cover on your Wii Fit and push red button there.If this not help may your wii fit need service.
Nov 02, 2009 | Nintendo Wii Fit for Wii
The red exclamation mark and the green setup light remain on.
I experienced the same problem several years ago and tried the suggestion provided below. It worked and it is still working today.
Here are instructions posted by John Phillips on "FixYourOwnComputer.com:"
Steps I took - and it worked beautifully - display problem solved !!
1. Ease off the plastic facia that covers the control buttons - (no screws - it just clips on)
2. Remove the cross head screw that is seen to the bottom left of the display unit.
3. Flip display unit open - remove the cross head screw that holds the dark plastic support clip that is behind the unit and top right ish!!
4. Remove the display unit - unscrew the 4 small cross head screws that hold the display assembly together - NOTE THAT THE CONNECTING RIBBON RUNS THROUGH THE HOLE - I didn't make a note at first, and it took me ages to work out where it went when trying to re-assemble it !!
5. Mark the connecting ribbon so that you know which way up it should be, then carefully pull it away from the black connecting block - Re-assemble merely by pushing it carefully back into place.
6. On the circuit board you will see a large (ish) black Integrated Circuit - using a magnifying glass you will see a tiny soldered fuse marked F1 just to one end of this Integrated Circuit.
7. Using a single strand of clean copper wire ( a single strand taken from a multi strand piece of speaker wire is ideal) carefully solder it across the two terminals
8. Having a soldering tip small enough is vital if you are to attempt this - an ordinary tip is TOO BIG. I used a piece of copper earth wire (obtained from ordinary "Twin and Earth" electricians household mains wiring cable) I then wound it around my soldering tip and filled it down to a fine point.
9. Re-assemble - switch on - and if you have been careful and succeeded in this feat of micro soldering - you should have a realistic chance of having a fully functioning display once again.
Jan 08, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
System wont load or eject any discs...
Remove the disc drive from the console. Remove the cover very carefull. Take the top part off (remove the 5 screws) and open the disc drive like a book.
Carefull remove the guide mechanism (the front part -1 screw).
The clicking noise is caused by the fact that the left side mechanism that raises and loweres the deck when the disk is inserted or ejected is stuck. Carefull push back the piece of plastic with teeth located on the left side of the deck (as you are looking at the disk drive the oposite side with the lens driving motor) until it clears complete the plastic round gear that drives that part.
mount back the guide mechanism, and the top part.
Attached the ribbon cables to the unit , power the console and keep the eject button pushed for about 10-15 seconds.
That will reset all the gears and stuff.
Worked for me when I experienced that issue.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Power Button does not push in and out
http://www.richspsxparts.com tells you how to disassemble the game console and replace the old switch this also sells new switches
Jan 21, 2008 | Sony PlayStation 2 (PS2) Console
42PF9956/37 SHUTSDOWN...
Ok. I got my tv back on.
I pulled off the back cover and found the relay that was clicking.
I have two blue relays next to each other that click when the power is pushed.
I placed a hair dryer over the relays for about a minute.
Once heated up, it only took 4 tries to get the TV to stay on.
Jan 03, 2008 | Philips 42PF9956 42 in. HD-Ready Plasma...
42pf9956/37 philps plasma
I don't know why but this got my TV on.
I took off the back cover and found the source of the clicking.
Two blue plastic rectangular relays in the exact middle.
When I pushed the power button, I felt the top relay click, and I saw a flash from the bottom one. (they are right next to each other)
I took a hair dryer and placed it over the two relays for about 1 minute and tried the power.
It clicked only 4 times and then came on!!!!!!!!!
For some reason heat helps the relay.
If anyone is a tech and can explain this, please do.
Good luck!!!!
My tv is on and it didn't cost me anything.
I just can't turn it off now!!!
Sep 25, 2007 | Philips Magnavox 42MF521D/37 Television
Philips SACD1000 CD Player Logo
96 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
