Question about Samsung Televison & Video
Samsung DVD recorder R150 won't recognize blank discs or discs that the unit has already recorded. When you put a disc in it will eject it and say that disc can not be played. Unit will play discs that are pre recorded. Any advice would be appreciated.
SOURCE: DVD recorded discs (from VHS) do not play on other dvd players
I called the manufacturer. They admitted to improper instructions. They provided me a fix to their copying protocol and it worked. Also, they game me instructions on how to fix already copied tapes. It works well and I would have to say I was impressed with their customer/technical service.
Posted on Dec 27, 2008
  • 6966 Answers
SOURCE: dvd will not record
Hi and welcome to FixYa,
Initially, try to clean the lens using a CD disc cleaner. Additionally, verify that your blanks are either DVD-R or DVD-RW.
Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 17, 2009
  • 371 Answers
SOURCE: Won't recognise DVD disk.
Your system needs a portion of the HDD to swap and stream for the purpose of playing and recording DVDs while CDs are small enough in their data size to play without the minimal size of the space left on your HDD which should be backed up and then erased to give you that brand new feeling.
Try it and get back to me with any problems.
Thanks for asking.
Please Rate.
Posted on Apr 22, 2009
SOURCE: Recorded DVD will not play in another player
if you record something in VR format, then it wont play in your dvd machine despite what kind of dvd you use. You need to record in "video format" if your camera supports it. Problem with that then is you cant edit or delete scenes. Also you must finalise your dvd before sticking it in your dvd machine in order for it to play. You can unfinalise it later if you want to add more stuff to the dvd.
I bought a samsung dvx100. I am using dvd-RW disc and am restricted to recording in video mode only. If I record in VR MODE it wont play on dvd machine :( so i cant edit or delete now either.
p.s dont forget to finalise the disc.
Posted on Apr 25, 2009
SOURCE: Will not read blank media so that I can record.
i have this model and the problem was the speed of disc you need itcant be any faster then 2x. the 4x is to fast for it i guess. I was doing ok with the "memorex DVD-RW reritables 2x ,4.7gb,120min.
Posted on Jul 18, 2009
Re DVDR pot tweak: 2 potentiometers on my Samsung DVD-R150 are labelled 'VR20High' & 'VR19Low', can anyone tell me 1 which is the DVD pot and 2 whether to turn the screw clockwise or anticlockwise?
if you have moved them needs an ohmn meter or osilloscope
they both a very narrow range so cant do much wrong by tweeking
i cant find anywhere to buy those two pentimeters in 2017
they could be dust effected
note where they are positioned
put both in the middle position and gently move them back and forth
then back to original position
Apr 16, 2017 | Samsung Televison & Video
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
Unit does not recognize DVD-R and is ejected from the player
You may need to try a DVD+R disc. Some of the players/recorders are REALLY picky.
May 17, 2010 | GoVideo Go Video DVD/VCR Combo
When I put a DVD-R into the DVD-R 155 recorder to copy a TV program after a few minutes of the blue disc at spinning at the top right of my TV screen the disc is ejected with the message 'disc cannot be...
This is a Samsung DVD recorder - I've had the exact same problem - By the way, don't you mean "this disc cannot be recorded" ? These DVD recorders are known to reject certain type of discs.
* Have you updated your Samsung with the latest firmware ?
Follow the instructions carefuly and please understand the risks involved in flashing your drive - Do not interrupt the process, it can take long.
* here are the brands of DVD-R I have used successfuly with this recorder int he past:
Taiyo Yuiden DVD-R 4x / 8x (the optical drives used in those recorders are outdated, their writing strategies are never up to date and may not recognize some type of discs)
Maxell DVD-R 4x / 8x
Verbatim DVD-R 4x / 8x
Try another blank disc - maybe it will accept it - if it keeps rejecting all your blank DVD-R no matter what brand, you have a bad drive inside your recorder - the samsung recorders are **** - I have ever since gotten rid of that piece of **** and now use a Sony HDR-780 HDD/DVD recorder, uses pioneer components and is great !
Avoid those lens cleaners - they can do more harm than good!
I hope this helps.
Try different brands of DVD-R, avoid the cheap generic **** - drives like best Taiyo Yuden & Verbatim media id codes - they should recognize Maxells, verbatims, sony, taiyo yuden, ritek. if it keeps spitting out all discs you use, you have a defective unit. The latest firmware on that drive should also help !
Good luck :)
Aug 22, 2009 | Samsung DVD-R155
Ok, Firstly it sounds like you have reasonable knowledge on what you're doing.
But just to clarify a few things.
1.You say you have tried a couple of different brands of disc.Unless they are of good quality
or compatible with your machine they may not work properly.Try TDK or Verbatim for example.
Also make sure they are DVD-R or DVD-RW.
2.If no blank discs are successful,then you may need to clean the laser lens thoroughly.
I know you said you cleaned the lens,but was this with a lens cleaner disc?
If so it will only remove dust not built up grime from other sources such as smoke from cigarettes.
This would entail taking the cover off the unit and cleaning the laser lens directly with a
cotton bud dipped in cleaning fluid.If you are not confident in doing this,then you
would need to get someone qualified to do so!
I have gotten many DVD Players and DVD Recorders working again doing this.
May 20, 2009 | Samsung DVD-R130 DVD Recorder
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Dvd will not record
Jan 16, 2009 | Samsung DVD-R130 DVD Recorder
Can anybody help me, I purchased a Samsung dvd recorder model dvdvr350m, since purchasing the unit it will not recognize that it has recordable dvd's in it (dvd-rw),it tells me no disc inserted please...
Did the sales guy use the same DVD-RW that you did? Maybe the brand you are using is not of good quality and can not be recognized by the recorder. If he did not use the same disc did you notice if he used DVD-RW or DVD+RW? Some DVD-Recorders only recognize one or the other but this is kind of rare these days. I recommend verbatim brand discs. They should be available for sale at any shop. If you want the ultimate in quality DVDs then go with Taiyo Yuden. This Japanese brand invented recordable media and in addition to that they are obsessed with quality. is always where I get my discs.
Thanks for reading!
Hope this was helpful
Apr 30, 2008 | Televison & Video
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
