Question about Samsung PPM42S3 42 in. Plasma Television
Use of HDI-V input on PPM42M5SBx
Hi, I was wondering if i could run a VGA input into the DVI-D jack, the VGA if from a laptop computer. Will the DVI-D jack work with the VGA input?
Thanks
Greg Magriplis
321-476-2619
    Problem Solver:
  • 16 Answers
The answer is no as VGA is a analog connection whereas the DVI connection is digital just like HDMI.
A DVI input on your display wont understand the analog signal and vise versa, hope this helps
Posted on Feb 26, 2009
No signal
Press the Function Button to open the short cut menu. Locate the Input graphic and press the button for it. Each time you press the button, it will cycle between DVI and VGA input jacks. Allow a few seconds for the display to switch inputs. Make sure that cable is connected securely to the associated jack in the back of the monitor and the computer (or other source). If either VGA or DVI input is selected ,but the VGA and DVI cables are not connected, a floating dialog box indicates:
"No Cable Connect" or "No Signal"
Your manual can be viewed here:
http://www.manualslib.com/manual/268264/Acer-S201hl.html#manual
Apr 07, 2014 | Acer S201HL BD Refurbished LCD Monitor
I just want to know what kind of cable I need to connect my LTV-37w2HD TV to my computer?@highes.net
The video cable should be a VGA cable, assuming your computer has a VGA connector. Get one that has M/M ends. This is sometimes listed as a 15 pin D-sub connection. Then connect a 3.5 mm audio patch cord (m/m) between the audio out (speaker/headphone) pf the computer to the TV's VGA audio in (if you want to use the TV speakers).
If your computer has an HDMI or DVI output, I do not believe that you can connect to the TVs HDMI port. (The signal from the computer is not the same as that from a set top box.) If you have a DVI port, get a DVI to VGA adapter and then connect to the VGA cable. (You could use a DVI-DVI cable and then the DVI to VGA adapter at the TV. However, space is an issue at the TV.)
Make sure that the VGA port is enabled on the computer. (Some newer computers have a different video port enabled initially.) This may require entering your BIOS just after turning on the computer. Usually you need to strike Esc, F1 or F2 repeatedly starting when you press the power button. (F10 is also a BIOS access with some manufacturers - the key will be listed in a splash screen that is only visible for a few seconds.)
With the computer and the TV off, connect the cables. Then turn on the TV and set the input to VGA. Next turn on the computer. (If this is the only monitor attached, the computer should find the correct resolution (Windows). If you are using a dual monitor option, then you may have to enable the TV as a monitor. This will depend on the OS. For my Windows 7 laptop, it's right click on the desktop and choose Graphics Properties. Set the monitor options for both, external or attached and click Apply. Then click OK when a confirmation window appears. With my Windows 7 desktop, it's right click on the desktop and choose Screen Resolution. Similarly choose the settings, click Apply then OK to confirm.)
I hope this helps.
Jun 02, 2011 | Westinghouse LTV-37w2 HDTV
My DVI has no signal but my VGA does! what do i do? Please help me!!!
Your HP2009M monitor supports (3) methods of accepting signals from a computer. They are: 1) VGA, 2) DVI and, 3) HDMI.
You would connect the computer to the monitor using one connection only. Generally the VGA is the least desirable as it is an analog signal. The DVI and HDMI method provide digital paths into the monitor and often perform better. Your computer may only offer 1 or 2 connection choices, so you'll have to choose a cable type that is supported by both the computer and the monitor. The HDMI choice will pass audio signals to the the speakers in the monitor without needing to run a second cable between the stereo audio jack of the computer and the audio input jack of the monitor (located next to the HDMI jack) or to a set of external speakers (unless of course you prefer the external speakers).
The message you're seeing is normal. Once the monitor is connected to your computer, there will only be one active selection; VGA, DVI or HDMI. Since you're using the analog VGA jacks and cable, it is expected that you'll see a message that there is no signal present on the DVI (and HDMI) inputs when attempting to view signals on other inputs.
I hope this helps and good luck! Please rate my reply, thank you.
Feb 26, 2011 | HP 2009M Monitor
How do i connect to an hdtv ?
You're going to need to connect a cable supported by BOTH the PC and HDTV. Check your HDTV's jack panel or manual. List the types of Input jacks it offers. The HDTV will likely have Component, Composite, DVI, HDMI and maybe even VGA jacks. Do the same for your PC. It likely has one or two Video Output jacks. Typical Video Outputs are DVI and VGA. The VGA type has been standard for years. It consists of a total 15 pins in 3 rows. The DVI has a number of pins, but most noticeable is a wide tab at one end of the jack.
If your HDTV has a jack that matches one of those found on the PC, you're in luck. Purchase a cable that will connect them - this would be either a VGA cable or and DVI cable. Nearly any inexpensive VGA or DVI (Digital Video Interface) cable 6 ft or less will do, but the better cables cost a bit more and when the distance is increased, the quality (or lack thereof) really becomes visible - especially on the lager HDTV screens.
If you want the sound to go to the TV speakers or elsewhere, you'll need to get a cable with a 3.5mm stereo plug (or whichever type your PC has - but that's the most common) to RCA or whatever the audio input jack type is that is associated with the video input you chose. The audio input must be the one associated with the video input - other wise you will not hear the audio on input 4 while watching input 3. The PC audio out is analog, so do try to put the signal into a digital input.
If you don't have a matching video input jack, you'll have to purchase an adapter or new video card with jacks that match your TV. Do not buy simple adapters that change VGA to DVI as they will not convert the actual analog VGA signals to Digital Video signals expected by the HDTV's DVI jack. The best bet is to buy a modern video card supported by your computer's mother board and OS that has a fair amount of memory (512 MB is a good start). If your HDTV has HDMI jacks and you wish to play the sound from the HDTV's speakers, get a card with HDMI output and buy an HDMI cable. It will send both the sound and video to the HDTV for you.
You can read a nearly endless list of articles about HTPCs aka "Home Theater Personal Computers" for ideas and deep discussions about everything from soup to nuts to implement, design and set up on google.
I hope this helps - good luck!
Nov 12, 2010 | Gateway GT5228 PC Desktop
Where do I get a cable to connect my laptop pc to the DVI input jack on the Soyo 32" LCD TV?
You will need either a DVI-I to DVI-I cable or a DVI-I to HDMI cable. Your computer should have a DVI-I output or HDMI. You can not directly connect a VGA output to the TV. If needed, you can purchase a VGA to component (Y/Pb/Pr) converter.
Mar 15, 2010 | Soyo DYLT032C 32 in. LCD Television
How to use my HDTV for a monitor for my computer
What video output connection type do you have on your PC.....DVI, VGA, S-VIDEO, HDMI?
What video inputs connection types do you have on your HDTV.....DVI, VGA, S-VIDEO, HDMI?
The cable you need will be whatever connection you have....ie: DVI----->HDMI or VGA----->VGA or DVI to DVI.
You will also need an audio cable, 2 Phono RCA Red/White (Left and right) -------------> audio output jack plug or Optical in------->Optical out
Thanks
Sep 05, 2009 | E-Machines eMachines Desktop PC
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Notebook Connection to TV
Check to see if your TV has a VGA or DVI input. If it does then buy a DVI to USB adapter or VGA to USB adapter. Each of the adapters cost around $30-60 US Dollars depending on the quality. Then use male-to-male VGA or DVI wire from TV to adapter, then adapter to PC. Good Luck.
Sep 20, 2008 | Toshiba Tecra M1 Notebook
Connecting an LCD TV to a computer to use as TV and Comp. Monitor.
Im no expert on the subject, but I use my L37 for a monitor, and use just the vga adapter. It works good as a monitor, and both dvds and my hdtv wonder tuner card look great through the vga connection. They do make adapters for dvi to hdmi. Although, hdmi also carries sound, but you wont get that out of your dvi output from your card. So you might not have sound when using that connection, as your tv may not look to the headphone type jack used for sound imput from your computer when you select the hdmi source on it. If you have speakers already connected to your computer you may not care. Also if you have a 720 p Vizio, 1366x768 is the highest resolution you are going to get out of it anyway, if I'm not mistaken. I'm Not sure why you would need 2 connectios to the same monitor either. I posted 1 link below because they had several dvi to hdmi adapters. Hope that helps.
http://www.bizrate.com/computercables_adapters/products__keyword--hdmi+dvi+d+dual+link.html
Jul 18, 2008 | Vizio L37 Television
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
Samsung PPM42S3 42 in. Plasma Television Logo
248 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
