Question about McCulloch Garden
Fuel lines route for Mac3200 chainsaw - McCulloch Garden
  • 7,733 Answers
Go To Mcculloch.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 12, 2010
Replaced fuel lines,vent line is my major problem!
Make and model please.?
Where is the fuel leaking from exactly?
Generally you don't get diagrams od fueling routes. They often go via the most direct route from tank to carb/primer
May 26, 2016 | Garden
Fuel lineson mac3200 chanson saw
Not sure what the question is since you just wrote a statement.
Ethanol gas does ruin these fuel lines. Fuel line can be bought anywhere. ACE hardware fro instance.
Dec 22, 2013 | Garden
I have a wt820 carb on an echo cs400 how do the fuel lines route
wt820-carb-echo-cs400-fuel-lines-route-u2zok31ofbeqiqkdplhepnij-2-0.jpg which is for the fuel line with the filter and which is for the primer bulb?
Nov 13, 2013 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
How do the fuel lines go & which one does the filter go on , on a McCulloch MAC3200 , mod.#22600032-69
Hi krangel123...
Check out the routing of the fuel lines in the drawing below
Please take time to rate me thumbs up
Sep 18, 2011 | McCulloch Garden
Need diagram of fuel lines from tank to primer bulb and carburator on a Poland chainsaw model 1950 wood shark
There are 7 different types of the 1950 model (types 1 - 7) and it came with one of these 2 carbs Walbro or Zama. The carbs are different as are the fuel line connections for each one.
Although this video is for the promer bulb you can see the routing of the fuel lines.
http://www.ereplacementparts.com/article/4262/How_to_Replace_a_Primer_Bulb.html
You will have one line from the fuel tank connecting to primer bulb the 2nd line going to the carb. If you connect it backward it does not pump fuel into the carb.
Kelly
(FYI Types 1 - 5 all have the same fuel line routing.)
Apr 12, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
After replacing the fuel lines on a mac3200 gas is running out of the bottom of the saw, after the tank emptys the fuel quits leaking. the saw runs great though
This is usually because you used a fuel line that is too small to seal the holes they pass through in the fuel tank. When they pass through the holes in the tank they should be very tight so gas cannot leak past the lines.
Jan 31, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Oct 13, 2009 | Garden
Fuel line crack dry out, in pieces
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Find your saw here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
SmallEng.com
I think the second line on the carburetor is an impulse line and connects to the crank case. HTH
Lou
Oct 08, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
78 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
