Where i can download driver sound edge 4.1 sky digital
SKY TV recording on Planner.I have presented my problem in that it won't recognise y pin when I wish to delete a recording. Please my I re-establish my original pin and please can you simplify your...
Has your pin been changed or reset? It may be that your pin is now the last 4 digits on your sky viewing card (in your Skybox). If this was always the case then it sounds like you (or someone in your home) has either deliberately or accidentally changed the pin so a call to Sky is your only way round this.
Hopefully the last 4 digits on the Sky Viewing card will work
Good luck
Andy
Nov 13, 2013 | Samsung TV Remote Control
How do you replace the propeller on the Air Hogs Sky Stunt, Blue?
To replace the Propeller on an Air Hogs Sky Stunt plane (I got this from their customer server number):
1.) Hold the propeller and turn the nose (at the grey plastic edge, not the rubber) counter clockwise (aka left) until the nose unscrews.
2.) Slid off the OLD propeller.
3.) Slid on the NEW propeller (You will notice there are slots on the propeller mount), need to line up the propeller with those slots.
4.) While holding NEW propeller, screw the nose back on (similar to step # 1) clockwise (aka right).
Hope this helps someone else.
Mar 15, 2013 | Toys
Sky remote volume code
  1. Switch on the TV set
  2. Press the TV button on the Sky Remote
  3. Hold down the Select and Red buttons for 2-3 seconds until the LED blinks twice
  4. Press the TV button on the Sky Remote again
  5. Enter the 4 digit code for your make of TV
  6. The LED should blink twice, if not recheck the 4 digit code used and go back to 1
  7. Press the standby button on the Sky Remote (The TV should go to standby)
  8. Press the Select button to store
Samsung Code 0060
Nov 28, 2011 | Televison & Video
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
Rectangle in led screen green/ or yellow with exclamation
The camera doesn't have anything to focus on - especially if you're shooting the sky. The auto focus needs something with fairly defined edges to work. Try to focus on the edge of a well defined cloud, or focus on a tree or similar, half depress the shutter to lock the focus, then move re-frame your shot. Alternatively you can use manual focus. Hope that helps
Jul 24, 2010 | Canon PowerShot SX210 IS Digital Camera
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Feb 18, 2008 | Televison & Video
Sky remote code for lg 37lc46
for sky plus remote ver 8 the code four number is 0206
the three number code is 206
Nov 16, 2007 | Televison & Video
440 people viewed this question
 Grubhead
Grubhead
