Question about Bosch Dishwashers
Bosch SHU5302UC/U06 dishwasher starts at 2H and eventually starts but continues for a long time at 1 without rinsing the dishes.
  • jdellis Jan 21, 2009
    Eventually mine shuts down. it does seem to rinse but takes a long time to complete the cycle. model # is SHU6802
I had the same problem a few years ago and the tech replaced the control panel. No problems until....last night. Now a different problem.
Posted on Mar 27, 2009
Bosch SGI4345AU/17 shows 2H on the display, it does not seem to matter which program is selected, the unit runs continually. It does not heat the water or finish any cycle. The washing tablet covers the...
The Control unit on your Bosch has a burnt out heat circuit. Just about every dishwasher has a number of "thermal holds" during the wash and rinse cycles in which the controller waits for the water to be heated to a specific temperature. Most dishwashers check for a temperature rise over a certain amount of time and will shut down if this increase is not seen, however, Bosch does not employ this secondary check and the unit will run for as long as you allow.
The Control Unit on your dishwasher will need to be replaced. Being as Bosch is extremely properitary on their parts sells, it is best to actually talk to a parts supplier directly in order to ensure you are getting the correct controller. It is very important that the replacement controller is for your model #, including the /17 designation at the end. A xxxxxxUC/12 controller will not work on your model.
The Control Unit is found in one of 2 places; 1) behind the Control Panel, or 2) at the lower right hand side of the unit towards the rear. Both are relatively easy to replace.
Apr 16, 2011 | Bosch Dishwashers
Bosch Dishwasher Model SHU5316UC-06 -- what does error code 2H mean?
2H is not exactly an "error code", but it does indicate a problem. It means that the machine exceded its wash time by more than 2 hours. This is usualy caused by a failure of the heater, most often caused by a failure of the controll. Remove the control from the door, remove the plastic housing from the control, and check for a bad solder joint on the heater relay.
If you find a bad solder joint, REPLACE the controll.
Or call a qualified service person.
NOTE: The SHU53A dish washer with serial numbers from FD8205 to FD8507 are included in a factory recall. If your dishwasher is one of these contact BSH @ 1-800-586-9226 24/7.
Mar 28, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
My bosch dishwasher control panel displays 0H on the time delay. When I start it the OH go to 2H. It then starts running and does not stop. The cycle minutes don't display. It's model number SHU5302UC...
check to see if your unit has a recall on it because if it does you will get a free control module from bosch.
your problem is the control module. thermador .com is the site to lookup. gaggenau,bosch,thermador they are the same ccompany. let me know if this helps by sending a 4 thumbs up post
Feb 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
SHU5302UC dishwasher will not spray or pump.
Pump motor would be where I would start. It could be something that has the impellers locked up so they wont turn or the motor could be bad
Jan 28, 2010 | Bosch 23 in. SHU5302UC Built-in Dishwasher
I have a bosch dishwasher shu6805uc/u06 to long to wash.
Well not going into the dry cycle could be a timing issue or a EOC (control panel) issue and will need to be addressed. But most dishwashers these days have a active run time during normal cycle of 110 to 120 mins, and thats not including the heated dry feature. I would let the unit run and see if it will finish on its own, and if I say it pushes two and half hours then something is wrong. A tech would most likely have to look at it, also a power reset could help but thats like a 30% chance.
DrakeTech
Dec 30, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Wash cycle OK, but the drying cycle is faulty. The dishes are wet after 12 hours. Will not dry contents of washer! #SHU680SUC/U06
your heating coil has gone bad it`s that rod looking thing in the bottom of your unit under your spray washing spinner depending on the age of your unit your probley better off buying a new dishwasher
Oct 02, 2009 | Bosch Dishwashers
The rinse agent light is on and the water will not spray out
NO WILL STILL WORK IS ONLY A FLOAT SWITCH TO WARN YOU,HOWEVER RINSE AGENT DOES AID THE DRYING PROCESS SO WITHOUT YOURE DISHES WILL BE WET AND SMEARY
Sep 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Not cleaning dishes
Our Bosch does a pretty good job of washing dishes. But we rinse most of the time. Not a hard rinse, but a rinse.
Are both spray bars rotating? You can test by seeing that the bars rotate easily by hand, and also by starting a cycle and opening the door real quick when you hear the spray hit the door.
Make sure the spray bar nozzles are all clear.
Has it ever done a good job of cleaning dishes?
DI you leave a heavy build-up of food on the dishes, and allow it to dry before washing?
Jan 26, 2009 | Bosch SHU5315UC Dishwasher
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Dishwashers Logo
414 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
