Question about Durabrand DUR-1500 Portable DVD Player
What is the price of INOVIX DVD Player Model IDP-1500
Can you provide a user manual for an Inovix iDP-713D Portable DivX DVD Player Widescreen 7" demonstrating where input to a 40" flat screen Samsung UE40C85UKXXU goes?
On the back of the TV you should see the component connections. Connect the Yellow plug to the Green/Y terminal. Connect the white plug to the white audio terminal and red plug to the red audio terminal. Change your TV input to Component and you should be set.
Nov 26, 2014 | Samsung Televison & Video
Inovix Portable DVD Player - have lost the charger
...first you must make sure the voltage of the player...usualy you can read it in the back panel of the player...example : 9 volt 500 ma....then after you know for sure the voltage you can find an universal charger with at least same output....at the electronic store...make sure you have a same voltage and miliampere !!!
Jul 09, 2009 | Televison & Video
Lost firmware of IMP-65 MP3 player
her is a link for the firmware download
IMP-65 Firmware
If this helps please rate the post.
Mar 02, 2009 | Audio Players & Recorders
INOVIX IMP-1112 POTABLE MP3 PLAYER -driver is gone
My Mp3 Player Starting Problum Plaz Help Me
Sep 12, 2008 | Inovix iMP-20 MP3 Player
Blu-ray disc
Hey jude06,
In order to play Blu-Ray discs, you must unfortunately own a Blu-Ray player. Neither HD-DVD players nor Progressive Scan/Upconvert DVD players are capable of playing the discs, and standard DVD players are not able to recognize information on the discs due to how they are constructed.
Please keep in mind that there are always a number of options available to you, should you consider purchasing a Blu-Ray player. While the average asking price with many retailers for stand-alone Blu-Ray players is between $300.00 and $500.00, you can typically obtain an internal Blu-Ray drive for your computer for considerably less. Additionally, the Playstation 3 may also be a viable alternative - the current 40GB model not only plays Blu-Ray discs, but also has the added perk of being a video game console for around the same price as the average stand-alone Blu-Ray player.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 08, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Problem inovix 512MB digital mp3 player
y have a problem with my mp3 player on my screen apeaer starting but is don't working....what y do???
Jan 24, 2008 | Inovix iMP-20 MP3 Player
Driver
gkjfjhfjhgfhjgfjh
Jan 05, 2008 | Inovix iMP-20 MP3 Player
Inovix imp-1112 mp3 player problems
Hi. I've had similar problems with the same model.
Have you tried a Firmware re-install yet? If not, do that first using the CD supplied with it.
Whilst it's plugged into your USB port, it'll hopefully also get a bit of a charge.  I notice on mine that the player will only charge from the USB port when the side on/off switch is in the 'on' (up) position, although there are times when the computer will 'reject' the player with the switch in this position - a series of 'ding-dongs' as it connects and disconnects from the USB port!
If this happens to you, just keep trying!  Come back to it each day, and try another Firmware re-load!
Mine took a few days, but then decided to come to life - weird machine!
Sep 23, 2007 | Inovix iMP-20 MP3 Player
Down laoding music
iTune format will not play in a MP3 Player, you must first convert them to MP3 format.
Aug 19, 2007 | Inovix iMP-20 MP3 Player
Durabrand DUR-1500 Portable DVD Player Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
