Question about Gateway AR-230 DVD Recorder
Can't get picture on TV.
DVD player was playing fine until I tried to play a VCR tape which I had done in the past. The screen was blank, but I had audio. Comcast had the VCR going through the DVD player when it was working. Comcast would not come out because the cable was working properly. The DVD and VCR on the LCD was working fine--just no picture on TV. With manual we tried to troubleshoot, but it still would not give us a picture. I have bought a new DVD and VCR combination player and it works fine. What do you suggest?
  • Anonymous Mar 26, 2014
    fLAT SCREEN TV/VCR/DVD Lost the control. Is there a way to select movies from a dvd where there are several movie titles?
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Posted on Jun 18, 2008
I have a Sylvania SRD3900 DVD Player / VCR Combo that I purchased about 6 years ago. The VCR part is causing problems. When I try to play movies the picture is distorted with no sound, but it plays back...
The tracking needs to be adjusted. Sometimes it's a knob on the VCR, and sometimes it's a control on the remote. Adjust it for the best picture, and the sound shoud be restored.
Good luck, and hope this helps..
Nov 01, 2010 | Sylvania SRD3900 DVD Player/VCR
I record a DVD from VCR tape and try to play on another device
In my research, I learned about finalizing the DVD, which was a new concept to me. I looked that process up in the manual and it did the trick.
Nov 16, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Sep 16, 2009 | Sansui VRDVD4000 DVD Player/VCR
No picture when playing in VCR mode
have you cleaned the heads recently?is there sound?check the tape you played to see if the machine is chewing up the tape and blanking the picture...good luck
Aug 02, 2009 | Samsung DVD-V4600 DVD Player/VCR
Vhs SP tapes
It sounds like the tapes may be physically damaged, wrinkled or creased. This may have been done when they were played in whatever machine you used 5 years ago. Tapes can also be damaged in storage by heat or humidity. Tapes should also be stored on end in their boxes, not flat. If these tapes were stored flat, the bottom edge might have gotten wrinkled. This can damage the control track and cause playback issues.
May 09, 2009 | Sony SLV-D380P DVD Player/VCR
Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Mar 02, 2008 | Philips CCC132AT 13 in. TV/VCR Combo
Video Tape picture shakes horizontally
needs tape path alignment or cleaning done
Jan 15, 2008 | Philips DVDR3320 DVD Recorder/VCR
Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
Sep 24, 2007 | Zenith XBV442 DVD Player/VCR
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Gateway AR-230 DVD Recorder Logo
651 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
