Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
The bottom part is not turning and it's loosing suction.
After replacing the motor to my DC14 I've noticed after re-assembly that the base no longer seems to hinge as freely as it did. This means that when the cleaner is tilted back there is loss of contact between the sole plate and the ground although after a few seconds the base falls to the ground. It looks to me as though the spring held component that runs around the circumferential groove on the motor housing it displaced to one side and there is too much friction. Any ideas for a remedy?
Posted on Mar 31, 2011
    President:
  • 1,654 Answers
Take the sole plate off and check for blockage and check and make sure the brush is turning freely I suspect the brush is clogged and the soleplate is obstructed. Check the hose for any obstructions as well.
http://www.espares.co.uk/diagram/dyson/dc14-vroom/p/1086/716/0/474352
Posted on Nov 15, 2010
Lost suction from cleaning dyson roller brush
This is actually a very common problem that we see for repair on Dyson Vacuums. Usually what happens is that the vacuum doesn't loose suction like most people think. You can test this by feeling the suction power on the hose. If you have suction coming from here, then most likely the machine isn't clogged.
What happens is that the bottom soleplate on the vacuum cleaner can easily be re-installed the incorrect way. If this happens the brushes on the vacuum cleaner can not even hit the carpet, which makes the vacuum feel like it's not picking up, but when the suction is tested from the hose it has plenty.
We see a lot of Dysons come in for repair with this problem. The bottom plate is not flush with the rest of the vacuum cleaner. Here's a picture of what an improperly installed bottom soleplate looks like:
When the bottom plate is put back on the vacuum, you should make sure that the bottom plate (the purple colored part in the picture) is flush with the agitator housing tray (red part in the picture). If not, the brushes will not hit the carpeting, and the vacuum won't really pick up anything.
This is how a correctly installed bottom soleplate should look like:
This should be the first thing you should check on your vacuum cleaner as it's the easiest and most common solution. If this doesn't fix your Dyson, please just use the Clarification Request form, and let me know which exact Dyson model you have, and whether the vacuum has suction power from the hose, whether the brushes turn when set to the carpet setting, and how old the vacuum is. I'd be happy to try and further diagnosis the problem with you.
I hope that this was helpful to you. If it helped you, please be sure to rate the repair as helpful by clicking the thumbs up icons in the top right hand corner.
Thank you very much,
Chris J.
GoVacuum
Mar 31, 2010 | Vacuums
Loss of suction when upright
Check the Rubber Air seals and bottom Hose for splits.
Feb 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction at the twirling brush
take a coat hanger and clean out under ...take off the brushes theres a small tunnel gets stopped up..
Sep 20, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka 4870: Brush roller turns even in hose setting.
You either have the wrong size belt, most likely too small, or you have installed a new belt incorrectly. When you open the cover on the bottom of your vac, you will see the pulley that moves as you flip the switch from floors to carpet. The belt does not go around this pulley. When activated(carpet) the pulley puts tension on the belt causing it to turn the roller. When switched back to hard floors, the belt looses tension allowing motor to cause suction but disabling roller. Also, the dial on top of vac is only to direct suction, not for disabling roller
Jun 21, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Dyson Animal, lost suction and bypass valve seems to be loose
Dear terrygivens, 2-17-2009 4:12am EST (USA)
Most suction problems are caused by a clog from picking up something you probably didn't see or if you have pets an accumulation of pet hairs!
To clear it out take a metal coat hanger and unbend it til it's straight, then bend the end and tape it so when you push it through to unclog your vac it doesn't rip the hose.
Push the coat hanger in from the bottom brush area through the opening where the suction is. Also push it in and out anywhere else you can......You'll probably find something clogged....keep working it til it loosens and intermittently turn on the suction.
If you have a second vac with a hose, use that hose for suction on the clogged vac!
This should do it!
jack
Feb 15, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction or very little
Make sure you have a good bag installed in the vacuum and the door is properly in place. Remove the attachment hose from the bag chamber and turn the machine on. You should have good suction coming from the hose inlet. If you don't you have a problem in the bag chamber. Bad bag, door is not on correct, door is defective, dirty secondary filter.
Connect the hose back to the machine and pull the other end out from the bottom, and turn the machine on. You should have good suction there. If you don't you have a clog or hole in the attachment hose and it needs to be unclogged or relplaced.
Reconnect the to the bottom. Flip the mahine upside down. Take the screws out of the bottom plate and remove. Remove the brushroller and belt. Turn the machine on and you should have suction at the inlet coming off the brushhousing. It you don't, then you have a clog in the nozzle hose and it needs to be removed. It will probably be more accessable from the bottom side since that is the way that it entered.
Sometimes a suction problem can be confused with an brush problem. The belts on that machine should be replaced every 6 to 8 months because they will strentch and wear. This is an inexpensive maitainance that will dramatically improve its function. Part Numbers are 38528-035 and 38528-034
Nov 21, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
I am not getting any suctio out of the wand.
i had same problem it was discovered on the bottom o the bin thats collects dust was cracked and needed replaced this caused me to loose suction
Aug 30, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction in upright position
Check the adapters at the bottom. They're supposed to move cleanly when you lower the handle. It's pretty obvious if there's an air gap when you lower the handle, and you should hear the suction in the air gap.
And...call Dyson...their support is great!
Oct 24, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
