Question about Jwin JD-VD745
I need a charger for jwin portable DVD player JD-VD745V1.1
SOURCE: Player Does not play any type of Disc
Press case lid where it attaches to player. If this makes unit react you have a defective lid switch. You can probably put some weight over it to hold lid down and it will operate. Otherwise switch must be repaired
Posted on Nov 10, 2007
Benimur
  • 6966 Answers
SOURCE: Battery Charger for Trutech Portabel DVD player
As have been posted in a post of similar concern...
You can try calling Target Customer Service 1.800.440.0680 and inquire cost & availability of the charger for the TruTech PVS12701.
Additionally, you may want to contact the manufacturer direct.
ALCO Electronics, Inc.
8392 Six Forks Rd., Suite 104, Raleigh, NC 27615,
(800) 252-6123)
Should you need direct Customer Support, please try here.
Alternately, you can just look for an AC adapter/charger that has the following specs:
Input Voltage - your country's standard AC mains;
Output Voltage - 12VDC
Output Current - at least 1.5 Amp (the higher the better)
Connector - one that will fit and match the polarity of the TruTech PVS12701. (am guessing crown type center positive, pls confirm with the store. It may also help to bring along the unit when doing the purchase over the counter).
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 13, 2008
SOURCE: portable dvd replacement charger
Anyone needing to replace parts for a Durabrand item, I located this website after many hours of research. They have a number of replacements parts and they aren't that expensive either. Good Luck
http://www.1800customersupport.com/products.aspx?cid=4
Posted on Mar 08, 2008
  • 2318 Answers
SOURCE: REPLACEMENT REMOTE
Check this site to find the remote control.
Posted on Apr 14, 2008
Agent Aaron
  • 265 Answers
SOURCE: Insignia portable dvd NS Pdvd8 need battery
Hey redhouse2,
Because Insignia® is a brand primarily carried by Best Buy™ stores, there are two basic ways that you should be able to obtain a replacement battery: by contacting Insignia® technical support, or by ordering a replacement through Best Buy Partsearch.
You may always reach Insignia® by calling their toll-free hotline at (877)-467-4289. If you would prefer a self-service option, simply visit the www.Bestbuy.com website, and follow the link at the bottom of the page that says "Order Parts." Additionally, you may always contact a Partsearch agent by calling our toll-free hotline at 888-Best-Buy (888-237-8289), and requesting to speak with a parts specialist.
Please keep in mind that while some third-party companies may carry compatible batteries for this model, if your DVD player is still under the manufacturer's warranty (or a Best Buy Performance Service Plan) you may wish to seek the replacement part through Insignia® or Best Buy™ first to avoid any unnecessary charges.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on May 29, 2008
Ten pieces of my jwin portable dvd player has a problem with the display it shows white how can i fox that?
White light means that your LCD display panel is not triggering only the back light of the panel is working. They come from China.
Mar 08, 2011 | Jwin JD-VD502 DVD Player
Where are the batteries located
On the bottom side of the portable DVD player.Look for a square plate with a four Philip srcews.Take out those four philips screws there will be a Litium battery inside that square hole.
Jan 03, 2011 | Jwin JD-VD740 Portable DVD Player
My charger broke what do i do
Contact manufacturer for replacement charger, or goto Radio Shack store to see if they have an adapter that may work for you. Otherwise, look on ebay.
Jun 13, 2010 | Jwin JD-VD740 Portable DVD Player
Lwin brand jd-vd760 (invalid key)
sent back to mfg who not fix over phone.
Dec 21, 2009 | Jwin JD-VD765 Portable DVD Player
I need to replace the LCD screen
The best bet is to get in touch with the brands closest authorised repair agent and thet should be able to order the parts for you. Good luck.
Nov 15, 2009 | Jwin JD-VD108 8.4'' Portable TV/DVD/CD...
I have jwin jd-vd503 it does not work it shows
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
  1. (Open the disc tray)
  2. Press SETUP
  3. Press 1, 3, 6, 9
  4. Press LEFT 3 x
  5. Press RIGHT
  6. A new menu entry appears (Version)
  7. Select it and select RC (0=codefree)
Sep 15, 2009 | Jwin JD-VD502 DVD Player
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Jwin JD-VD745 Logo
42 people viewed this question
Top Jwin Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
romy sibug
romy sibug
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
