Question about Biostar K8M800 Micro AM2 Motherboard
Yesterday my computer stopped booting. Now all it does is give a long beep tone every 3 to 4 seconds. I've swapped known working memory, replaced cables to my drives , removed and reinstalled the CPU, pulled and replugged cards. Nothing seems to make a difference. Do you have any more suggestions as to what the problem may be?
  • Biostar Master
  • 27,725 Answers
Make sure the RAM is seated properly
Test or Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your
(motherboard to hard drive)
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
hope this helps
Posted on Nov 11, 2010
G61-306NR power button doesn't work
Disk Drive works, Memory is good, so any Blinking Lights or Beeps when you hit the power button? Does anything ever post to the lcd screen when you press the power button?
It sounds like either you've got a memory issue or a video card issue. Just because the memory worked in your friend's computer does not mean it will work in yours. Your Slot where the memory goes might be bad.
When you plug in the power cord is there anylights whatsoever on the laptop, where the plug goes in or on the AC Adapter ofthe power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 11, 2012 | HEWLETT-PACKARD G61-306NR Notebook
Only long beep tones with a few seconds pauses
depending on the beeps, you are looking at usually memory or video card error. first step is to remove the memory from the system and place only one stick in at a time. if the unit only has one stick then you need to get a known workign stick to test with. if the known working stick works or only one of the other sticks work then check each of the slots indvidually. if you find that the unit does not boot with the memory in a specific slot, then you have a bad motherboard. if the unit boots in every slot with the good memory, then you have a bad stick. If the pc boots after pulling and reseating the memory, you got one of the rare issues of a memory stick lossening up. If nothing boots it, then you need to move on to either the video card or motherboard.
Without the exact beeps and length of each beep i could not give you more than a generalized answer.
Sep 07, 2011 | Compaq Presario 5000 PC Desktop
My H.p Pavilion dv2500 gives 2 short beeb sounds when i start it, but screen is not shoving anything, all leds are working, and no activity is seen on Hdd led, have tryed to change ram, but same problem, ...
Hi! Welcome to FixYA,
2 short beeps is usualy a beep code for Parity circuit failure.
Since reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other stick
If you have access to another computer that uses the same memory, try using its known good memory in your computer. If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
If it is determined the memory in the computer is bad I suggest that you replace it.
Jun 18, 2011 | Computers & Internet
My computer lenovo desktop thinkcentre beeps 1,3,3,1 i chaged the memory RAM but no effect seen it continue beeping at booting process, please help me
Cause
Computer RAM (memory) related issue.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards. Information about ESD and proper grounding techniques are found on our ESD help page.
Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Open computer and reseat memory
Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Try another computers memory
Replace memory
If it is determined the memory in the computer is bad we suggest that you replace it.
May 19, 2011 | Lenovo ThickCentre M58p Desktop 7479A3U
My tower beeps when i turn it on i have unplugged all the cords, transferred it to another power point and it continues to do this it beeps for 2 seconds and then beeps for 5 seconds and then pauses for a...
Try turning it off from the wall open the case and remove the ram (memory sticks ) from the mother board if there is one stick carefully clean the metal contacts with a new white eraser and reinstall it (if there are two sticks only replace one stick at a time ) if it boots with one stick then this was the problem if it doesnt boot and you have two memory sticks swap them and try again if it boots this time try shuting it back down and replace the second stic if it stops working again remove the faulty stick and replace it with a good one .(make sure you turn the computer of and unplug it every time you remove the memory .
I hope this helps Andrew a
Apr 07, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
F2 wont bring up system bios computer sounds 3 beeps when starting no keyboard control or display
3 beeps means you have a faulty or very dusty memory module.
You will need to open up the case and clean the interior out of dust. Remove the memory modules and clean the brass contacts and the slots the memory clips into.
Then reseat the memory and try to boot the machine again. If you still have the same 3 beeps you will need new memory for the machine.
Regards.
Jun 28, 2010 | E-Machines T2742 PC Desktop
3 short beeps.
This indicates a memory problem
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Sep 14, 2009 | EliteGroup K7VMM Motherboard
My G4 Power Book won't start up.
myhotspot,
I think you are experienceing the same problem I had with my Powerbook G4. I would get the single beep, followed by the pulsing white light (2 flashes). The single beep indicates no memory is detected by the machine and the double flash with the white light is related. Apple eventually replaced my memory banks even though I was past the 1 year warranty period because it was a "known" problem with some of the G4s.
As a short term solution, you may want to try swapping your installed memory to the unused slot.
Aug 10, 2009 | Apple PowerBook G4 Mac Notebook
Did not boot and with 3 beep sound
Remove added memory
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
Aug 04, 2009 | Computers & Internet
Desk top emachine powers on
You state that thre are no beeps coming from the PC upon boot. If you remove the memory entirely and reboot, you should get a series of BIOS post tones. If you do not get these, I would first test your power supply to make sure it is working properly. If it is, you most likely have a failed hardware component: either motherboard or processor. If you get no post tones without memory loaded and with a known good power supply, the motherboard will be your problem child.
If you DO get post tones with a known good power supply, try replacing memory 1 stick at a time (if you have more than 1). If 1 works, you have your culprit. If neither work, then you most likely have a bad processor.
Process of elimination...sucks sometimes :-(
Jun 18, 2009 | E-Machines eMachines Desktop PC
Biostar K8M800 Micro AM2 Motherboard Logo
Top Biostar Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
