Question about Minolta EP1083 CS/PRO Copier
The phocotopy copy brings out a black background which was not on the original copy
    Scholar:
  • 177 Answers
If your original that you are copying is not white paper you will get this issue also another problem is that your optics mirros may need cleaning in general the machine will require a general service by a certified engineer this will fix your issue
Posted on Mar 06, 2011
How to remove dark background on bizhub 350
Make multiple copies of Jet black print for example, open the platen cover and then make blank copies.Print out will be jet black.After about 60 to 70 copies background will be adjusted, if not then replace the toner.After replacing the toner if the background is still there then you must replace the developer.
Feb 11, 2015 | Konica Minolta bizhub Office Equipment &...
How to remove blackscreen wallpaper from window xp
It could be virus. Try running a full system scan.
Sep 01, 2014 | Computers & Internet
Why when I select color copy on HP Deskjet 3050 J610, it prints with a blue background?
The issue is from the glass on the copier, it would be better if you clean it very well or possible change.
Aug 20, 2014 | HP Deskjet 3050 All-in-One J610A Printer :...
Canon PC921 Replaced toner, bad copies. Is there a separate drum to be replaced?
yes that it 's the most possibillity.
but you must be assure that :
- the paper is not moist. (it makes pale copies)
- the glass has you cleaned up. (it makes black background uneven)
- the transfer unit is not dirty. (it makes black background)
May 21, 2011 | Canon PC-921 Black and White Copier
Xerox 3050 service manual
sir,
i want get solution for my 3050 xerox machine. while taking the copy the background coming black, idon't know the reason, i changed explosure lamp, primary corona end block, tonner, but till the problem is background black, if one copy comes clear another copy will be black. if know the solution kindly pass the message to my cell no.7760191629.
thankyou,
regards,
prabhu
Sep 11, 2010 | Xerox Office Equipment & Supplies
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Copies have gray background.
Have you had the optics cleaned resently? If not Iwould start with that and make sure you have the copier unpluged and don't forget to clean the two mirrors under the Black Box/cover. It could also,mean that you need a new OPC drum and blade.. It depends on how maiy copies are on the copier and drum...
Sep 04, 2008 | Toshiba 2060 Copier
Copying from Colored Paper
No..The exposure will only give you an overall lighter or darker copy.. Dave UK
Feb 23, 2007 | Canon ImageRunner C-3170U Copier
52 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
