Question about Dell Inspiron E1705 Notebook
I have a Dell Inspirion E1705 which came installed with Windows XP. When I turn the computer on, I get the Dell Logo, then nothing except a cursor in the top left side. I tried booting from the reinstallion Windows disk but nothing happens?
  • 15 Answers
Try this, while the computer is off, press and hold the Fn key down then press the power button like turning it on.. it should say diagnostics boot selected. if it passes the test windows would have to be reinstalled. if it fails with error codes 0141, 0142, 0143 or 0146 then the hard drive has to be replaced.
Posted on Nov 11, 2010
Bluetooth not working on windows 7 dell inspirion but drivers are installed but still not in task bar what to do?
You can enable this with the fn function on the keybord?
Otherwise it might be an winxp machine with win7 driver and that is the isseu. If its an winxp computer try to install the driver under xp compatabilitymode!
Jan 21, 2018 | Dell Computers & Internet
Dell Inspirion 530 start up one beep dell logo to black screen with cursor. Ran repair w disk nothing happened what are my options will reinstalling vista fix this is there a remedy without losing all data...
Normally this means the memory cards are not seated properly in the motherboard. Pull them out flip the white plastics retainers on the sides down and reinseert.
Jun 14, 2011 | Dell Inspiron 530s Desktop Computer
How difficult or advisable is it to try to upgrade an existing Dell laptop? I have one that is probably 5 years old...would like to wipe it clean.
I dont think you can upgrade this particular mode.. Its better if you can get a new computer.. If you need to wipe out everything then you need to reinstall everything like OS and drivers which may take long time.. S0 try this..
Dell has a default partition on the computer and you can install with the same..
If you have windows vista on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you have windows Xp then you have to turn on the computer and when the dell logo appears you have to simultaneously press control and the F11key.. You will be able to reinstall the OS and drivers in this way..
If thi is not available then install OS using the OS disk and then drivers using the drivers disk...
Sep 20, 2010 | Dell Inspiron E1705 Notebook
My Dell Inspiron 1545 on Windows 7. After a system restore will not start. You switch on, The Dell logo appears, then the screen stays blank except for the cursor arrow which remains and can be moved...
Power drain your computer, remove all the accessories connected on it, including battery and power cord then press the power button for 1 minute.
Connect the power cord then turn on the computer.
This is a possible Operating system corruption and it needs a complete reloading of your operating system or reformat your HDD and install the OS again.
May 15, 2010 | Computers & Internet
MY inspirion e1705 laptop stated I had a virus then it wiped me out. computer will not boot in nornal or safe mode please help me recover so i can remove the virus
insert operating system cd/dvd into cd/dvd rom and restart. while restarting press any key while u get the press any key to boot from cd/dvd. then re install / repair your operating system
Jan 12, 2010 | Dell Inspiron E1705 Notebook
Startup screen goes black except for the cursor
Get a new OS Installer, I suggest you take Windows 7
Oct 18, 2009 | Dell Inspiron 6000 Notebook
BOOTMGR is missing? dell inspiron e1705
maby you can use xp disk to startup computer and select the R from the menu thad displays than you are in the repair funktion
type help and you see a list .
type fixboot and enter
than type exit and now you are in the dos mode
restart and i hope xp wil also repair your bootmanager and computer starts normaly
download the windows relase version and burn it to disk .it are avalebel on microsoft webpage
good luck
Sep 01, 2009 | Dell Inspiron E1705 Notebook
Dell inspirion 530 Black sreen at boot up with blinking cursor
HI there.
Hit F12 - enter diagnostics - then run them
It should from memory run a test called 'DST' which stands for disk short test. If this passes OK your disk is 99% ok. If OK then (my guess is you have WinXP) boot the XP install disk and attemp to install Windows. If the installer detects a version of windows already on the disk it will ask you "if you wish to repair the copy already installed"
If it does hit yes - ( you wont lose your data however I hope you have backed up)
After it has finished your done.
Hope this helps you out.....Mark
Aug 28, 2009 | Dell InspironTM 1501 Notebook
Dell Inspiron E1705 Do I have a switch or keystroke to turn on wireless capability"
you should have software that came with Dell but failing that you can use Windows by clicking connect to on the Start Menu
Mar 31, 2009 | Dell Inspiron E1705 Notebook
My E1705 does finish coming up or turning on.
if the computer is booting up (you see the dell logo and then the windows logo) it could just be that your ram needs to be reseated, its very easy to do but if your not comfortable doing so any computer shop would be able to do it but most likely not for free. if that doesnt do it try to reseat the hard drive and or the wireless cards, any loose components can cause it to freeze, also if you have any USB Devices hooked to the computer during bootup make sure you remove them while troubleshooting. Past that it would be either a mechanical failure in the Harddrive of the computer or possibly failing memory or motherboard. You will need to do extensive troubleshooting to determine that. If you have a waranty with Dell they will walk you through the paces if your not sure what to do next you can ask me as well.
Best Regards,
B.
Mar 24, 2009 | Dell Inspiron E1705 Notebook
Dell Inspiron E1705 Notebook Logo
146 people viewed this question
Alun Cox
