Question about Acer Computers & Internet
I have an accer sreen that has power,I faintly can see that the monitor is working....however the screen is totally dark....but can see background
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 11, 2010
Dark sreen
put some dark covering over the logo
May 15, 2014 | Sony Vaio VPCEA36FM
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Jan 06, 2011 | Computers & Internet
Screen comes on then goes out in 5 seconds. The backlight goes dark but the seen is working, just can't see it. The backlight is out...
mark587, Did you shine a very bright flashlight 1" from the screen to try and see the WIN-desktop ?? Even though the screen appears BLACK. Your words above said: JUST CAN'T SEE IT Did you really NOT see anything? Have you seen any of the longer video clips of "LCD Monitor Disassembly" on YOUTUBE? Some BLACK screen "symptom" lcd displays can be repaired for less than $10 in parts. Capacitors! Also check videos on lcd repair. Then get back here to fixya and I or any of the guys can help you decide what to do with your display whoose screen is now dark and lifeless. After doing the YOUTUBE thing you may even tell us what you will do!!! Hope this was helpful. Yes we do want to hear back from you. please rate this response on fixya. I'm louie12fix on fixya or lmistyrel @ aol.com. Bye for now.
Oct 07, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Dark LCD screen. Very faint image.
Internally it has a inverter board which go bad sometimes or due to heat sometimes get unpluged.So you will have to open it make sure when you do there is no power going to it.Look at the wires make sure they are snug and try again.
good Luck
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Faint Vertical lines on Samsung LCD TV
Your correct, LCD's don't burn. This sounds like a defective main control module. I would take it in as soon as possible to have it looked at.
May 03, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Sceptre X-24-wg LCD not bright dark
if you can see the image in the monitor the light tubes are not firing and this is commonly caused by blown capacitors on the power board, the capacitors need to be replaced and the monitor should work fine.
Let me know what you want to do .
Mar 22, 2009 | Computers & Internet
Dell inspiron 5150 dark screen, faint image in background
If it showed a pinkish tint on the screen before it went out it could be the backlite. If you can see a faint screen when you turn the room lights out it chuld be the inverter. Inverters are cheap ... a used one for around $8 on ebay. Try that first. Make sure that you buy the EXACT model that is presently in your laptop.
Jan 14, 2009 | Dell Inspiron 5150 Notebook
Computers & Internet Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
