Question about Gateway MX3215 Notebook
Memory update problem
What you said about about chipset makes sense. how do i determine the chipset?
  • John Peel
    John Peel May 11, 2010
    Cuple things -
    1. How much memory are you trying to update too?
    2. how much memory did you have before?
    3. Where did you buy the laptop?
    Problem Solver:
  • 13 Answers
I just downloaded a cpu monitor from www.cpuid.com for my wife's gateway.
If you go to their home page and download version 1.48 it should give you the stats for your chipset.
Hope that works for you!
Posted on Dec 02, 2008
We received a donation of Dell Optiplex 755 Mini Towers. I can determine which and the proper order of LAN/Network driver (1,2,3 etc.) installations.
Find your specific model on http://support.dell.com
First, look for a "chipset" device-driver. If it exists, install it first, and reboot.
Second, look for an Ethernet device-driver. Download it to a USB memory-stick, and move the memory-stick to the Dell, and install it.
Third, the order of the other device-drivers does not matter, but having a working Ethernet connection makes it much easier to download/install the other device-drivers, and also to run "Windows Update" to download more device-drivers directly from Microsoft's web-site.
Feb 06, 2014 | Dell 25 Lot Optiplex 755 2.3ghz Mini Tower...
Alert chipset heat sink not detected
would help if u can provide info about ur system specs/model. something u can try is to make sure the fans and htsnks on ur system and any cables specifically for thermal sensing are seated/connected properly and check for updates to the bios of your system. u can usually check the support site of your computer manufacturer to check for updates to the bios and chipsets. hope that helps
Nov 29, 2013 | Computers & Internet
Does 1rx8 ram go along with 2rx8?
Look at your motherboard manual, it tells you what kind of memory, which slots to use for number of sticks.
Your statement makes no sense, 1r, what is this ?
There is speed and size of memory.
DDR-, DDR 2 or DDR3, then speed, DDR3 2000 which each speed has a corresponding number.
DDR3 2000 is called ( PC3 16000 )
The chipset of the motherboard dictates what size and speed of memory that it can use.
Dec 05, 2012 | Biostar Computers & Internet
Dvd player will not register
A similar thing happened to me, I updated my Intel chipset drivers.
  1. Determine what kind of chipset you have: http://www.intel.com/p/en_US/support?iid=hdr+support
  2. Download the proper driver
  3. Install.
May 06, 2011 | Computers & Internet
I have a Cisnet Model CA-ST501 PC and I would like to kwon if I would have to update my BIOS or chipset to install memory chips of 400 speed instead of 333 speed.
Hello
If your memory config in the bios is set to automatic,then you shouldnt have to update the bios.Or the chipset.
If however there is a bios and chipset update available, then i would update them both after you install the new memory chips.
Aug 29, 2010 | ZT Group Cisnet PC Desktop
Windows 7 drivers for Optiplex GX620
for drivers u visit driversdownload.com, register and then dowload required drivers for ur comp. i doubt ur computer is affected with virus. pls check it also
Jul 14, 2010 | Dell OptiPlex GX620 PC Desktop
Multimedia Audio Controller Needed as Well!
I find VGA and Audio triver for motherboard MSI-661FM3
Jun 02, 2009 | MSI 661FM3-V Motherboard
Blue screen on start-up. Mobo SIS-741 Chipset SIS741GX Rev 03
This problem can be caused by several things. First, are the memory chips exactly identical (brand, type, size, etc.)? If not, that will definitely cause the problem. Second, how many memory slots are there? If you have four, check the manual and make sure you're putting the memory in the correct slots. Some Mobo's require that you put chips in slots A1 and B1 and not A1 and A2. Also, some Mobo's have DDR slots and DDR2 slots, so make sure you're putting the right kind of memory into the proper slots. Some people fudge the memory by putting 400 mhz memory into slower slots, and that works one chip at a time - but if you install a second, identical chip, the system will fail. If all else fails and you've met these conditions, check the type of memory to be sure of the proper fit (use manufacturer's recommended brands and numbers) or try a different chip in the second slot. One chip could be bad.
May 25, 2009 | SIS741GX-MN Motherboard
Install drivers
This is most probably happening because there's a chipset driver for the
motherboard that you haven't installed. There should be a basic driver CD
that came with the system, or you can determine the motherboard make and
model (it's usually screen-printed on the board) and from that you can find
the manufacturer's site and get that driver set. Installing that is the
first thing to do after a Windows reinstall.
If you don't have luck with finding the chipset drivers you need, another
posibility is to go to the Windows Update site (start/all programs/windows
update, at the top) and letting the site look for drivers you need. It's in a
list of sections of update, on the left.
Was this helpful? Then click the "Yes" button below. Voting helps the web
interface. http://www.microsoft.com/wn3/locales....htm#RateAPost Thanks,
Feb 10, 2009 | Gateway Computers & Internet
Question from docustor re:ASUS Intel 810 Chipset MEW-AM
the intel 810 chipset requires very specifically made 256meg sticks to support that much memory. the 256 meg standard has changed, and the 810 wont support the ram unless it is made by the old specs. smaller ram sticks such as 64 and 128 will not have this problem.
Jul 19, 2008 | ASUS Intel 810 Chipset MEW-AM Motherboard
Gateway MX3215 Notebook Logo
80 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
