Question about Earlex HVLP Spray Station 3000
I can't remember how many seconds the paint should run through the funnel thingy
    Problem Solver:
  • 6 Answers
Assuming that you are using the standard 2.0mm tip - MAXIMUM 60 seconds.
The paint manufacturer publishes a data sheet with recommended viscosity for spraying and you should try that first. The data sheet will probably suggest a maximum percentage of thinning as well.
You will find that in order to obtain a nice fine spray 45 seconds through the viscosity cup is about right for most oil paints.
Posted on May 31, 2011
MY DAISY DONT PUMP, WHAT SHOULD I DO?
It's the little cone shaped white plastic thingy and the O rings in the pressure reservoir. When you take it apart, it's the valve thingy connected to the end of the trigger thingy that;s inside the large threaded plug thingy. It's held in by a tiny C ring. Daisy USED to sell a specific repair kit that included those specific parts for that specific problem, but don't ask me if I know if they still do. Yeah, I have a 922 sitting behind the door in my den. It's the original metal receiver white diamond gun. I loved that thing growing up and I still shoulder it now and then and remember the good times we had back in the late 70's-early 80's. I've had to rebuild that exact same thing twice before when Daisy sold the repair kit for $4. Hector, good luck on your rifle, sir! I hope you can locate those parts you need!
On a second thought, if you can't locate the kit, try replacing the O rings by themselves. That might work. Those rot with age. Take the valve off, the large threaded plug with the valve thingy on the trigger thingy, and see what size it looks like and just give those a try.
Oct 17, 2016 | The Optics
Where do you add transmission fluid in at
Through the transmission dipstic tube. Use a funnel that will fit into the dipstick tube and SLOWLY pour the transmission fluid into the funnel. Remember to have paper towles with you to catch any remainingbfluid that is in the funnel, and make sure the funnel is clean.
Dec 31, 2014 | 2001 Jaguar S-Type
I need to know where to put transmission fluid in my 88 town car
there is a large dipstick that is painted red-you need to remove the dipstick and put a long funnel in the tube, fill from there.
Mar 16, 2011 | Lincoln Town Car Cars & Trucks
Need to know where to put transmission fluid in a 1991 Geo Storm.
Gotta drop it down the same hole as the dipstick. Get a funnel or spiral up a piece of paper to make a funnel. Its the little red handle near the back of the motor. Remember to always check trans fluid while car is running
Feb 02, 2011 | 1991 Geo Storm
Where do you fill the transmission fluid on a 2003 Passat GXL?
not sure when the level thingy disappeared ,if you havent one then its up in the air on a four poster and fill from underneath ,very easy with the right gear but a bit awkard in teh garden
Aug 28, 2010 | 2003 Volkswagen Passat
I just bought a 97 pontiac trans sports and i dont remember the anti theft thingy to starty it and the guy i bought the van from is gone
Contact a Pontiac Dealer, I believe on that van, if you take and cycle the key off and on 3 times, that will reset the alarm and anti theft thingy.
Jan 28, 2010 | 1997 Pontiac Trans Sport
I need to add transmission fluid to my 2001 A/T Dodge Stratus but cannot find where to add it to.
I assume this is an automatic transmission? You add the transmission fluid through the dip stick tube. It will require a slender funnel available at any good auto parts stare. It doesn't look like it's that big of a hole, but with a trans funnel, you'll get it in there. And REMEMBER, the lines on the dip stick do NOT desingnate "quarts", they designate "pints". Also, make sure the engine is running and warm when you check the fluid or you will not get an accurate reading. the Stick
Dec 10, 2009 | 2001 Dodge Stratus
Stihl 021 running poorly
Couple of things I would check first. Place a funnel in a can with a paper napkin covering bottom of funnel. Pour the gas from the saw into the funnel. If there is a lot of trash in there, remove the fuel line from tank. Clean the filter with carb. cleaner. Then clean the tank with carb. cleaner. If you still have problem. Replace the Air inlet tube, (clear tube with screw type device close to carb).
Apr 15, 2009 | RTO Spur Sprocket For Stihl 017, 021...
1996 tahoe wont start
There should be a 2 second prime by the fuel pump. This prime by the fuel pump is standard for GM vehicles, and if it is not present a hard start is encountered. Turn the ignition to the run position and listen for the fuel pump operation. You may have to have an assistant listen at the fuel filler by installing a long slender funnel into the fuel inlet to the tank, remove the gas cap and insert the funnel, listen at the large end of the funnel to see if the pump can be heard running. Using the funnel acts like a megaphone and makes it easier to hear the pump. If the pump runs for 2 seconds after you turn the key to the run position (DO NOT attempt to start the engine during this test) and the engine doesn't start due to lack of fuel, check for an obstructed fuel filter. (Just change it, it's probably overdue for service anyway since everyone thinks it get changed during oil changes, but never really does.) If the pump doesn't run during prime interval, the computer may not be turning on the fuel pump relay, or the relay is defective. To check the relay, use another of the relays in the power distribution box to substitute for the suspect fuel pump relay and retest. Be sure to wait at least 30 seconds between key cycles since some systems have a delay timer built in to keep the pump from over running. Be sure the relay you sub into the fuel pump socket is identical to the one you remove and properly oriented in the socket. The engine will run following your manual prime because an additional set of contacts in the oil pressure switch will power up the fuel pump relay once proper oil pressure is achieved by an idling engine. If you find that the relay is not defective, but doesn't provide a priming impulse, the engine computer may have failed. DO NOT use a conventional test light with a filament type bulb to check any of the computer circuits that drive the fuel pump relay, or any other computer controlled circuits on an automobile ( or pickup) The driver circuits in a vehicle computer can be blow-out by over-current when using a conventional test light. You can use a high-impedance DVOM for testing safely.
Nov 01, 2008 | Chevrolet Tahoe Cars & Trucks
Earlex HVLP Spray Station 3000 Logo
223 people viewed this question
Top Earlex Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Earlex Air Tool and Compressor Expert? Answer questions, earn points and help others
