Question about Hobart 1HF50D Deep Fryer
Oil won't heat up when readout says heating - Hobart 1HF50D Deep Fryer
Lg oven not heating after self cleaning. code f9
F9 stands for oven no heating. It will be displayed if oven temperature readout when oven temperature doesn't exceed 150F/66C in less than 5 minutes from set time. I would say you may have a heating element malfunction..
Oct 23, 2016 | LG Kitchen Ranges
My thermostat clicks,but heat won,t come on
The t-stat is only a switch, it doesn't provide heat. Please provide information as to what kind of heat (gas, oil, heat pump) as well as what the heating unit is or isn't doing.
Dec 03, 2013 | Goodman CLQ30AR32 Air Conditioner
Heater fan on electric fireplace not working, so heat shuts off and won't come back on. The manufacturer is Southern Enterprises, Inc., model no. FA515500TX.
Was having same problem, found the fan needed a little oil on bearings. Was not spinning up to full speed so heater was cylcing on high limit
Jan 21, 2013 | Southern Enterprises Luxembourg Ivory...
Won't heat my studio - even on "HIGH"
Does it get hot? If so, that is all you will get! It is not made to heat a room of 20 X 15 X 8 feet high. That is 2400 cubic feet of air space that may or may not be insulated. You need a quartz heater or two that are designed with fans to heat larger areas (see the specifications on them). The oil filled radiator is to put next to your rocking chair or under your desk near your feet!
Jan 01, 2013 | Comfort Zone CZ7007 Oil Filled Electric...
J-300 won't heat. FLO readout
FLO = It typically for a Flow Switch or pressure switch (heater is deactivated. Pump may also be deactivated).
It is most likely a flow/pressure switch failure.
Before you buy a replacement try running the spa with out the filter cartridge - Checking if dirty cartridge is the issue. Also check that all gate valves are all the way open & locked.
Jan 05, 2012 | Jacuzzi Home
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
Transmission won't shift when engine heats up
Dear Madam or Sir,
if the problem has an electrical cause, the oil temperature sensor is defective, this should be checked first.
If the sensor is working good, there is a mechanical problem with your transmission due to worn bushes and / or gaskets. The viscosity of the oil is decreasing while heating up, if there is a worn gasket the shift pressure drops and the transmission won´t shift.
Jun 26, 2010 | 1992 Dodge Caravan
Readings disappear on thermostat for awhile then come back
Hi Linda,
There are a few things that cause this:
  1. When the heat is starting, it will sometimes go blank for a few minutes and then resume.
  2. Most have batteries, replace them with fresh new ones, if the electricity goes out while you are away, the batteries will keep the settings.
  3. Have someone check the house when it is extremely cold or hire a service to monitor. Your alarm company can usually add temperature sensors to your home, it will add a little safety net for you.
Hope this was helpful, please rate my answer.
Thanks,
Paul
Jan 27, 2009 | Honeywell Programmable Thermostat Heater
Hobart 1HF50D Deep Fryer Logo
42 people viewed this question
Top Hobart Kitchen Appliances - Others Experts
atva20
Level 1 Expert
Colin Stickland
Colin Stickland
Dennis Boxerman
Are you a Hobart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
