Question about Microwave Ovens
Little card bord looking thing inside microwave has burned can iget a new one
  • 144 Answers
Yes you can fix it . it is easy to replace , it can be bought on the net or any good shop , buy a replacement that fits most m/waves and cut to size. or google make model etc. have had fault many times Replacement will fix problem most certainly,
pete
Posted on Nov 11, 2010
Kenmore microwave 80082 sparking from an inside panel
If your positive it is not arcing behind the waveguide cover I would think it has to be in the control area. You will have to turn off power to the unit and remove the control panel and look to see if you can find any burn marks or soot, to indicate where your problem may be. I have found burnt connectors at the relays or even possibly burnt wires to the door switches. Careful! the capacitor on these can hold a charge for a long time and can shock you pretty good. Only work on something like this with the power to it off and the capacitor discharged. Microwaves do not come through the little round holes those are typically an RF screen to prevent microwaves from getting through. A lot of times that is where the cavity lamp shines through.
Aug 14, 2017 | Microwave Ovens
Plastic shield card is burning up!
Hi there
It is called the waveguide ocover and is made from polycarbonate
Feb 29, 2008 | Welbilt MR99T Microwave Oven
I get an occasional spark when microwave is in use
Presuming that you have iliminated the possibility of any metal objects that are not meant to be in the machine being in there (and this includes dishes and other items with silver or gold leaf on them, which WILL spark and burn!) then take a look inside the oven its self. You will find a waveguide cover. It is usually a strange flakey silvery plastic/card like material called Mica and is usually on the same side of the microwave wall as the control panel (So if the picture on this thread is accurate, I will guess the Mica cover is on the right hand wall inside as you look at the machine from the front) . Over time, the magnatron (the thing that creates the microwave energy) will often burn a hole through the mika, or cause a dark brown or black burn mark in it. If this cover is even slightly damaged then it may well cause sparking inside the machine. These covers are designed to be removed and you can buy replacements for them from electrical stores.
Aug 12, 2011 | GE Advantium SCA1001HSS Convection...
When plugging in a Sharp R-33st microwave, nothing happens except a flashing time, no buttons seem to work, any ideas?
it sounds like this is not a new microwave,, is it getting on in years?
if the microwave was discounted from the mains when it was pluged back in the power surge could have blown the circuit bord inside it,, this is quite common, it may be cheaper just to buy a new microwave than spend good money on an old week unit
Mar 05, 2010 | Microwave Ovens
My microwave turns off when I start it
its the program bord inside your microwave playing up and to be realy honest its realy not worth paying out good money to get it fixed even if you could get the new bord,,,its better to just buy a new microwave there so cheap now you can pick them up for less than £50.00p and it would cost you all of that just for the repair man to come and look at it,,,,why do you think they all drive round in big cars?
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Arcing inside microwave
unless you are familiar with these, leave it alone. Over time small particles of food become carbonized inside the oven, hence the electrical display. the solution is to clean it after every use.
Oct 02, 2009 | Magic Chef MCD1110ST Microwave Oven
My cookworks micro wave works fine but upon cleaning the inside i noticed on the right sideof the inside a small square ''piece of card/plastic'' has a hole/burn mark-can i obtain a replacement
Look at repairclinic.com for this part. Have your make and model of couse and describe the part as clearly as you can. They are very good at sorting things out.
a
Sep 28, 2009 | Microwave Ovens
Microwave is arcing on the antenna blade.
Arcing is often the result of the cover over the magnatron (The thing that produces the microwaves) being aged, burned or damaged. If you look inside the oven, you will see a cover (usually square or round and around 3-5 inches across depending on the machine)made from a flakey silver plastic/fibre material. If this is burned or has a hole, it needs replacing and this will probably cure your problem.
Mar 13, 2009 | GE Microwave Ovens
A little metal is showing at the inside roof of the microwave.
Rub down with fine wet & dry ,paint with Humbrol enamel to match.
Sep 28, 2008 | Microwave Ovens
Kenmore microwave mod. # 721.62463200 Fire
This sort of thing is caused by food particles burning and maybe the wave guide cover has a hole in it. They do not, if used correctly, burn as you describe.
May 19, 2017 | Microwave Ovens
Microwave Ovens Logo
48 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
