Question about Bose 901 EQ1915 Home Equalizer
My power switch flickers on series 1 equalizer, is this a problem
    Novelist:
  • 87 Answers
It probably is not. The pilot light in a lot of power switched is a neon bulb wired across the AC mains. Those neon things sometimes flicker from the time they are new and sometimes only after some years. If you don't hear any static or sound fluctuation - rock on.
Posted on Nov 12, 2010
How can i hook-up a 901 series vi equalizer to a str-de897?
I own 901's(since new) with the active equalizer powered with a non-Sony surround sound receiver.
Basically, you use the MD/Tape in/out jacks to route the signal to the Bose active equalizer. Switch the Tape Monitor switch if no sound is heard.
Here are some references.
https://docs.sony.com/release/STRDE897.pdf http://products.bose.com/pdf/customer_service/owners/901_guide.pdf
Connect equalizer cables (4 total) to the MD/TAPE section of your receiver. OUT from the receiver to the equalizer IN and Out from the equalizer to IN on the receiver.
One issue with the equalizer running through the MD/Tape jacks is that it may affect any other speakers hooked up to your system.
Mar 15, 2016 | Audio Players & Recorders
Kenwood kac-6295 shuts off then turns back on at high volumes
Did you wire the speakers in series or parallel? 4 ohm speakers in parallel actually come out to equal 2 ohms wich most amps would see as a short causing protection issues. 4 ohm speakers in series equals 8 ohms which should be fine for your amp. been there : expert-tech / SAM
Mar 27, 2012 | Car Audio & Video
Hi,i have a nx7010 that powers up but no actvity on screen,,swopped mem. modules,,nothing,but when i swop the chip it powers up normaly everythings okay,but when i shutdown the problem returns,swop the...
hi
old PC
when did it last run perfectly last week last year, never, I found it in dumpster. or garage sale for $1
swap, (exchanged)
the screen never ever shows text. right? = equals no activity>?
this old PC is CCFL pC, back lighted.
and as such those fail easy, (20,000 hr rated max)
we use LED now, and never fail.
the tests are here
laptop, PC, NX old series. from long ago.
all are problematic this old,
But screen dead is #1 for sure. 100% dead.
btw that lamp can turn on then off, the flicker go dim or just be pure intermittant folly;, a PITA they are and the inverter same.
see the simple tests here.
http://www.pcdied.com/monitors.html#Laptop
Aug 05, 2017 | HP Compaq nx7010 Notebook
My RCA 32V550TYX1 turns itself off and on - flickers. The only way to stop it is to unplug the set. Any ideas?
Hello, The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive HV were detected.
May 19, 2010 | RCA 32V550T 32" TV
The dislay flickers SH GE90.technics .it seems to be a common fault.. can this be fixed
replace the 3 electrolytic capacitors in the power supply section near where the lead from the transformer connects to.
they're sat side by side.
you may notice only 1 might be leaky but replace all 3 for good measure.
i've had quite a few with exactly the same fault and all were cured by replacing the above.
hope this helps?
Mar 11, 2010 | Technics SH-GE90 Home Equalizer
I need a hook up digram fof an optimus model 31-2025 stereo equalizer
http://support.radioshack.com/support_audio/doc48/48943.htm
Ten-Band Stereo Frequency
Equalizer (310-2025) Connections Faxback Doc. # 48943
Follow these steps to connect the equalizer to your audio system.
CAUTIONS: Use only shielded audio cable with RCA-type connectors (not
supplied). This type of cable is available at your local
RadioShack store.
Before you connect the equalizer, turn off all components in
your audio system and unplug their power cords.
Before you plug in the equalizer's power cord, complete all
connections and be sure the equalizer's POWER button is out.
1. To connect the equalizer to your receiver, connect the receiver's TAPE
OUT jacks to the equalizer's MAIN IN jacks.
Then, connect the equalizer's MAIN OUT jacks to your receiver's TAPE
IN or TAPE MONITOR jacks.
2. You can connect a tape deck to each set of tape jacks (TAPE 1 and TAPE
2) on the back of the equalizer.
To connect each tape deck, connect the equalizer's TAPE OUT jacks to
the tape deck's in jacks. Then, connect the tape deck's out jacks to
the equalizer's TAPE IN jacks.
3. Plug the equalizer's power cord into your receiver's switched power
outlet or any standard AC outlet.
WARNING: The equalizer's power cord has a polarized plug. To prevent
electric shock, do not use an extension cord or other
receptacle unless you can fully and easily insert the plug's
blades.
4. Connect the power cords of all other components.
(wr 08/04/98)
Feb 24, 2010 | Audio Players & Recorders
How do i connect multiple ampliers to one source and equalizer?
why do u want to use 3 amplifiers connected in series ?or even parellel.?remember in series amplifiers 1+1+1 does not make 3.it may make 10,hence the speakers may go bust .
Aug 24, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
I have 1000 watt sony XPLOD amp and i just installed it today. with new monster cable&ground. the green light turns on& thumping goes for a little. i try to raise up just a little bit& after 2...
it isnt getting enough power and its tripping the internal switch on the amp and putting it in safe mode. either your wire isnt a high enough gauge. you might need a capacitor or you need bigger wire.
Jun 13, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Connecting the 901 series VI equalizer
hello
please make sure your receiver has a tape monitor switch on the front panel or pre-in/out sockets at the rear. only then all sources will play thru the bose equalizer. also remember if you need a 5.1 or greater setup, you will need 2 amps/receivers.
hope this helps
May 27, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 EQ1915 Home Equalizer Logo
175 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
