Question about Sansui VRDVD4005 DVD Player/VCR
I would like to make a copy from my video tape to a DVD How do I do it?
  • Sansui Master
  • 5,416 Answers
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. Remotes.com often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: http://www.managemylife.com/mmh/owner_manuals/26967/SANSUI-DVD-VCR-Combo-L0311311?brand_name_search=sansui+VRDVD4005 .
I hope this helps.
Posted on Nov 11, 2010
3 Suggested Answers
  • 161 Answers
SOURCE: Copying a DVD
the instructions for this should be in the manual for your combo.
Posted on Jun 12, 2009
  • 603 Answers
SOURCE: when copying a vhs tape to dvd, and there is only
You must be able to watch what is being reocorded.
After the part you want to record is finished stop it.
Also the recording can be set for a set amount of time.
Posted on Jan 07, 2010
Can DVD DISKS BE COPIED FROM VHS TAPES ON A dual; DECK MACHINE?
There are machines made just for that task such as the Magnavox DVD recorder. There is a VHS tape deck on one side and a DVD recorder on the other side. You can copy a VHS tape to a DVD and copy a DVD onto a VHS tape as well
Jan 21, 2017 | Televison & Video
Trying to copy vcr tapes onto a dvd and it will not let me...says protected? how?
If the tapes are commercial type movies being bought at a store some time ago, the system will detect it as copy right protected and will not let you make a copy. I've had the problem in the past many times, but if the tape is a home made movie taken with a video camera, it should let you copy it. Some video to pc software does this even with homemade video movies, very frustrating and annoying some times.
Mar 05, 2015 | Magnavox Dvd Vhs Vcr Player Recorder
Can I copy a vsh tape to a dvd with this one player
You can't. It's designed to copy DVD to tape. You might want to invest in a little device: Audio Video USB adapter convert VHS tape to PC, CD, DVD. About $20.00 or less.
Apr 06, 2012 | Zenith XBV342 DVD Player/VCR
Is it possible to copy video from a vhs to a dvd?
If the DVD drive is a recorder, yes. If it is a player only, no. If the tape is copy-protected, recording to a DVD recorder is not possible. Assuming the tapes are not copy-protected, and you are using a DVD recorder with the correct format DVDs (DVD-R for example), you shouldn't have any problems transferring old VHS tapes to DVD.
Jul 05, 2011 | GoVideo DVR4000 DVD Player/VCR
In February, someone asked: "When
What are the tapes that you are trying to copy? are there genuine copies of films? YES THEY COULD BE COPY PROTECTED how they do that? simple they record the tape with the most minimum srength of signal, if you try to copy it you lose signal strength trough the copy process than the video looks a bit scrambled/discoloured and the sound is bad, if it's the case you could buy a video signal booster (if still available in stores) than you have to copy with a VCR that is separated from the DVD recorder so that you can install the booster from the output of the VCR to the input of the DVD recorder.
Hope it helps!
Jan 04, 2011 | Televison & Video
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
Not able to copy entire vhs to dvd
What is the recording speed of your tapes and DVD? SP SLP, etc. on tape SP SLP XP on DVD? That will determine the length of th recorded tape and the recording time the DVD can hold.
Aug 10, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
Transfer To DVD Gives an Error that indicates the content is copy protected
Amazing, CCD-TRV68 is analog video camera and doesn't have any digital signal like copy right.
Jul 29, 2008 | Sony Handycam CCD-TRV68 Camcorder
Copying vhs to dvd
The write-protect tab on the cartridge is set to "PROTECT" or the disc is protected witht the "DVD Management" settings.
Some video tapes on the market(including rental videos) are copy-protected to prevent illegal reproductions. Copy-protected video tapes cannot be properly recorded.
You cannot use the copying function when the FUNCTIONS window, the Scheduled Recording List screen, etc. are displayed.
I hope this information can be of some help to you all. Ms Tanya 2/12/08 3:54AM CST.
Jan 30, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dubbing vhs to dvd
Easy. Connect RCA lead from video/audio OUT on the VCR to video/audio IN on the DVD recorder. Set DVD recorder source to VIDEO then press play on the VCR and record on the DVD recorder.
Sep 09, 2007 | Aspire Digital AD-8091 DVD Recorder
Sansui VRDVD4005 DVD Player/VCR Logo
262 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
