Question about Jura Capresso 551 Electric Burr Grinder
Grind setting I get the same very course grind whether the dial is set to 1 or to 9. Seems to have no effect whatsoever. Thoughts?
This grinder is really pretty crappy, I have the same one. If you want anything less coarse, you will have to grind it multiple times. My Grandmother tried using this and it ended up spitting out a few half and whole beans even after grinding. The best you would end up getting would be a drip coffee grind. Check this out, it might help understand the problem: http://www.epinions.com/content_143707967108
Posted on Jun 26, 2008
How can i Troubleshooting Fax Issues on my hp officejet 4650?
If you get issues like Faxes can be sent but not received, Faxes can be received but not sent error on your Printer then follow the given troubleshooting steps.
Solution to Faxes can be sent but not received
    ·Initially, you have to check any of the telephone line services are enabled. There are,
    1.Voice Mail
    2.Call Waiting
    3.Billing Tone
    4.Privacy Block
    5.Security Screen
    6.Anonymous Call Rejection
    7.Privacy Manager
    ·These may block your incoming faxes. So disable the above features.
    ·If you are using Automatic fax reception option on your fax recipient, then check whether the Automatic Answering feature is enabled or not, if it enables means Auto Answer green LED should be on.
    ·Check the Ring to Answer value.
    ·If the value set as answering machine that causes the issue on fax reception. Then change the value to Fax or FaxTel
    ·Now, you can receive the incoming faxes.
    Solution to Faxes can be received but not sent
      ·Check whether the dialed number is correct or not. Every one of the digits required to make a telephone call from a similar line must be dialed.
      ·On the off chance that the Speed Dial has been used for dialing or the fax has been sent from your PC, print the page to be faxed and dial the number physically on the HP Fax front board.
      ·Check whether the Tone Dialing is set on you HP Fax product.
      ·In the event that faxes are sent effectively from the HP Fax front board, but, it's fail when sent from the PC, test the communication between the HP Officejet 4650 printer and your PC by tapping the Status button in the HP Director application, or attempting to print some record.
      ·If the printing fails to send the fax, then check whether all cables (from system to HP Officejet 4650 Printer) are connected properly, if it's not then connect it properly.
      ·Now restart it. On the off chance that communication still can't be set up, Call Printer customer service team via Toll-Free: +1-800-836-3987 to resolve your HP Officejet 4650 fax issues.
Jun 27, 2017 | HP Office Equipment & Supplies
Coffee grinder only grinds to course no matter where grind adjuster is set
From what I've read about this grinder, you should be happy that it worked well as long as it did.
I say chuck it & buy a new one!!
Apr 13, 2012 | Coffee Makers & Espresso Machines
With the BES860 set to Dual Wall for full automation, even on the lowest auto grind volume setting, the grind volume is too large and it spills over. This is on double setting and using the double filter...
If your using the dial gauge with a dual wall basket, you need to leave the dial in the dual wall setting. If you move it beyond the dual wall setting, you are basically adding more volume to the basket. Leave it in the dual wall setting for dual wall baskets.
Otherwise it may be faulty, it could be your grind setting, try it on 13 and see how it goes.
May 07, 2011 | Breville Fresca BES860 2Cup Coffee Maker
Just bought a used one, seems like the espresso grind is pretty course, is there an adjustment I can make?
To adjust this grinder turn the adjustment nob to the finest setting (ESPRESSO or TURKISH) Locate 2 small set screws on the adjusting nob. Loosen these screws (do not remove them) about one full turn. Start the grinder and, with it running, VERY SLOWLY and GRADUALLY, turn the CENTER adjustment screw clockwise until you begin to hear the burrs begin to touch (whirring sound). Back off the center screw about 1/16 of a turn, shut of grinder and re-tighten the set screws. Then try the grind on DRIP or there about for brewed coffee.
May 21, 2010 | Grindmaster 495 Electric Grinder
With the dial turned to "Turkish" I still get a very course grind. How to adjust/fix?
On the adjusting knob there are 2 set screws (outside of the center) and an adjustment screw (the one in the middle). First make sure the LARGE screws on the side of the SELECTOR plate are tight. Start with the selector on Turkish, with the grinder OFF loosen the set screws about one full turn each. Leaving the selector on Turkish turn the grinder on and gradually VERY SLOWLY turn the center screw clockwise. Eventually you will hear the burrs inside touching. After they touch back of the center screw about 1/8 of a turn. Tighten the SET SCREWS tight as they may allow the grinder to go out of adjustment if not tight. Test the grind with very little coffee and throw those grounds out. Then grind and brew! If these grinders are adjusted too fine you may have problems with the grinds not falling and may back up.
Apr 26, 2010 | Grindmaster 810 Electric Burr Grinder
I have the EAM3200 coffee maker and the coffee comes out of the spout very slowly. We have the grinding dial set for course grinding and we have the flavor dial set to weak. The coffee is very strong...
I find the machine needs a good cleaning at least once a month, make sure you remove the filter unit and clean it well, use a damp cloth or paper towel. Mine went like this when I broke a silicone O-ring, it gets lodged in a waterway and partially blocks it. I describe how to replace them in another solution here, take a look.
Mar 07, 2010 | DeLonghi EAM3200 Espresso & Coffee Maker
Saeco taleo grounds are very wet - almost fluid! this hase started recently when i changed my beans. i have changed the grind to course but with no effect. any ideas?
Try adjusting the amount of coffee and then the grind to finer. If there is not enough coffee in the chamber then it gets over extracted and you get a soupy puck at discharge, if the grind is too coarse, you might also get the same result. Think of your coffee grind as rocks and sand and that will give you a better feel for the proper setting for your machine.
Jan 29, 2010 | Saeco Talea Touch 14-Cup Coffee Maker
Problem with tamping
Try adjusting the grind to a finer setting also the amount of coffee can be adjusted with the lever in the grinder chamber.
May 06, 2009 | Gaggia Syncrony Compact Coffee...
Olympus c-8080 stuck on movie mode. Mode dialing has no effect.
I'VE DONE A LOT OF READING ON THE OLYMPUS SITE AND IT SEEMS LIKE YOUR CAMERA MIGHT JUST HAVE BEEN SET ACCIDENTLY IN MOVIE MODE AS THE DEFAULT SETTING AND THAT IS WHY MOVING THE DIAL HAS NO EFFECT. THE PROBLEM BEING I HAVE YET TO DISCOVER THE TRICK TO REVERSE THIS DEFAULT SETTING FROM MOVIE AND BACK TO THE FUNCTIONS OF THE MODE DIAL. YOU ARE POSSIBLY IN A BETTER PLACE TO DO THIS PART OF THE FIX. I AM HOPING BY HEARING THAT IT IS IN A DEFAULT SETTING YOU MIGHT KNOW WHO WOULD HAVE DONE THIS AND HAVE THEM RESET THE CONTROL TO NORMAL.
IF THIS DOES NOT PRODUCE ANY RESULTS, PLEASE REPLY TO: ARCLIGHT1217 AND I WILL DIG DEEPER INTO THAT SITE TO FIND THE SOLUTION TO RESET THE DEFAULT! I WON'T LEAVE YOU HUNG IN TOON TOWN! WE'LL GET IT.
ARCLIGHT1217
Oct 25, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Grind
Love your 'handle'!
I'm thinking that there is something in the burr in the unit. Empty the unit and remove the burr. Usually, this is done with a counterclockwise turn. Note how hard it may be to turn...you'll have to reverse this when you put it together. Now, clean out any coffee debris you find. Then, turn the unit over and tap it on a firm surface covered with newspaper. Reassemble and return to service.
Nov 03, 2007 | Grindmaster 810 Electric Burr Grinder
Jura Capresso 551 Electric Burr Grinder Logo
285 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
