Question about Bosch Washing Machines
Bosch nexxt 500 plus series washing machine. Cant open door as locked. tried the refresh program 4 times and still does not unlock. Baby sock or small rag may have gotten stuck?? Took drain hose off and it was unclogged.
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Based on your post there may indeed be something stuck, however this can also be the bi-product of the unit not spinning/draining properly.
These are the steps I'd suggest you take to move forward...
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) Bosch nexxt 500 plus series - macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful...I usually cover the edges with electrical or duct tape or wear welders gloves).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
( you should also see a ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good planBosch nexxt 500 plus series - macmarkus_31.jpgbr /> macmarkus_31.jpg THIS RELEASES THE DOOR LATCH IF PULLED
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap.
Hopefully you'll find the item/debris that initiBosch nexxt 500 plus series - macmarkus_28.jpgere.
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, or door lock but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Nov 11, 2010
  • boschwasher1 Dec 08, 2010
    Worked like a charm. If you want to drain water, you could use this procedure. Be careful when you open the drain, rather open it slowly. If the water is trickling from the top which mean there is water pressure and you have a lot of water to drain. Get a wet
I have an E13 code coming up after the machine tries to end the SPIN cycle, but never actually spins. It doesn't even sound like it's trying to spin. I have turned the machine off and set it to REFRESH,...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Idea. To manually unlock the door lock system, perform the following steps:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a teardrop shaped tab.
Gently pull the tab down approximately 1/4 inch, or until a click is heard.
5. The door may now be manually opened.
Pl give me a ‘very helpful’ rating for the free help, thanks, I badly need to improve my rating!
Jun 18, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Is it possible to reverse the doors on a Bosch Nexxt 500 series dryer? If yes, does it require a kit from Bosch?
yes ,it is possible,you don't require a kit from bosch,however,you will need to disassemble the machine.if you are not confident,get someone who is.
Oct 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Lint filter not allowing dryer door to unlock
Try unplugging it for an hour.. Might reset it..
Hope this helps !!
Rate me good ;o)
Jul 13, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My washer has E:13 on the display. I called Bosch
According to the service manual, you should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. I would run the short wash or refresh cycle without detergent and hopefully your lines will clear. I have also read that if this persists, powder HE detergent is better to use instead of the liquid because of certain chemicals contained in the liquids that cause it to congeal in some front loader drainage pipes. I hope this helps.
Jul 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch 500 Washer - Can't Open the Filter Door
I did it! The trick was to push a small nail into the hole and push in on the filter door while rotating the door...all at the same time. The original problem was the water not draining and the washer displaying code E04. Just like a previous solution stated, there was one knee high sock in the drainage pipe.
Nov 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
500 series washer
Hey try this, open the doo rand oil the door lock mechanism. next turn the machine on and push start/pause button. repeat ,repeat, repeat. if it does not release open round acees door at the bottom of the washer,there should be a manual unloccking pull inside pulldown to unlock(very thin strip of plastic. repeat process. also make sure rubber gasket around tub is secure and flush around washer openig.
Aug 31, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Wahing Machine 300 NEXXT Series
Sounds like a baby sock stuck in the drain. Remove the access door bottom right. Reach in and unscrew drain cover slowly and a little at a time. Put a sheet pan under it to catch the water as it drains. It’ll fill the sheet pan a couple of times so have patients. That’s where your clog will probably be.
May 17, 2008 | Bosch Nexxt 300 Series WFMC2201UC
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
