Question about Karcher 2500 PSI Pressure Washer
Why want my pressure washer suction the solution while pressure washing the house?
    Scholar:
  • 100 Answers
The first problem might be that you are trying to use the wrong nozzle, see this link to read more about what nozzle to use for detergents
If you still have an issue the problem is going to be in the chemical valve on the pump, there are two different styles they have on this type of machine, look at the links below on directions on how to repair your chemical valve.
Chemical Injector 1
Chemical Injector 2
Posted on Nov 11, 2010
Washer have a litter water come in
Hello Morris Daniels - Are the house valves fully turn on? Is the hose kinked or pinched? If not, then it sounds like you have an issue with the water pressure and possibly will need to replace the pressure switch. First try checking water pressure at another faucet in the house. Wait until water supply and pressure increase (water pressure for washer must be at a minimum of 30 psi). Straighten the water inlet hose if it is twisted or kinked. If any proves to be ineffective, contact a professional to move forward accurately.
Jan 03, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a 2200 Troy Pressure washer, I cannot get it to draw a detergent solution. I am using the black soap nozzel, i have a new siphon hose. any ideas?
Dismount the bolt that is use to connect the soap line.Turn on the washer and test if you fill if is "suction" intake air.Sometimes it becomes clogged so see if anything is clogging the suction .Is that not work the suction system is bad.
Nov 13, 2010 | Briggs & Stratton 2200 PSI Gas Pressure...
Fresh water is slowly leaking into the washer inside. we can run the wash onthe drain cycle and empty it, but it continues to slowly fill up again. help.....
Possible that the waterlevel sensor pressure switch is not working and so unless it contacts the cycle will not proceed according to the program.
So remove and test the pressure switch with a suction or blowing to see the contacts clicking.
If the switch is OK the program controller can be faulty
Sep 30, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Sears 2600 psi power washer
there should be a low presure tip for dispensing wash cleaner or if you have an adjustable wand turn it to low presure setting also make sure the suction tube is open some have a adjustable filter...good luck
Jul 25, 2010 | Briggs & Stratton 2200 PSI Gas Pressure...
Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Sep 24, 2009 | Briggs & Stratton Pressure Washer...
The motor works fine , no pressure out of hte hose, could it be the hose or pump, how do I trouble shoot. Also, how do I draw soap from a bottle to shoot out of the washer onto the house?
Since you did not mention the pump brand or type. I will just assume it to be a pressure washer, complete
with gun. The pump comes two suction hoses. One for the water supply and one for the soap bottle or pail There is pressure adjuster right at the pump near where the hose is connected. You can adjust to higher pressure by turning it clockwise. You can adjust the nozzle spray pattern by turning it. However, if your pump comes with only one set of suction hose. Then, it is designed to get the water
supply from the faucet with hose bib. The only one
set of hose is for the soap bottle or pail. It will **** the soap once the nozzle spray is opened.
hose,
Jun 30, 2009 | Plumbing
Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Mar 18, 2009 | Honda Garden
Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Mar 31, 2008 | Washing Machines
High (incoming) water pressure in house
You only have to regulate the incoming valve in your wall (to the washer) to have safe pressure.........don't see any reason why you can't do this.........& get on with your tons.......
Nov 27, 2007 | Kenmore 44102 Front Load Washer
Karcher 2500 PSI Pressure Washer Logo
235 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
