I have an old dell computer It will not power up.The run light blinks. The fan is not running.
    Scholar:
  • 85 Answers
The best option is to contact your Service engineer...
Posted on Nov 11, 2010
Power led blinking
1) the function can be the power supply box ffaulty, see if the fan are RUN, and test the power supply for +5VDC, otherwise is faulty the p.supply box
2) However you must RUN the software from DELL coming with the computer, or contact DELL for chat ONLINE,
God bless you
Jun 19, 2012 | Dell OptiPlex GX520 PC Desktop
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
My XPS 200 keeps shutting down and power light blinks
During when does your computer shutdown? Please check the diagnostic lights at the back as well which ones have light on it during the time it would shutdown.
Since you said that the light is blinking yellow it just says that your power supply is running outside its normal operating range. So most likely you would need a change of power supply. Maybe a higher wattage would be better.
Apr 28, 2010 | Dell XPS 200 PC Desktop
It will not power on when I press the power button and there is a blinking "A" light going off. When I press the power button the "A" light with a lock around it blinks, the fan sounds like it is going to...
try to run diags, press and hold fn key then press the power button an release them both at the same time when the computer turns on, check for any error message, or try to reseat your memory modules too
Oct 04, 2009 | Dell Latitude E6500 Laptop
Dell inspiron b120 laptop won't power up
i dont know why dell did this but you have to have battery to run your laptop. the ac coard charges the battery which runs the computer. I really know why but i dont like the configuration. it is so the power is clean to your computer and so the can have less parts in the laptop you need to get a new battery
Jun 23, 2009 | Dell Inspiron B120 Notebook
Spilled liquid in laptop; wont power up
Gennerally, this is a motherboad replacement at a minimum, often many other components are damaged too. If the system is 4 or 5 years old, it may be too old to be econmically repairable
Apr 06, 2009 | Dell Vostro 1000 Notebook
Dell 5150c shuts down orange flashing light
It was a faulty or worn out power supply fan. I just replaced it and the computer has been running for about an hour and a half and still no shut down. The system temperature is stable. It runs quieter now. New fan cost 13.88CAD.
Mar 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
The monitor will display the word"analog" and then blinks off
check the cable also id your cable end into the pc is it blue and about 15 pins or is it white and about 20 pins with 4 on one side? that hdmi. but analoge is vga and are you sure you pc is running do you hear a fan running inide? try that
Feb 13, 2009 | Dell UltraSharp 1905FP LCD Monitor
Dell Optiplex gx280 shuts down and orange power light blinks
It happens because the power supply is overheats and computer goes to standby. The power supply is 160w or lower. Specially it will happen if you put more devices in such as video card or sound card. So the only solution you have is to place a small 1or2 fans toward the power supply to make it cooler. And 1 more thing the power for the fans should come from other sources.
Sep 30, 2008 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
