Question about Watches
Westend watch jowan prima swiss made wheel balance has been damage and not working properly
3 Suggested Answers
SOURCE: swiss army watch
Did you have the battery checked to see if it was bad a first? Take it to a Reputable watchrepair , and ask them to CHECK your battery NOT replace it. Alot of times your watch will have a mechanical problem which will make your watch look like it is o.k. once you replace the battery but, two weeks later the watch stops again because the battery has lost enough power to now stop the watch again. Also your watch may have a electrical problem which a battery will not solve the problem. The coil (the orange straight piece in the movement), or the curcit board could be bad. Always have the store check your battery because, if you ask them to change your battety they will no matter if your original battery is good or not.
Posted on Sep 09, 2008
escapement
  • 2334 Answers
SOURCE: Repair of Ernst Benz Wright Brothers Centennial Watch
Yes, it is quite difficult to get the replacement parts from Switzerland and sometimes takes very long time. In my experience the longest was 9 months for the balance wheel.
If you are not satisfied with your watchmaker, check out direct services from Ernst Benz using this link: ernstbenz.ch
Here you can find all the info and services they are offering.
Do not forget to rate, please.
Posted on Feb 06, 2009
WATCH ON DESKFOR 24 HOURS KEEPS PERFECT TIME'WHEN I WEAR WATCH IT LOSES IN 1 HR. LOSES 40 MIN. BATTERY NEW. OMEGA CONSTELLATION 30 YEARS OLD CAN YOU HELP?
When a watch is on a desk, the balance wheel is vertical, when you are wearing it the balance wheel horizontal.
Has the watch been dropped onto a hard surface?
If the balance wheel bearing is worn or has suffered a large shock, then the shaft may move in its bearings or the bearings damaged, which may give the problem you decscribe.
Take it to a watch repairer to have it adjusted or repaired.
Dec 27, 2010 | Omega Watches
I don't have any technical problem with Gevril watch. I was wondering Gervil watch, why Gevril watches were not known by alot of people? and they are all On sale by big discount? ...
Although Gevril has been making fine Swiss watches for 265 years, you may have only heard of them in the recent past. Gevril was acquired in 2001 by Samuel Friedmann in his desire to fulfill a dream. Friedmann envisioned the renaissance of an established, high quality watch brand through a careful balance of strong tradition with the most modern technology.
The rich Swiss history of Gevril attracted Friedmann to the company. The original founder of this watch brand, Jacques Gevril, was born in 1721. Jacques was the first in a family line of watchmakers.
As would be expected of a watchmaker of his caliber, Jacques Gevril clocked in many firsts amongst the community of timepiece makers. Two of his most notable firsts were his invention of the repetition dial, and his becoming the first exporter of Swiss timepieces when he hand delivered a specially crafted watch to King Ferdinand VI in 1758. The king was so impressed with the craftsmanship that he personally appointed Gevril 'Watchmaker to the Crown of Spain'.
Aug 21, 2010 | Gevril GV2 Classico Swiss Automatic (Day...
Wenger Swiss Military Watches Sportedge Bracelet Watch (For Women): I've dropped my watch on the ground twice at work ...
Please run through below link. That is the site of Swiss, and Customer Services will help you, depending from what country you came from.
Swiss
May 17, 2010 | Swiss Army Wenger Sportedge Bracelet Watch
How to remove the back cover of the Swiss Army Victornoix pocket watch so to replace the battery?
The back will either have a small slot on one edge to pry it off or indentations around the perimeter for a case wrench to unscrew it. Specialized tools are used to avoid scratching the case. You best bet is to take it to a watch shop and let them do it. Most places charge between $3 - $8 to properly do it without damaging the case and they should also change the gasket to maintain water resistance if so equipped. Once you have it open you risk damaging the movement as you change the battery. It's not that it's a tricky procedure but you can easily damage something that will cost a LOT more than $8 to fix if you don't have experience.
Apr 09, 2010 | Swatch Irony watch
Swiss army stopped
If qz. see previous answer. If it's mechanical and absolutely all the moisture is not eradicated then rust may begin to form and will over time cause damage. So if it's mechanical take it to a watchmaker for servicing asap.
Please rate my solutions.
Jul 26, 2009 | Relic 0504648FA
Watch.....
Rolex is very fine watch if you maintain it properly. Is it more accurate for keeping time than a quartz watch? No, even specs tell you that. Hope that helps you.
May 30, 2009 | Rolex Daytona 116520 Wrist Watch
Need to change the battery and take off the steel back of the watch
This may be a threaded backplate and removing it without the proper tool may cause some damage you won't like. Most jewelers will sell and install the battery for a modest price.
Mar 22, 2009 | Swiss Military Watch
Feb 05, 2009 | Ernst Benz ChronoJewel Mid-size 40mm...
DIFERENT DISPLAY FOR THE SAME WATCH MODEL.
A watch is considered Swiss, when it is made in Switzerland (hope I spelled that right), by a Swiss Comapny, using 50% or more parts that are also Swiss. Watches made this way will have "Swiss Made" Swiss" or a similar print on the back.
If it has the lables of "Swiss movement" "Swiss Case" then it means that it is only partly swiss made, and will not have a lable listed in the first part of this solution branded on the back.
Hope I helped, have a great day.
Jan 13, 2009 | Invicta Swiss Pro Diver 9309 Wrist Watch
Can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Jan 05, 2009 | Croton Watches
Watches Logo
55 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
