Question about New World Spirit 100 (Gas) Kitchen Range
How to change a thermocouple in new world oven
I have a New World Double oven, dual fuel range cooker - NW 90DFD0 The main oven isn't heating up.
Hello Ally;
My name is Peter. I am a retired field service appliance technician.
You may not have a problem. Normally your oven will rise about 40 degrees F. above the set temperature and then shut down, until the oven temperature falls 40 degrees F. below the set temperature, then the oven turns back on.
Your oven temperature is controlled by you oven thermocouple.
You also have a high temperature limit switch, which turns the fan on when you go too far above the set temperature to vent the oven. This may be bad.
Mar 10, 2016 | Ovens
Electrolux oven gets hot then switches off
Hey Richard Skerritt, thank you for your post!
I understand that your Electrolux oven will shut off once it becomes hot and you have recently changed the thermocouple. This sounds like a possible issue with your thermostat or control panel. If there is a slight miscommunication within your oven you may be able to perform a reset which will help clear any miscommunication. If you flip your household circuit breaker off for roughly ten minutes that is the best way to reset your oven. I hope this information is helpful. -Matt
Feb 15, 2015 | Electrolux Ovens
G90m
no not the thermocouple it would not light if it was that , sounds like its the thermostat which should be in the makes hand book underspares .
Jan 06, 2012 | New World G90m Gas Double Oven
How to replace a thermocouple in a New World Spirit 100 gas range cooker
not at all hard to replace just have a few small wrenchs on hand 10mm 7/16 maybe 1/2 in and screw driver. how do you know its a thermocouple problem, theremocouple are on commercial ovens and basic ranges usually a domestic range has a glow coil operating oven and not a thoemocouple
Feb 04, 2010 | New World Spirit 100 (Gas) Kitchen Range
Hi When I try to light the gas oven, it will light but as soon as I release the button the flame goes out
Are you giving the thermocouple time to warm up?
You have to hold the oven knob in for a while to warm the thermocouple before the oven will stay alight. If you are doing this then the thermocouple needs replacing.
See my other posts for a link and price as it was at that time.
Dec 11, 2009 | New World 50GSO Gas Kitchen Range
Our New World gas oven is just on two years old (i think) when we use the grill it keeps clicking and then it just shuts itself off as though there is no gas getting to it. The pilot light will continue...
If the grill is clicking because you are holding the ignition button, which I'm asuming you are because the grill will not light then the thermocouple on the grill is broken.
goto www.espares.co.uk but unfortunately you'll have to ask them if they have any grill thermocouples for this model as I can't find them anymore only thermocouples for the oven.
Nov 08, 2009 | New World 50GSO Gas Kitchen Range
On lighting the oven you release the gas knob and gas goes out
you need a new thermocouple. Should be fixed by a qualified person.
Sep 30, 2009 | New World Spirit 100 (Gas) Kitchen Range
New World Spirit 100 (Gas) Kitchen Range Logo
111 people viewed this question
Top New World Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
John Rodgers
John Rodgers
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
