Question about Pentax Optio M20 Digital Camera
Cam takes white pix outside and horizontal lines inside.
I am Katsugo. I posted on June 1st. I have the same problem as the previous post. I just dont know if the camera has been dropped. How can I resolve this problem?
Thanks
posted by shel1009 on Mar 28, 2008 Report abuse
hi my husband dropped our camera on the beach and now when take pictures outside it is all white and inside it has lines throught out it running horizontal.
can anyone suggest what to do or should we buy a new camera?
Post Solution Work Queue --> Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 1 Other User Has The Same Problem Comment by katsugo, posted on Jun 01, 2008 I have the exact same problem. I let my teenage daughter use it and when I get it back, I have the same problem taking pix.
    Genius:
  • 2,028 Answers
Try taking the camera in for a cleaning service. Having lived near the beach for sometime, believe me when I say, you would be amazed at where fine beach sand can get.
Posted on Jun 17, 2008
  • 4,472 Answers
A problem with these cameras
http://www.pentaximaging.com/customer_care/pentax_service/
That will get you started on getting it serviced.
Good luck,
Lee
  • 1 more comment
  • Lee A.
    Lee A. Jun 17, 2008
    If you find my solution helpful I only ask in return that you accept and rate it accordingly.
    If you need anything else don't hesitate to use the Ask Me feature.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 18, 2008
    I am assuming from not hearing from you that you have your answer. If you do happen to have a moment and could rate my solution accordingly it would be greatly appreciated.
    Keep me posted,
    Lee
  • Lee A.
    Lee A. Jun 19, 2008
    Still hoping to hear back.
    Lee
    Genius:
  • 3,422 Answers
HI,
Its a CCD issue and you'll have to get it repaired and thats the only solution to fix it.
  • Priya darshan Jun 17, 2008
    Before that please try reseting it to the factory default and see if it helps.
    Please CLICK HERE to refer the manual and follow the steps to reset.
    Goodluck..
Sanyo dp50747 plasma tv is only showing in the middle of screen no video blue square showing horizontal 20 inches wide.The outside of square is blue solid both sides inside the square fuzzy lines red,...
It is line fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 17, 2014 | Sanyo Televison & Video
Why or what causes the TV to have white lines acros the screen
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 19, 2014 | Televison & Video
What can cause horizontal white lines in a projection television? The TV is about 10 years old, and I am told it may be the internal power source. Could that be true?
can you see a pix or is it all white with lines running diagnally about every 1.5 inches--if you do not have a pix only lines problem is the 200 volt line feeding the crts(off flyback transfofmer)
Sep 02, 2009 | Sony KP-61XBR300 61" Rear Projection...
White pictures
There is sand or grit inside of the camera. you need to open it up and take the sand out. but beware of the flash wires. packs a mighty jolt.
Jun 06, 2009 | Casio Exilim EX-S500 Digital Camera
Canon S2 IS - LCD screen is white after taking an outside picture
the image is all white or has lines through it.Definitely sounds like a repair issue, and has been a previous problem with the camera in the past. There is a defect in the sensor of the camera, and happens quite frequently in this model. I would try and contact Canon about it, and see if they'll repair it for free. If not, its probably going to cost more than the camera is worth to repair it.
Mar 24, 2009 | Canon PowerShot S2 IS Digital Camera
White lights blurring pix when taking pix outdoors
pls confirm ur problem from here
http://www.imaging-resource.com/badccds.html
it is not ur fault my friend thousands are suffering due to this
It is actually CCD Failure !! U ARE LUCKY ! u can get it repaired FREE OF COST from canon just call them on the number if u are in US go to the link below and they will send u postage paid envelope and repair free of cost PLS RATE ME FIXYA for the help dont u think i deserve it
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
pls dont gorget to rate me FIXYA !
Mar 21, 2009 | Canon PowerShot A430 Digital Camera
CCD failure !! thousands having the same problem
samsung will do it free of cost as all are doing it is a manufacturing fault they cant deny it pls contact ur local samsung support centre
see this
pls rate me FIXYA for help !!
Mar 21, 2009 | Samsung L200 Digital Camera
Nikon Coolpix 5400 lines in pix
Yes! Send the camera to Nikon with the service form. It takes about 3 weeks, free of charge.
Nov 05, 2008 | Nikon Coolpix 5400 Digital Camera
RCA-single horizontal white line
Your vertical deflection IC is bad.
Nov 04, 2008 | Televison & Video
Poor printing from my printer
Hi D
First off review my previous post about under head cleaning and follow the process through. Make sure you have no build up of fluff or a small piece of paper stuck below the head.
Once you have completed the under head cleaning cycle, let me know what difference is made via this post. Further wirk may be needed
Sep 20, 2007 | Epson Stylus RX500 All-In-One InkJet...
Pentax Optio M20 Digital Camera Logo
132 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
halotheracer
halotheracer
Are you a Pentax Camera Expert? Answer questions, earn points and help others
