Question about Panasonic Pro Curve ES 8019N Electric Shaver
I have a Panasonic ES- 8019 which is the best shaver I have ever owned. Unfortunately I can no longer charge the shaver, without the body becoming very warm. I think it needs a new battery and a good cleaning but no one works on these shavers. I live in Naples Florida where can I have this shaver repaired. My phone is 239-513-9143 E-mail joelcarmody@embarqmail.com
  • 125 Answers
SOURCE: wet/dry Panasonic shaver stopped
Do you think a 1000uf, 25 volt capacitor will fit inside a shaver?
Posted on May 30, 2007
SOURCE: Braun 5520 Shaver Stopped Working
order a replacement 5520 PCB assembly. it is very easy to replace. remove the two bottom cover next to the charger and remove the two screws. slide the unit out and pop off the black plastic cover. remove the defective PCB battery module and insert the new one. replace the black plastic cover and slide the shaver back into the shell. charge annd it ready to go.
Posted on Dec 17, 2007
SOURCE: I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
Pry out the blue button. In the oval hole where the button was you will see a thin metallic part (semi-circular shapes on each side); pull it out through the hole and the switch will be functional.
Posted on Aug 12, 2008
  • 14 Answers
My model is almost the same as your model ...
Problem: Model ES7037CMB - Over the past month the Panasonic shaver would turn on with 3-4 tries, but now will not turn on at all – the on-off switch must be bad after only 7 months of wet use. Before sending in I found this diagram:
Disassembly: Remove bottom Phillips screw & end cap, pop off each plastic side with fingernails (reinstall them from top 1st), remove 4 screws, remove 2 clips, take top off. Remove battery case and the on-off little, white plastic lever fell out. Slide off the white plastic/metal on-off slider & clean contacts with knife … my bottom contact was black & top was clean.
Assembly: Reinstall on-off slider (white plastic with metal contacts) by sliding back in grooves -- hardest part - place the on-off plastic lever on the battery back unit – I tried to put it on the case and could not get it to stay on. Slide the battery pack back in with the plug prongs in the holes in the end being careful not to drop the on-off lever. Test shaver. Stuff battery wires inside case – screw 4 screws and add 2 clips on, then final screw in the end after cap placed on. Easy once I knew how to put the on-off lever on the battery side – that was tricky. Total time was about 1 hour – next time it will be about 15 minutes. Works great! jgg 12-27-08. Think I will use it dry from now own since it had a lot of whiskers inside of it and maybe wash only the head as needed with baby shampoo.
Posted on Dec 27, 2008
brector3
  • 1610 Answers
SOURCE: Braun 7570 shaver won't switch off!
Most likely, the switch mechanism is broken inside and will need to be replaced. This part comes with the outer housing of the shaver and is available at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-syncro-body-housing-select-models-p-811.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Posted on Jun 29, 2010
How can a buy the power cord for a ES-LT41 shaver?
panasonic WESRT51K7658 adapter charging cord for men electric shaver panasonic es lt41 power cord replacement parts.
panasonic es lt41 charger power cord
Jan 14, 2015 | Panasonic Personal Care Es-lt41-k Shaver...
Need a trimmer replacement
panasonic WES9025PC replacement outer foil and inner blades set for electric shaver panasonic es la63 replacement parts.
And panasonic es la63 parts is also separated foil and blades, then panasonic es la63 replacement foil is WES9165PC and panasonic es la63 replacement blades is WES9068PC.
Feb 06, 2013 | Panasonic ES-LA93 Shaver Electric Shaver
I have a Panasonic ES8023 rechargeable razor and I want to replace the batteries in it. Where can I find replacement batteries?
When my ES8023 razor quit working, I decided to buy and try a Braun Series 3 razor that ultimately I was dissatisfied with. I favor the Panasonic's narrower head. Deciding to replace the Panasonic's batteries, they were very easily removed. Noting they seemed barely larger than AA batteries, I decided to try replacing the OEM Ni-Cd batteries with some NiMH batteries I had. My only real concern was whether the NiMH batteries would charge adequately from the ES8023 charger....they did, which was great news since Ni-Cd batteries are inferior to NiMH.
Adapting the shorter AA NiMH batteries to the shaver was as simple as laying a small hex nut (#10-32 size I think) upon the negative (upper) terminal in the shaver and then inserting the battery. This makes for a tight fit and provides contact for teh negative end of the battery. The positive nub of the battery makes contact to the shaver's positive terminal with no issues.
The original battery has a long pin extending from the positive tip that I think may be to provide a pin that extends through the shaver body for a charging cord to connect to. However, for the induction charger of the ES8023, I didn't think the pin would be needed, and it wasn't. With two NiMH batteries inserted as described and the shaver reassembled, I successfully charged the shaver overnight in the original charger. I believe NiMH batteries typically charge at a higher current draw than NiCd batteries do, so I do expect a longer charging cycle to be required, but I don't anticipate any issues.
Mar 07, 2011 | Panasonic Linear ES 8003 W Electric Shaver
Where can I find a replacement battery for a Panasonic ES4011 wet/dry shaver? I have looked everywhere. THANKS!
Panasonic does not sell the specialized batteries for their shavers. Your best bet would be to purchase one of the models that replaced it. I have included links to two models below. These are very similar to model ES4011 and use the same shaver head as your model
http://shaveroutlet.com/shavers/panasonic-es-rw30s-mens-wet-and-dry-shaver.html
http://shaveroutlet.com/shavers/panasonic-es4026-shaver-with-er416-nose-and-ear-hair-trimmer-p-699.html
Dec 15, 2010 | Panasonic Sonic-2 ES 4011 K Electric...
Need a panasonic razor cord for model ES-LA93
Panasonic razor cord for model ES-LA93 is Panasonic WESGA21K7662 charger power cord replacement.
Sep 13, 2010 | Panasonic Health & Beauty
Replace batteries?
Panasonic uses a specialized battery inthir shavers that have prongs on the ends. These are used only in panasonic shvers. Panasonic does not and will not sell these batteries to the consumer. You can not replace the batteries in this model without sending the shaver to the authorized Panasonic repair center and it will cost you more to repair it than to buy a similar new model.
You may want to take a look at buying the updated version of your shaver. It uses the same foil and cutter and is VERY similar to yours. You wll find this model available at shaveroutlet.com. See link below.
http://shaveroutlet.com/shavers/foil-shavers/panasonic-es-sa40-wet-dry-rechargeable-shaver.html
Mar 20, 2010 | Panasonic ES 3042S
Shaver will not hold a charge, panasonic es8003
Sounds like the switch is dirty and not lettingit run ... look at this video on how to clean the switch ... mine would not charge or run until I cleaned the on-off switch.
http://www.youtube.com/watch?v=9b7lf5hqjag
Apr 13, 2009 | Panasonic Linear ES 8003 W Electric Shaver
Panasonic 8077 shaver top fastener broken
This may sound nutty. Please don't laugh. It works: attach a rubber band from the top "broken" corner of the shaver to the underside. Yup. Lousy design. Are you done laughing yet?
Jan 28, 2009 | Panasonic ES 8077S Electric Shaver
Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Dec 05, 2007 | Remington ES-1000 Electric Shaver
Panasonic Pro Curve ES 8019N Electric Shaver Logo
159 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
