Question about Toshiba REGZA 52RV530U LCD TV
I have a Toshiba Regza 52RV530U HDTV and it now shows an 18" verticle black bar down the left side of the screen. LVDS cable and Main Board need to be replaced. How much should this cost to repair? If I choose to repair the Toshiba myself, where can I purchase the parts?
  • 10 Answers
What year was the TV manufactured? What model is it?
If its manufactured in 2008 get back with me.
I have a failing LCD panel and am starting a class action lawasuit against Toshiba becuase there is a high number of failing units built during this time that Toshiba is not addressing and their customers are not being herd... well I am going to make them listen!
let me know if you want to be part of this activity.
Curious too, did you fix the TV?
andedwar@cisco.com
Posted on Jan 06, 2011
Vertical black bar on my LG 47" LCD shifting the image to the right
Two possibilities are there. The first one is, with loose LVDS cable, that connects the T'Con board to display panel. The second is the fault with its main digital processor board.
May 21, 2013 | LG 47LC7DF 47 in. LCD HDTV
Maxent 42" flat screen M # p4202yd04
reseat the the LVDS cable inside the set. this is the cable that connects the main board to the panel. if that does not work replace the LVDS cable and the main board.
Mar 05, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
My 52" Toshiba Regza has a six inch vertical line just left of center that changes color as the picture changes. Some times it stays with the same pattern for quite a while. It goes away when I turn it off...
you must either change the t- con board, or the left board strip. it is dangerous because mines caught on fire. but most like since that strip is connected to the lcd screen u will have to replace the whole entire screen.
Aug 09, 2010 | Toshiba REGZA 52RV530U LCD TV
Verical lines on half of the screen
I have the same prob. Please help my *** out here!
May 25, 2010 | Toshiba REGZA 52RV530U LCD TV
Have 52 inch toshiba regza tv black box appeared in top left corner will not go away tried changing channels still there
Check to see if the tv is in the text mode of the closed captioning.If not you may need a new main signal board.Also try unplugging the set for a couple of hours to reset it.
Nov 04, 2009 | Toshiba REGZA 52RV530U LCD TV
Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Oct 30, 2009 | Toshiba 52HL167 52 in. LCD HDTV
My Toshuiba 46RV530U tv has developed an image
Sounds like you need to try reseating the lvds cables on the t-con board.This board is located at the top of the set in the center.You will have to remove the metal shield covering the board.Then you will see to flat cables connected to the board,one for each side of the screen.carefully unlock the connectors and remove and replace the cables.If this does not work you will need a new t-con board.I'm not sure about this particular model but sometimes the t-con board is only available as part of the lcd panel assembly.Good luck!
Oct 15, 2009 | Toshiba REGZA 46RV530U LCD TV
Big black bar in the middle of the screen vertical
You will need to replace the Main board and I would also replace the LVDS cable that connects the main board to the LCD panel. Very easy to do, but might take about 2 hours depending on your comfort level.
You will need:
Screw Driver
LVDS cable – Part # 0500-0505-0540
Main board – Part # 3632-0652-0395
Those part numbers will work if you have a model number VOJ320F1A.
If you post the model number I will try to find the part number for you.
thanks
Aug 11, 2009 | Vizio L32 32 in. LCD HDTV
LG 50PG3000 SOUND BUT NO PICTURE
This sounds like a screen problem, possibly the internal connecting cable (LVDS) which connects from the main board to the screen may have become loose. If not a replacement screen would be required.
Jun 29, 2009 | LG 50PG30 Plasma HDTV
Toshiba REGZA 52RV530U LCD TV Logo
306 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
