Question about eMachines T5224 PC Desktop
I have an emcahine T5224 it was given to me ive tried fixing it and determined its not the HDD because it loads the OS on my other computer and works just fine but for some reason it stops and says there was an issue loading the OS and gives me the options to tr to laod windows normaly, last known working configuration ect. but it still doesnt work, and it is not the HDD because it has been tested and works perfectly, some help please?
  • Joseph McAleese Nov 11, 2010
    the HDD is from my other computer, just to test it because i didnt not recieve it with any kind of memory, i literaly was just given the computer so dont know much about it, other then no HDD and no ram so had to put my own in, i tried another HDD but i think this HDD that i put in was broken, it came up with Blue Screen STOP: 0x0000007B (OxF8968640, 0xC0000034, 0X00000000, 0x00000000)
    Scholar:
  • 74 Answers
You stated that it loads that OS on the other computer. Is this by taking out the hard drive and putting into another PC? If it is, then I would have thought there is h/w issue elsewhere in your PC...
Usually if you have a message saying that it could not load windows properly, it is an OS issue which I would recommend you fix by using your emachines recovery disks.
Hope that helps
Posted on Nov 11, 2010
  • azzh81 Nov 12, 2010
    If you put in a HDD from your other pc, it will probably have drivers setup that don't work with the Emachine and therefore stop windows from loading. However, if you have a look at the STOP message, it may say something about a memory error. It could therefore also be a RAM issue that causes this error.
    The best thing to do would be to get a blank HDD and check it is detected in the BIOS. Go through the motions of installing Windows - if it fails, chances are that some other hardware has failed. Poss RAM/ Motherboard etc
I cannot get the Dell PowerEdge 840 to recongize and of my HDD in the Raid array.. Trying to install the OS but tells my on HDD is detected
Then you need to get into the BIOS of the PERC RAID controller and inspect the state of the physical/logical volumes. Reboot the machine and watch for the prompt after the PERC5/6 RAID controller loads it's BIOS.
Considering this a null issue given the age, though...
Jan 21, 2014 | Dell PowerEdge 840 (becwmk1_2) Server
I have a dell 9300 that loads bios fine but wont load os even after a complete reinstall? Diag runs threw just fine? it loads to safe mode or normal or bootlog. but then upon entering any option bios...
You might want to play with the BIOS options on the hard drive. If it shows AHCI change it to SCSI then vice versa if the are other options given.
If it still doesn't work, try moving the HDD to a diferent SATA port to check if the OS will load.
If not, it's a possible problem with the HDD.
Let me know what happens next.
Hope this helps!
Aug 07, 2011 | Computers & Internet
My sony vaio pcg-551l won't go past "no operating system"
If this is the first time your trying to start up this computer try to restart it. Sometimes brand new laptops can fail to find the operating system on first startup. If this isn't the case it sounds like your Hard Drive is either disconnected or has had a critical failure.
Mar 15, 2011 | Computers & Internet
When i press the power button my computer turns on and after the dell loading screen it freezes completely if im fast enough i can press F2 F12 and even go to Safe mode screen but none of the options work...
his could be caused by a couple of problems but you are going to need access to a second computer to determine the problem.
1) You have a disk that is failing and it has had an error. Got to the disk makers site and down load their diagnostic program and check the disk. This is a stand alone CD so you don't need to boot into the OS.
Another program that can temporarily fix errors is http://www.dposoft.net/ This program will stop after fixing the first error unless you buy it. Again, this is a stand alone.
If it is a disk error, you need to quickly get your data off and install a new disk.
Don't have a second computer? then you need to take it to a local computer store where they can remove the disk, install it in a desktop and check it for errors.
2) This could be a virus, but I think #1 is your problem. TrendMicro.com has a free online virus scan if you can install the disk in a second computer.
Aug 11, 2010 | Dell Latitude 110L Notebook
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
I have a Maxtor one touch 2 external hard drive,serial#2dd10020,worked fine on Windows XP,I'am now using it on Windows 7,it shows up in computer as drive Z,I cannot unlock it to get to my files,any help...
ok for one your computer no matter what OS you are using stores no drive letter , a drive letter is only given in the order as it is
installed on your system for example if you use 2 internal HDD
and one external HDD your computers C: drive will be the master
the F: will be the slave and the external will be G: , now if you have changed the order of the drives from your last OS then it
will conflict to the last drive letter given , your unit will know
what letter it was given so it must be in the same location for
the new OS , there is also the possibility that Windows 7 doesn't
support the driver for that unit , you can try hooking it up to
another computer retrieving your data , then hooking it back
up to windows 7 run its software , then installing the data back
into your HDD
Jan 29, 2010 | Maxtor OneTouch II external hard drive...
My acer 5630 laptop does not boot up
Try reinstalling the OS with your restore disks. It might be that you have HDD failure in which case you would need to replace the HDD.
Feb 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
OS Loaded on SCSI HDD Cashed
If the Bios did not detect the third drive, try switching it to a known working slot and see if you have a bad drive, or something wrong with the cage or cabling. The 3000 were shipped with either a 68 pin drive cage or a 80 pin drive cage. The 68 pin drives and the 80 pin drives are not interchangeable. To make matter worse, the drive cage would be configured as simplex or duplex. For duplex mode, you will need to connect two SCSI cables to the cage.
Dec 30, 2008 | Compaq ProLiant 3000 Server
Wont load
It is on your os problem. Insert your OS installer. You don't have to install a fresh copy but you can repair your previous OS installation. Make sure you have set your boot sequence to CD, floppy and last HDD. You can now reinstall your drivers after doing that.
Dec 21, 2008 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
eMachines T5224 PC Desktop Logo
289 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
