Question about Ruud Matching Split Air Conditioner
I have a RUDD Achiever series split unit with electric heat, model # UHSA-HM2417JA. Can I install the furnace on it's side in my crawlspace? Or does it have to be istalled upright?
  • 659 Answers
SOURCE: Rudd Furnace under-achiever 90 no lights nothing
You say you have power but what is the voltage? You said that that you are using a 3 amp fuse so you are referring to a gas unit. Ok, have you checked the safty switch that is located on the blower cabinet, the one that the door sits against to make sure that you have power leaving the switch? Also, on some units, there is a limit switch that come directly off of the above mentioned blower cut off switch that when tripped, will cut main power to the board. Its located on the inducer or on the flu pipe, but mostly on the inducer houseing. Make sure that all your manual reset limits are reset. But check the switch first and then work your way to the limits. This is the only thing left and was probably the probablem before you replaced the board. If you have any more questions, please respond to the thread.
Posted on Mar 31, 2009
buffalonyman
  • 1865 Answers
SOURCE: trying to change out my thermostat to a
You should check the terminals where the other end is connected, there is no guarantee that the installer followed a wire color code. There should be a diagram in the HVAC unit. Normally, you have the power wire from the XFMR, a wire for the heat, a wire for the AC, and a wire for the fan.
Posted on May 05, 2009
james3751
  • 614 Answers
SOURCE: rudd achiever serie. where do the 24 volt wires go
The two wires from condensing unit go yellow or y from Tstat and theother wire goes brown if it is a Rudd or Rheem. Red from Air HAndler goes to Tstat R Green to Tstat G white to w. If it is digital tstat brown goes to C.
Posted on Jun 05, 2009
FurnaceGuy
  • 74 Answers
SOURCE: I have a Rudd Achiever 14 and I want to know if
Take the front panel off the air handler and look for a heat element. You should notice controls and relays with larger wiring to it. It may not have any heat but you can add it.
Posted on Jan 06, 2010
atocrxr
  • 135 Answers
SOURCE: 2 Rheem Protech 500 thermostats, 1 upstair & 1
Have you checked to make sure that all of the supply registers are open, the air filter is clean and nothing is blocking the return air grill?
It almost sounds like you could be cycling on a limit switch.
Usually on gas furnaces, the blower is controled by the onboard controls, in the cooling mode the thermostat will control the blower.
I would be looking past the thermostat, at the furnace it self.
I hope you find this helpful. If you continue to experience problems, please let us know and we will dig deeper. :)
Paul
Posted on Apr 04, 2010
We are trying to buy a home which once had oil heat and it has part full basement and part crawlspace, IF the old tank is still on the property (converted to gas long ago) unfortunately it's in the...
I have not seen an home heating fuel oil tank buried before. Most such oil tanks were standing on legs and outside of the house. If the old oil furnace was where the new gas furnace is, look for the old fuel line hanging loose. It might tell you where the tank was or is.
Jul 29, 2011 | Malco Products Malco STKM Ductwork Tool...
My ruud achiever series model UHSA-HM2417JA is blowing out cool air even when turned on to heat. we replaced a fuse yesterday but no luck. help!
hi manda,
i think its a heater problem..if you can check the heater..its better!
http://www.2instructions.com/search.php?cmarque=RUUD&modele=UHSA-HM2417JA..
try downloading the manual here..
mastergani
Jan 07, 2011 | Heating & Cooling
Rudd Achiever series model RQNJ-AO42JK 000 mfg
Turn the thermostat as low as it will go and have someone stand out side, they should here the condensor fan and compressor come on at the same time. They are two distinctive sounds so you should
be able to tell if the compressor is running.
If nothing happens and you are skilled with electrical
you can turn power off and remove the electrical
cover to the outside unit. Restore power and carefully
push in the contactor, if the fan and compressor
starts you have a thermostat or low voltage problem.
If just the outdoor fan runs on any attempt, more than likely you need a new capacitor.
Jun 18, 2010 | Ruud Central System Air Conditioner
Jan 05, 2010 | Ruud Handler Air Conditioner
I have a Rudd ultra series 16.0 and I cant get the air to blow hot..I have heat on and "hold at 90" but it wont heat..ac is less than 1 yr old
I am curious if the unit is short cycling. If it is, take the face off of your thermostat and turn the anticipator to .4 and when you can have a tech take an amp draw on your furnace. If it is a new furnace and old thermostat, it may not have been checked with the new install
Jan 05, 2010 | Heating & Cooling
HOW MANY BTU IS A RUDD ACHIEVER 90 PLUS FURNACE MODEL RCBA-6089GG24X1?
This is the Model number of your coil which is a 5-ton. Your heater Model number will be behind the front panel of the heater.
Jan 04, 2010 | Heating & Cooling
Rudd achiever serie. where do the 24 volt wires go to on the air handler.
Jun 04, 2009 | Ruud UAMB Air Conditioner
Rudd Achiever A/C float switch is clogged.
If the pump was bad the switch is supposed to shut down the ac so the water damage won't occur. You most likely have a bad drain.
May 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Trying to change out my thermostat to a programmable one but the wire colors don't match up, what color wire does what on the Rudd Achiever series?? green/brown/yellow/white/blue
May 05, 2009 | Ruud UBHC Air Conditioner
Ruud Matching Split Air Conditioner Logo
55 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
